Hello,
fr translation is done and available here
http://arcadesetjeux35.forumsfaciles.co ... 9845#p9845
if there is a translation problem thank you for letting me know so I change the files.
I can't access that link Clenzowen
I did not check the permissions of the forums.
I have not added any online files indicating having en translations do not worry lol
The message is now available Battye
The forum is also accessible to guests so feel free to give me one or translation errors that I corrected that.
Livirathon
- Greenhorn
yes, it's work! but i use "Edit or Delete" they will change back "?????"battye wrote:Ahhh, the foreign characters always get me
The fix mainly consists of adding a "true" parameter at the end of the request_var function.
CATEGORIESCode: Select all
--------------OPEN includes/acp/acp_quiz.php-------------------- -----------FIND---------------- // Now do the actual update, fix up the category name first. $category = utf8_normalize_nfc( $db->sql_escape(request_var('category_name', '')) ); -------------REPLACE WITH------------- // Now do the actual update, fix up the category name first. $category = $db->sql_escape( utf8_normalize_nfc(request_var('category_name', '', true)) ); ---------------FIND--------------- if( !check_form_key('uqm_category') ) { trigger_error($user->lang['ACP_UQM_QUIZ_FORM_INVALID'] . adm_back_link(append_sid("{$phpbb_admin_path}index.$phpEx?i=quiz&t=add_category"))); } $category = utf8_normalize_nfc( $db->sql_escape(request_var('category_name', '')) ); ---------REPLACE WITH------------ if( !check_form_key('uqm_category') ) { trigger_error($user->lang['ACP_UQM_QUIZ_FORM_INVALID'] . adm_back_link(append_sid("{$phpbb_admin_path}index.$phpEx?i=quiz&t=add_category"))); } $category = $db->sql_escape( utf8_normalize_nfc(request_var('category_name', '', true)) );
EDIT: here are the fixes for adding/playing quizzesCode: Select all
---OPEN quiz.php--- ---FIND--- $check_correct = $quiz_configuration->check_correct_checked($current_questions); // see if the user has left any empty $quiz_name = request_var('quiz_name', ''); ---REPLACE WITH--- $check_correct = $quiz_configuration->check_correct_checked($current_questions); // see if the user has left any empty $quiz_name = request_var('quiz_name', '', true); ----OPEN includes/quiz/quiz_question.php---- ---FIND--- for($i = 0; $i < request_var('question_number', 0); $i++) { $question_name = request_var('question_name_' . $i, ''); $answers_name = request_var('answers_' . $i, ''); $multiples = explode("\n", $answers_name); $correct = request_var('answer_' . $i, ''); ---REPLACE WITH--- for($i = 0; $i < request_var('question_number', 0); $i++) { $question_name = request_var('question_name_' . $i, '', true); $answers_name = request_var('answers_' . $i, '', true); $multiples = explode("\n", $answers_name); $correct = request_var('answer_' . $i, '', true);
Then run these SQL queries to convert the database tables to utf8_bin (by default they are collated in latin or something, which is another thing that will be rectified with UMIL...)
----DATABASE---- ALTER DATABASE `phpbb_quiz` DEFAULT CHARACTER SET utf8 COLLATE utf8_bin; ALTER DATABASE `phpbb_quiz_categories` DEFAULT CHARACTER SET utf8 COLLATE utf8_bin; ALTER DATABASE `phpbb_quiz_questions` DEFAULT CHARACTER SET utf8 COLLATE utf8_bin; ALTER DATABASE `phpbb_quiz_statistics` DEFAULT CHARACTER SET utf8 COLLATE utf8_bin;
Edit 2: screenshots of foreign characters working + the quiz play once setting below. I also found a bug whereby if the "show answers" config setting is disabled, then no quiz statistics are stored - that's fixed now
another question (not bug)
if i wan show the question is
A「かわいい いぬですね。」
B「ええ、わたしたちと あそべると おもって( )。」Code: Select all
A「かわいい いぬですね。」B「ええ、わたしたちと あそべると おもって( )。」-
thewebmaster
- Greenhorn
Hey this seems to really a nice module. I have never tested this or seen this in action but it is looking cool.
I just want to call the quiz on external page and also the stats of the results on again on external page. Is that possible with this mod.
Also Can I have a copy to install the things on my forum and give you the test results.
I'm not sure what you mean by calling it on an external page, but most of it is contained in classes (there is a quiz_statistics class, for instance) so including data on an external page shouldn't be overly difficult. If you can describe what you mean I could give you a better answerthewebmaster wrote:Hey this seems to really a nice module. I have never tested this or seen this in action but it is looking cool.
And not a problem, I am PM'ing you with the link right now
Welcome to CMX thewebmaster
thewebmaster
- Greenhorn
Thanks, for the PM, received that.
Wondering about the installation instructions there but I am trying to do this from my end.
External page I explained in the PM as well. I simply mean calling a quiz and the results on a page outside the forum directory.
Regards,
Aka
Regards,
Aka
thewebmaster
- Greenhorn
Uploaded all the files from root dir to my forum ran the quiz_installer.php
everything went smooth and installation was successful. But I can not see the quiz or any other related Tab inside the admin panel.
Also can you help me with one thing my bgcolor is not coming up
http://sports.webhostie.com/forums/
thewebmaster, to install the ACP module you need to do this (this was listed in the MODX instructions):
I still don't know what you mean by calling a quiz page or poll, do you mean just linking to it or actually displaying it and having it work as a fully functional feature outside of the forum structure? An example of what you mean would be beneficial, thanksTo install the module, do this: "ACP -> System -> Module Management -> Administration Control Panel -> and select "Quiz" from the "add module list" on the bottom right."
Good evening,
I wanted to install the mod on my new quiz forum.
When I wanted to launch "quiz_installer.php" I had the following general error, or it may come in please?
can you help me please, thanks
SQL ERROR [ mysql4 ]
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '('qc_cash_correct', '50', 1), ('qc_cash_incorrect', '150', 1)' at line 10 [1064]
SQL
INSERT INTO phpbb_config (config_name, config_value, is_dynamic) VALUES ('qc_minimum_questions', '2', 1), ('qc_maximum_questions', '5', 1), ('qc_maximum_choices', '5', 1), ('qc_show_answers', '0', 1), ('qc_quiz_author_edit', '0', 1), ('qc_admin_submit_only', '0', 1), ('qc_cash_enabled', '0', 1), ('qc_cash_column', 'user_points', 1) ('qc_cash_correct', '50', 1), ('qc_cash_incorrect', '150', 1)
BACKTRACE
FILE: includes/db/mysql.php
LINE: 175
CALL: dbal->sql_error()
FILE: quiz_installer.php
LINE: 74
CALL: dbal_mysql->sql_query()WalterFD: Open up (in Notepad) quiz_installer.php and remove this code:
Then after executing the script, make sure you remove the file otherwise anyone can access it
Clenzowen: sorry for the delay
If you look inside phpbb_config, are the rows already there?
if( !$auth->acl_get('a_') )
trigger_error('UQM_INSTALLING_ADMIN_ONLY');
}Clenzowen: sorry for the delay
please, Sent to me file for 2.1.1?
I have v2.1.0 Alpha 1
thanksssssssssssss
thanksssssssssssss
Not a problem plasmino, I've sent you a PM
thanks, installed with not problem
italian language file
- it.zip
- (3.65 KiB) Downloaded 721 times
