HTML usergroup
I'm tossing up between Appalachia and SubSilver...
I'll do whatever you decide to do, you're the one making it 8)
I think subsilver would probably be a good default. All I need is all the homepage's so I can set it up. Part of the script I posted has to be loaded to the server so I guess you will take care of that part. Everything else is just cut and paste into the homepage's. I figured I would make it available on all of them just in case. I would hate for someone to get stuck with a theme they don't like just because of the cookie. I suggest you check out http://www.ozzu.com, it is a vast resource for webmasters. It is one of the best forums I have run across with some very knowledgeable people.
Yeah, I'll upload everything you need... I can't wait to see the end product :D
Same here, I should be able to have it done this weekend. Which theme did Boozy do? You did the igloo one and I did appalchia and will be done Silver Xire, who did subsilver? I need that page so I can edit this little tweak into it.
I made SubSilver, that was the original one. Boozy tweaked mine a bit and added the Google thing. I also made Igloo which is sitting on a Floppy Disc (Yeah I know :oops: ) right next to me. And you made Appalachia. I don't mind working on Solaris, which I have re-uploaded. And if you're making Silver Xire we're set!
The original SubSilver one is located at http://www.battye.jmstacey.net :)
Should the google thing be universal among all the homepage's? If so we need to get that script from Boozy so we can put it on all the homepage's.
I tested it, using "Domain Search" and it search a domain... just not mine. It was searching the Google domain :?
So is that a no then?
I'll go and find out the code, then I'll PM it to you 8)
Sorry mate, I tried to View Source but it wouldn't display... Do you think we should just leave the Google Add-On for the default SubSilver page?
Works for me, it's your site man, I'm just here to help.
And you're doing a damn good job too :D How's that drop down thing coming along?
I'm at work, so I am not working on it. I just entered the source code into notepad just to see what it would look like. I wish I had FP on this computer but I am not allowed to install it. Oh well. I'll work on it this weekend when I get some free time.
Ok, sounds good :)
