quicksilver wrote:h,mm cant say i agree completely with you two on this issue. i find it invaluble to be able to check that the person i,m about to admin is who they say they are. also i have never experienced a collapse of the room due to using the printuserlist. this obviously is a personal choice matter mentioned above with regard to #r#n, the printuser works on the same peice of code ...
I removed it bc of personal reasons, and it is not unlike me to not consider that many do not run rcms in the manner i do.
However if you have a high volume of traffic and run channel for a long time. It is very common for list to get very buggy. And a printuserlist command can easily crash channel.
Just as a large # of admins can do same thing. And since my channel runs 90+% of the people in channel as admin, well it has been an issue for a long time, so we always remove them.
as far as hasleft, nickname etc, its easy enough to get in twice with nushi to see who is using them. And if there is a problem kick the offending party.
