WCS - Chat server
WCS 1.8.3 released
I have released 1.8.3, this contains a potentially major bug fix and as such it is recommended that you update immediately.
Changes since 1.8.2:
Added /gnotice command (G access) to send group notices
Added colour support to opmsg (only in text, not names, so messages continue to stand out)
Added space back to beginning of multi-line text (it wandered off in a previous release, added it back again)
Removed check for WPN connection hacks
Fixed potentially major buffer overflow vulnerability
Fixed bug with sometimes not loading port from config
Fixed memory leak with multi-line text
/gnotice allows you to send a notice to everyone with a certain access level, this can be useful to send it to only a select group of admins for example. Note that for the purposes of this command * does not mean every access level, and * access will not let you see the notice unless you also have the other access level the notice is directed at.
Download WCS @ http://wcs.mxstuff.org/?download
http://www.mxstuff.org/ is back online. :)
Last edited by p2p-sharing-rules on Fri Jun 13, 2008 4:33 am, edited 7 times in total.
WCS 1.8.3.1
Release Date: April 9, 2011
This release fixes a problem where WCS won't stay connected when exposed to certain deliberately crafted network traffic & will overcome the current issue with it.
Many thanks to KM for his patience in talking me through the minor edits required in the source and his help with overcoming the problems I introduced by using a more recent compiler version.
For the paranoid among you ( I know many don't trust KM ) these were very minor edits, which couldn't have introduced any hidden "nasties", even with my very limited ability I could see that.
Windows
wcs-1.8.3.1-win32.zip
(61.52 KiB) Downloaded 1907 times
Linux
wcs-1.8.3.1-linux.gz
(55.77 KiB) Downloaded 2136 times
Example Config File.zip
(708 Bytes) Downloaded 1940 times
Country Database ipdb.zip
(554.53 KiB) Downloaded 1898 times
