[Player] Winamp
garmabeaneth
Dancing Queen
Dancing Queen
bah.... the new Winamp never runs with my teknap script. i usually end up going back to an older version of Winamp
Sometimes when you cry... no one sees your tears.
Sometimes when you are worried... no one sees your pain.
Sometimes when you are happy... no one sees your smile.
But fart just one damn time ...
(¯`·._.·[GUEST 601]·._.·´¯)
smile you're on candid camera Image
Winamp 5.541
Download links can be found here.
What's new:
New! Now Playing: Discover Artist Songs, Videos, Radio and Photos
New! AOL Radio Powered by CBS Radio
New! Expanded Flash video support
New! Media Monitor: Playing music on the web just got even better
New! Language packs available in Chinese, Japanese and Korean
New! Updated Winamp toolbar - control Winamp from your browser
* Improved: [pmp_ipod] Better auto-detection of newer iPod models
* Fixed: Filetype icons in Windows Explorer not updating when changed in Prefs
* Fixed: ML & Vis appear under other overlapping modern skin windows
* Fixed: No error message when trying to edit metadata for Read-Only files
* Fixed: Potential security vulnerability in NowPlaying
* Fixed: [gen_ff] Keyboard shortcuts in modern skin playlist windowshade mode
* Fixed: [gen_ml] Scrolling to bottom of AlbumArt pane & other misc scrollbar issues
* Fixed: [in_mp3] Broken '307 - Temporary Redirect' url's
* Fixed: [ml_local] AlbumArt icon selection glitch
* Fixed: [ml_playlists] Play and Enqueue actions reversed if Enqueue is set as default
* Fixed: [ml_rg] ReplayGain analysis of 20bit files
* Misc: Double-click Modern pledit songticker now toggles windowshade mode again
* Misc: More miscellaneous general tweaks, improvements, fixes and optimizations
http://www.winamp.com/player
Changelog
Winamp 5.551
* Fixed: [libsndfile] CAF Processing Integer Overflow Vulnerability
* Updated: libsndfile 1.0.19
* Improved iPod Sync Support
* New iTunesLibrary Import
* New Online Services Gallery
* New OurStage Radio Online Services
* New Spinner MP3 of the Day Online Service
* New Turkish, Romanian, and Portuguese Language Packs
Winamp 5.55
* Fixed: New version check can't be disabled when anon statistics is enabled
* Fixed: Rare crash when closing vis window
* Fixed: Various issues when starting/stopping/switching vis plugins
* Fixed: [Agent] Systray icon not showing if 'Play in Winamp' removed in Shell Options
* Fixed: [enc_flac] 24-bit FLAC encoding
* Fixed: [gen_jumpex] Shell Options, B Hotkey, Send To menus & other misc bugs
* Fixed: [gen_ml] Library button resize glitch
* Fixed: [in_cdda] Potential cddb Disc null pointer crash
* Fixed: [in_flac] Albumartist & Ensemble fields not cleared when deleting Album Artist
* Fixed: [in_flac] Track restarts when updating metadata
* Fixed: [in_mp3] Potential ID3v2.0/2.1 crash issue
* Fixed: [in_mp4] Empty genre metadata field (eg. when transcoding from flac to m4a)
* Fixed: [in_mp4] Long hangs on slow network drives
* Fixed: [libsndfile] AIFF buffer overflow vulnerabilty (thanks milw0rm/secunia)
* Fixed: [ml_disc] Potential crash on exit
* Fixed: [ml_disc] 'Use uppercase file extensions' ripping option not being respected
* Fixed: [ml_history] Tracking still updates if playback stopped before specified time
* Fixed: [ml_local] Broken 'Create Playlist' button functionality in local media
* Fixed: [ml_local] Remove missing files broken with some older/corrupt databases
* Fixed: [ml_wire] Columns sometimes hidden in Downloads view
* Fixed: [ml_plg] Multiple 'Failed to initialize' error messages
* Fixed: [ml_pmp] Crash when deleting playlists/files from a P4S portable device
* Fixed: [ml_pmp] Metadata hooking, transcoder, autofill and other bug fixes
* Fixed: [nde] Albums with % in title not displaying tracklist in local media views
* Fixed: [out_ds] Logarithmic volume control dB display glitch
* Fixed: [pmp_ipod] Deletion of non-existent files from database
* Fixed: [pmp_ipod] Reading of Play Count statistics
* Fixed: [pmp_ipod] Various database, albumart, playback & disconnection issues
* Misc: New "Send Feedback" item in the Help menu
* Misc: Note that changes made to the ml database are not backwards compatible!
* Misc: Removed some older Milkdrop presets and added some newer ones
* Misc: Separated vlb.w5s and nsvdec_vp3.dll decoders from in_mp3 and in_nsv
* Misc: Separated timer from gen_ff into timer.w5s
* Updated: Gracenote CDDB/MusicID v2.6.0.6
* Updated: libpng 1.2.35
* Updated: Sonic Burning Engine v4.10.32.502
* Updated: [gen_jumpex] JTFE v1.0.4
* Updated: [in_mp3] Fraunhofer Decoder v4.3
* Updated: [lame_enc] LAME 3.98.2
* Updated: [vis_avs] AVS v2.82
Another update.
Winamp 5.552
* Fixed: [gen_ff] memcpy integer overflow vulnerability in maki script loading
Thanks Peter P. :)
Finally got around to it. IE8 and the new Winamp aren't very friendly to each other!! :shock:
You're welcome Moon. :)
That's not good. Hopefully Microsoft or Winamp will sort out the compatibility issues.
Changlog
Winamp 5.56
* New: Winamp Orgler plugin - Let's you track, chart & share your listening history
* Improved: [jnetlib] New SSL support for playback of https:// streams
* Improved: [ml_autotag] Fuzzy matches now unchecked by default & marked 'Unsure'
* Improved: [ml_local] New background scanner
* Improved: [ml_online] Various tweaks, fixes & enhancements
* Improved: [ml_pmp] Added support for drag+drop from Explorer to device playlists
* Fixed: iexplore process not ending when browser closed after opened via Winamp
* Fixed: Save EQ preset name duplication bug
* Fixed: [Bento skin] SHOUTcast homepage url's redirecting to Winamp search
* Fixed: [gen_jumpex] Up/down buttons reversed, 'stop after current' & other issues
* Fixed: [in_mod] Crash on some .s3m modules (w.i.p.)
* Fixed: [in_mod] Playback glitch during background transcoding
* Fixed: [in_wm] Decimal point issues in Alt+3 format info
* Fixed: [in_wm] Embedded IE browser for DRM license acquisition
* Fixed: [in_wm] Loading of URLs in WPL playlist files
* Fixed: [in_mp4/libmp4v2] Integer overflow bug with MP4 sample size
* Fixed: [libsndfile] VOC buffer overflow vulnerability
* Fixed: [ml_impex] Read "has video" field from iTunes XML (and write on export)
* Fixed: [tagz.w5s] Hang with $right function in ATF when specified field is empty
* Fixed: [vis_avs] msvcp71.dll dependency
* Misc: Added front.jpg/gif/etc to album art criteria
* Misc: New omBrowser.w5s shared component for ml_nowplaying, wire & online
* Misc: Removed dashboard (ml_dash) from distribution
* Misc: ml_orb now only installed as part of separate Winamp Remote package
* Updated: [gen_jumpex] JTFE v1.0.5
* Updated: libsndfile 1.0.20
I was looking to install Winamp on here and found out there's a new version out.
More info is available about its release here: Winamp 5.57 is Now Available!
http://www.winamp.com/media-player
Winamp v5.581
changelog link
