Hi,
When I installed the MOD it worked really well.
Now I get the following message :
Warning: file_get_contents(http://search.msn.com/results.aspx?q=Si ... &FORM=QBRE): failed to open stream: HTTP request failed! HTTP/1.0 403 Forbidden in /home/sindo/public_html/phpbbforum/admin/admin_search_results.php on line 60
The results for Google, Altavista and Yahoo display ok.
Any ideas ?
Thanks,
Karen
Search Results MOD
karenthaibsyah
- Greenhorn
Create a page in notepad with the following contents:
Save it as fgc.php and upload it to your site, and then run the file. Do you get the same error?
echo file_get_contents('http://search.msn.com/results.aspx?q=Sindo+Self+Defence&FORM=QBRE');
?>CricketMX.com in 2022: Still the home of bat's, rat's and other farmyard animals!
karenthaibsyah
- Greenhorn
The error I now get is :
Warning: file_get_contents(http://search.msn.com/results.aspx?q=Si ... &FORM=QBRE): failed to open stream: HTTP request failed! HTTP/1.0 403 Forbidden in /home/sindo/public_html/fgc.php on line 2
I think it is a problem on MSN's side, it isn't the MOD.
karenthaibsyah
- Greenhorn
I did wonder if that might be the case.
Many thanks for your help.
Cheers,
Karen
Cheers,
Karen
