µTorrent
µTorrent 1.8.4
August 17, 2009
µTorrent 1.8.4 Changelog thread.
µTorrent 1.8.5
Release date: Nov. 2, 2009
µTorrent 1.8.5 Changelog thread.
Download link
utorrent 1.8.5.17414.exe
(282.75 KiB) Downloaded 1811 times
Last edited by p2p-sharing-rules on Wed Feb 10, 2010 4:32 pm, edited 4 times in total.
Reason: I uploaded µtorrent 1.8.5.17414.exe because the newer version is banned from one of my private torrent sites. I recommend that you check if v2.0 is banned from your private torrent sites before updating to it.
uTorrent has been pestering me for a few days to update now... I guess I better do it...
once these downloads finish ;)
µTorrent 2.0
Release date: January 25, 2010
µTorrent 2.0 released
A Kinder, Gentler µTorrent 2.0
µTorrent alpha 0.9.3 (Mac)
Release Notes
µTorrent 2.0.1
Release date: April 23, 2010
µTorrent 2.1 released
µTorrent alpha 0.9.3 build 19223 (Mac)
Release date: April 22, 2010
Release Notes
µTorrent 2.0.2
Release Date: May 13, 2010
µTorrent 2.0.2 released
µTorrent beta (0.9.3 build 19343) (mac)
Release Date: April 30, 2010
uTorrent Expands, Launches Apps and Labs
The uTorrent team has released a new version of the BitTorrent client that supports extensions, or apps as they call them. The new version, codenamed Griffin, is part of the new uTorrent labs where users will get early access to new projects, including live streaming (Pheon) and remote access (Falcon).
Thanks for all of the updates P2P, I have finally gotten around to updating to the newest Mac version of uTorrent. It looks really nice too, it's all split into tabs and has a different interface and now has a download/upload speed graph :)
I split my connection between 3 people and one of them was getting slow download speeds in utorrent, I suspected it was uTP and I googled how to disable uTP to see if it was the problem. It was the problem because after I disabled it his downloads went faster. He's using v2.0.2.
To disable uTP, go to Options > Preferences > Advanced and set bt.transp_disposition to 5.
Then go to Options > Preferences > BitTorrent and uncheck Enable Bandwidth Management.
Another thing I read is if you disable uTP you won't be able to connect to other users that use uTP.
I found this info on utorrent's forum.
bt.transp_disposition: This option controls µTorrent's level of bias towards using TCP or uTP for transporting data (assuming the peer at the other end of the connection supports both transport protocols). The following is a list of the accepted values:
1 allows µTorrent to attempt outgoing TCP connections
2 allows µTorrent to attempt outgoing uTP connections
4 allows µTorrent to accept incoming TCP connections
8 allows µTorrent to accept incoming uTP connections
16 tells µTorrent to use the new uTP header. This is an improved communication header, but is not backwards compatible with clients that do not understand it.
This option is interpreted as a bitfield, so values can be added together to obtain a combination of behaviors. Setting this value to 255 guarantees that all behaviors are enabled.
p2p-sharing-rules wrote:I split my connection between 3 people and one of them was getting slow download speeds in utorrent, I suspected it was uTP and I googled how to disable uTP to see if it was the problem. It was the problem because after I disabled it his downloads went faster. He's using v2.0.2.
Thanks P2P, if I experience it going very slowly I will give that a go. Strangely since upgrading it does seem to be downloading a little bit faster... in fact, I have noticed a significant delay in loading webpages while downloading a torrent. Normally that is a result of the upload speeds being maxed out and no bandwidth available. I suspect the upload speeds are being reported incorrectly (for instance, I always used to upload at 7-8kbps, now it is less than 1).
µTorrent 0.9.3.11 (build 19773)
Release date: May 24, 2010
Changes in 0.9.3.11
* Fix: When external drive with the download directory is not connected, do not create the missing directory in /Volumes.
* Fix: Fixed deleting non-torrent files when dropped on application window.
* Fix: Sort order no longer randomly changes when sorting on fields other than name.
* Added create torrent dialog.
* Fix: Shutdown bug that cancels computer shutdown when the quit dialog is disabled.
You're welcome Battye.
µTorrent Stable (1.0)
Release date: June 28, 2010
µTorrent Mac 1.0 Stable Release
Changes in 1.0.0.1 (20277)
* Fix: Create torrent
* Fix: Adjusted uTP protocol packet scaling.
Changes in 1.0.0.0 beta (19873)
* Client promoted to release
* Fix: Creating directories on external drives now fixed.
FINALLY!
I had it download to my external hard drive about a year ago, and it was disconnected soon after. Ever since it's been eating up space on my internal hard drive in /Volumes/, compounded by the fact that it's hard to find the directory in order to delete the files (I think the only way is to open uTorrent, right click a file and click Open in Finder).
:D :D :D
µTorrent 2.0.3
Release date: July 22, 2010
µTorrent 2.0.3 released
µTorrent 2.0.4
Release date: August 28, 2010
µTorrent 2.0.4 released
There is a DLL vulnerability in all versions of Windows affecting a great deal of software applications. Subsequently, attack code targeting the μTorrent client surfaced on a third-party website, and while so far no attacks have been reported to us, we have released μTorrent 2.0.4 to fix this vulnerability. The new client disables loading of DLLs from the current working directory and prevents this exploit from functioning. More information about the exploit can be found here:
http://www.reuters.com/article/idUS2168761020100825
µTorrent 1.0.1 (22592)
Release Date: Oct. 14, 2010
Changelog
Fix: Clicking on magnet link in the browser adds the torrent after launching uTorrent.
Fix: Deleting torrent data should only delete files and directories belonging to the torrent.
Fix: UserAgent now sent correctly in HTTPS requests.
Change: Dropped extra revision digit from version number.
