To edit, simply click it (the name of the category or subcategory)
Ultimate Quiz Mod
I haven't added a feature to delete yet
I have this error ... any idea ???
Cannot update view counter
DEBUG MODE
SQL Error : 1064 You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 3
UPDATE phpbb_quiz SET quiz_views = quiz_views + 1 WHERE quiz_id =
Line : 112
File : quizzer.php
Great .. Great Mod ... realy , are there any way to don't make always the first question always the right question ???
thx .. great job ..
EDIT :
I can solved , changing ..
to
Is this OK ??? , work now , but i know if it's ok
Plus , I find a mising var in lang_admin.php ----> $lang['guest_cant']
Thx again
EDIT 2 : I solved the problems with always the right anwser is the first choice
i need to add ...
srand((double)microtime()*1000000);
at the begining of viewquestion.php to initializate random uses with suffle() funtion , i guest my php version in my hosting company is older than v4.2
Thx
DEBUG MODE
Line : 112
File : quizzer.php
thx .. great job ..
EDIT :
$vchundred = "UPDATE " . QUIZ_TABLE . "
WHERE quiz_name = ' . $page . ;
WHERE quiz_name = '" . $qnm . "'";
Thx again
i need to add ...
Thx
It's been a while since I've updated this post, basically I am not adding more features until the second major release.
So far I have added the following:
Please tell me so I can add it to the list
- Current Features
Index Page - Link to quizzes
- Categories
- Statistics
- Page Views For Completed Quizzes (Not on a per question basis)
- Author
- Link to Random Quizzes
Playing The Quiz - 4 Multiple Choice Answers
- Shuffled
- Layout (by Xusqui)
- Incorrect / Correct answers after playing
- Indepth statistics about how you went
- DHTML Statistics Drop Down Box
- Pagination
- Cash Rewards
- New Redirection Engine
- Image Support
- Time Limit Feature
- Admin's can delete or edit quizzes
- Optional feature so the Quiz doubles as a survey
- Ability to play a quiz picked at random from the database
Adding Quizzes - Questions
- Fakes / Answer
- Quiz Name
- Image Support
Admin Panel - Quiz Configuration
- Category Admin
- Configure cash / points settings
- Verify Quizzes
Statistics - Modules
- TPL Files
- Drop down statistics box when viewing quiz
- Optional surveys
