Allow users to play only one time per day
Istrien
I want to change the quiz to let users only play the quiz one time a day. I dont want that users solve it too quickly.
How can I make that? :wink:
You can allow them to play a quiz once in total (found in Quiz configuration) but not once a day.
FrEaKmAn
Should users only be able to play each quiz once?
I have this on yes but it doesn't work..
There are no other settings on which could be overiding the play once setting?
FrEaKmAn
sorry my bad, it seems to work for other users but not for me, admin..so everything is fine..
FrEaKmAn
I have one more problem
option:
Enter all users which you wish to have quiz moderator status (move, edit, delete quizzes).
Separate user id's with commas!
How to separete them with commas, can you explain me this...
A comma is: ,
eg: 2,3,4,5,6,7
FrEaKmAn
hm I just set one user which is mod on the forum but it doesn't work, and idea??
FrEaKmAn wrote:hm I just set one user which is mod on the forum but it doesn't work, and idea??
They aren't banned?
FrEaKmAn
no...
FrEaKmAn
have you anymore ideas because I really need this..
When you visit the ACP -> Quiz section, do you see the banned users, or does it simply not update?
FrEaKmAn
no banned users, I set the users nick and when he tries it to submit quiz, it says only quiz moderators...
Sorry, I meant to say quiz moderators. Does the database update, or everytime you load the quiz section of the ACP, the user id's you entered as quiz moderators do not show (blank field).
If it is not blank, please paste the contents of the field in your next post.
Thanks 8)
FrEaKmAn
I looked into db and everything is saved.
The blank field is filled with nick: Tester
