My Drop Down menu gets white whit some browsers...
Leon
I implanted a drop down menu that is 100% in the overall_header.tpl file.
But for some reasons it gets white for some users.
I know that some whit firefox gets a white Drop Down List :?
http://www.volunteerforum.se/testpage.php
(The testpage has its own test header)
anyone that knows what the problem can be ?
(Can it be a conflict whit the forum's code somehow ?)
If you take "View Sorce" you can see the full drop down menu code:
<style type="text/css">
#csstopmenu, #csstopmenu ul{
padding: 0;
margin: 0;
list-style: none;
#csstopmenu li{
float: left;
position: relative;
#csstopmenu a{
text-decoration: none;
.mainitems{
border: 0px solid blue;
border-left-width: 0;
background-color: #EFF3F6;
.headerlinks a{
margin: auto 9px;
font-weight: bold;
color: white;
.submenus{
display: none;
width: 13em;
position: absolute;
top: 1.2em;
left: 0;
background-color: #FAFAFA;
border: 1px solid silver;
.submenus li{
width: 100%;
.submenus li a{
display: block;
width: 100%;
text-indent: 3px;
border: 1px solid white;
html>body .submenus li a{ /* non IE browsers */
width: auto;
.submenus li a:hover{
background-color: #EFEFEF;
color: black;
#csstopmenu li>ul {/* non IE browsers */
top: auto;
left: auto;
#csstopmenu li:hover ul, li.over ul {
display: block;
html>body #clearmenu{ /* non IE browsers */
height: 3px;
</style>
<script type="text/javascript">
startMenu = function() {
if (document.all&&document.getElementById) {
cssmenu = document.getElementById("csstopmenu");
for (i=0; i<cssmenu.childNodes.length; i++) {
node = cssmenu.childNodes[i];
if (node.nodeName=="LI") {
node.onmouseover=function() {
this.className+=" over";
node.onmouseout=function(){
this.className=this.className.replace(" over", "")
if (window.attachEvent)
window.attachEvent("onload", startMenu)
window.onload=startMenu;
</script>
<ul id="csstopmenu">
<li class="mainitems">
<div class="headerlinks"><a href="http://www.volunteerforum.se/portal.php">•Portal</a></div>
</li>
<div class="headerlinks"><a href="http://www.volunteerforum.se/index.php">•Forum</a></div>
</li>
<div class="headerlinks"><a href="#"><IMG SRC="http://www.volunteerforum.se/overallheader/ar1.gif">Navigation</a></div>
<ul class="submenus" style="width: 14em">
<DIV align=left>
<li><a href="http://www.volunteerforum.se/portal.php">Portal</a></li>
<li><a href="http://www.volunteerforum.se/index.php">Forum</a></li>
<li><a href="http://www.volunteerforum.se/blog">Blog</a></li>
<li><a href="http://www.volunteerforum.se/links.php">Links</a></li>
<li><a href="http://www.volunteerforum.se/search.php">Search</a></li>
<li><a href="http://www.volunteerforum.se/websiteindex.php">Website</a></li>
<li><a href="http://www.volunteerforum.se/album.php">Photo Album</a></li>
<li><a href="http://www.volunteerforum.se/general.php">General Content</a></li>
</DIV>
</ul>
</li>
<!-- BEGIN switch_user_logged_in -->
<div class="headerlinks"><a href="#"><IMG SRC="http://www.volunteerforum.se/overallheader/ar1.gif">User Menu</a></div>
<ul class="submenus">
<DIV align=left>
<li><a href="http://www.volunteerforum.se/profile.php?mode=editprofile">Profile</a></li>
<li><a href="http://www.volunteerforum.se/memberlist.php">Memberlist</a></li>
<li><a href="http://www.volunteerforum.se/groupcp.php">User Groups</a></li>
<li><a href="http://www.volunteerforum.se/privmsg.php?folder=inbox">Private Messeges</a></li>
</DIV>
</ul>
</li>
<!-- END switch_user_logged_in -->
<!-- BEGIN switch_user_logged_out -->
<div class="headerlinks"><a href="#"><IMG SRC="http://www.volunteerforum.se/overallheader/ar1.gif">Guest Menu</a></div>
<DIV align=left>
<li><a href="http://www.volunteerforum.se/profile.php?mode=register">Register</a></li>
<li><a href="http://www.volunteerforum.se/whatis.php">What is a volunteer ?</a></li>
</DIV>
</ul>
</li>
<!-- END switch_user_logged_out -->
<div class="headerlinks"><a href="#"><IMG SRC="http://www.volunteerforum.se/overallheader/ar1.gif">General</a></div>
<DIV align=left>
<li><a href="http://www.volunteerforum.se/faq.php">FAQ</a></li>
<li><a href="http://www.volunteerforum.se/sitemap.php">Site Map</a></li>
<li><a href="http://www.volunteerforum.se/aboutus.php">About Us</a></li>
<li><a href="http://www.volunteerforum.se/contact_form.php">Contact Us</a></li>
</DIV>
</ul>
</li>
<a href="{U_LOGIN_LOGOUT}"><B><FONT COLOR="#2355C0">•{CA_L_LOGIN_LOGOUT}</FONT></B></a>
</li>
<a href="http://www.volunteerforum.se/profile.php?mode=register"><B><FONT COLOR="#2355C0">&nbsp; •Register</FONT></B></a>
</li>
</ul>
<div id="clearmenu" style="clear: left"></div>
And here is the full test_header code from the testpage
http://www.volunteerforum.se/Minmapp/Te ... header.zip
Volunteer Forum Community
CSS and Javascript aren't my areas of specialty I'm afraid. Grinch knows CSS though, possibly he will know the answer :)
Leon
Aha.. ok..
well lets see what he says then
(If he says something at all)
This new header has taken ALOT more time to create
then i tought it would...
BTW battye what colour is the Drop Down list for you ?
(Dont say it is white plxor) :wink:
Attached
Leon
As i have seen and heard its ONLY the main text that gets white for some ppl..
The submenu is not affected at all
Leon wrote:As i have seen and heard its ONLY the main text that gets white for some ppl..
That's what I see *see above*
Leon
As i said the submenu is not affected for you eighter.
Only the main text for the menu, that is white for you is affected :(
.headerlinks a{
margin: auto 9px;
font-weight: bold;
color: white;
color: white turns your text white. Try using a different color.
Leon
Yep that was the problem, but why the *beeping* was it blue in
explorer and maxton then as it should have been :?
Well i have changed it.
Is it blue for you now battye ?
Thanks grinch2171 :D
Yep, blue for me now.
As for it not working in Internet Explorer, I can say that next to nothing works in Internet Explorer :lol:
When I have done things in CSS (which as I said above is very limited) IE has always been a hurdle.
Leon
battye wrote: As for it not working in Internet Explorer, I can say that next to nothing works in Internet Explorer :lol:
But it did work in explorer. and Maxton the only once they worked in..
So in this case explorer worked better then firefox 8)
It has to do with how FireFox and IE interpret CSS. If you need to change the background use background-color: white or just background: white
FF is more standards compliant than IE6. So I usually design for FF and then apply "hacks" to make it work in IE6. IE7 is better but no where near where it should be.
Now I noticed that in FF you navigation gets bunched up and in IE it is spread out.
Looks llike you already fixed the bunch up.
Leon
Yes i have found out that i do have some kind of bug still
insted of going in a row:
•Portal •Forum Navigation User Menu
Sometimes it gets like this instead:
•Portal
•Forum
Navigation
User Menu
etc. and messing up the layout :?
Its like once every 15-20 times or so
