first of all thanx to anyone who is willing to help me...ok on with my issue
i resently booted up my computer and loged on to my account...and i found out that my internet shortcut wasn't working...so i check it out in the control panel and i was looking for the internet connection there but i found out that it no longer existed ...but i have never deleted the connection..so now i can't log on the internet easly so i have to do some other steps..that i don't need to EXPLANE....so..thats one problem the other one is that i can't turn on the windows firewall ..nor i can't use Help and Support well here is a pic of was i get when i want to open up Help and support i don't even know wa they mean by system service so if any one know's my problem plez help me out...thanx...
[/img]C:\Documents and Settings\Alberto\My Documents\My Pictures\help and suppor error.JPG
Problem with my WinXp Sp2 ....<<need help!!!!!!!!
- Sureno_5outh~T3x~WeSlAcO
- A Forum Addict
- help and suppor error.JPG (12.41 KiB) Viewed 3843 times
Hi Sureno , sorry for the delay I was looking for this good link that I often use when I have a Services Problem
http://www.theeldergeek.com/services_guide.htm
If you jump past the first three blocks of text (warning) boxes and on to here, you can see where to go to restart your dysfunctional Help And Support Service.
I hope that helps you restore the setting back to normal.What are services? By definition, it's a program that runs invisibly in the background. But can't the same thing be said for a number of programs that run in the background such as anti-virus programs? Yes, but the real difference is that services load and start running whether or not anyone logs into the computer, unlike a program that is launched from the Startup Folder under All Programs.
There are two ways to view Services on your computer. The first is to use the MS Configuration Utility by typing msconfig.exe in the Run box accessed via the Start Menu, followed by clicking the Services tab. If you want a quick visual of which items are running or stopped, this is fine, but the information is limited. The preferred way to make changes to services is to launch services.msc from the Run option on the Start Menu. The Services window will open.
- A Forum Addict
ALRIGHT that fixed my problem..thanx...silver
The preferred way to make changes to services is to launch services.msc from the Run option on the Start Menu. The Services window will open.".....<<was the one that fixed my problem.............thanx for you time..silver..and see you later in Winmx Cricketmx room..
IM BACK for a day or two ...lol
Check out my Deviantart Page
http://www.vyrus956.deviantart.com
[center]
[/center]
[center]
[/center]
[center]
[/center][center]
[/center]- John Riddler
- Miracle Worker
- Location: I come from a place were there is a saying, and it goes "From here on there be Dragons"
that error sounds like one of the old ones...
"windows could not find a keybored, press F1 to continue"
- Know-It-All
thats a BIOS error during the POST, not a Windows error...
The windows one is:
"A Mouse was not detected, click OK to continue"
The windows one is:
