Hi Zorro, I am working on adding the categories to the ACP as I write this
Lugsciath: thank you for the post and your PM. I am not sure why you are having trouble with the save quiz feature, nobody else has reported any problems with that feature. I will have another look at it though and see if I can see any problems, thanks
Hmm, I've hit a snag with the ACP. I wanted to simply have the quiz settings in the board features area, but I think (to get the category admin part to work correctly) I might have to create a new ACP module which I've never tried before.
- quahappy
- Happy, not Quappy
Does this mean one modules for UQM general configuration and another for category management? If I could help, I would, unfortunately i know nothing on how to create new modules. Of course, we'll all be on hand to beta test where possible.
As I said on phpBB.com I set some time aside today to do the ACP. I've written the files, but when I try and create the module I'm running into a brick wall
For some reason I'm not getting a ".MODs" tab in the ACP which is a bit strange, but I'm investigating...
I could not get to sleep and was thinking about this. When I was going through a file structure of Calendar MOD, I remember very simple way the files for ACP were created, and in fact, if you plan two pages, one CONFIGURATION and other CATEGORIES, then for CALENDAR Mod there was close to it or maybe same structure of ACP files...and please don't give up battye!battye wrote:I've written the files, but when I try and create the module I'm running into a brick wall![]()
Hi raabis, thank you for your support. Also, thank you for your PM on phpBB.com. I will try Lugsciath's suggestion (thanks Lugsciath
) when I get the chance (fortunately as of this week things are no longer as busy for me), regardless of that I will send the files to you soon raabis
any new news of the progress?
Is it possible to send me alpha version? thanx
hello Battye , you have a change ?
Is it possible to send me alpha version , with the tables ?
thanx
thanx
