I have been using winmx for quite a while, but this week Ihave begun having problems. I hope someone can help!
P2P: WinMX
Problem: Will connect to network, but will not find files/download/upload
When It Started Happening: after we hooked up our wireless internet router
If You Have Installed Any New Software or Hardware: see above
If You Have A Firewall or Router: new wireless router on our home computer
Internet Connection: cable
Internet Service Provider: Time-Warner Cable
Operating System: Windows XP
Ram, Processor, And Other Computer Information: Ram=512, Processor=Pentium 4
Other: help??
WinMX Won't Search, Download or Upload
If it happened directly after you installed your router, then it is most likely your router.
There is a good article regarding how to fix connection problems here.
Hope that helps!
Hope that helps!
- Red XIII
- Sultan Ruler Of The Poles!
Road Runner tries to block WinMX a lot...set the ports you're running WinMX through as
TCP: 120
UDP: 80
or it's the other way around...that should fix everything
TCP: 120
UDP: 80
