Stef67
Excuse me :oops:
When I want to change some quiz I can not change the title, the questions do not appear.
Here is a picture to better understand
This quiz may be amended
This not because the issues do not appear
What are you doing differently to get:
Image[/quote]
Instead of
Is the "questions not appearing" only happening for some quizzes?
Lugsciath
German translations
quiz_link.php
* Ultimate Quiz MOD [English]
* Thanks to mtrs for recommending the creation of this file
* @package language
* @version $Id: quiz_link.php, battye (c) 2004, 2005, 2008, 2009
* @copyright (c) 2009 battye, CricketMX.com
* @license http://opensource.org/licenses/gpl-license.php GNU Public License
* DO NOT CHANGE
if (!defined('IN_PHPBB'))
	exit;
if (empty($lang) || !is_array($lang))
	$lang = array();
$lang = array_merge($lang, array(
	// ACP
	'QUIZ' 					=> 'Quiz',
	'QUIZ_EXPLAIN' 			=> 'Ultimate Quiz MOD',
quiz.php
* @package language
* @version $Id: quiz.php, battye (c) 2004, 2005, 2008
* @copyright (c) 2008 battye, CricketMX.com
* DO NOT CHANGE
	exit;
	$lang = array();
// DEVELOPERS PLEASE NOTE
// All language files should use UTF-8 as their encoding and the files must not contain a BOM.
// Placeholders can now contain order information, e.g. instead of
// 'Page %s of %s' you can (and should) write 'Page %1$s of %2$s', this allows
// translators to re-order the output of data while ensuring it remains correct
// You do not need this where single placeholders are used, e.g. 'Message %d' is fine
// equally where a string contains only two placeholders which are used to wrap text
// in a url you again do not need to specify an order e.g., 'Click %sHERE%s' is fine
 'QUIZ' => 'Quiz',
	// Various
	'QUIZ_MUST_BE_LOGGED_IN' 		=> 'Du musst registriert und eingeloggt sein um diese Seite zu sehen.',
	'QUIZ_MUST_ADMIN_USER' 			=> 'Nur Administratoren haben hier Zugriff.',
	'QUIZ_USER_EDIT_OWN'			=> 'Als Benutzer kannst du nur dein eigenes Quiz editieren',
	// Functions
	'SELECT_A_CATEGORY'				=> 'Wähle eine Kategorie',
	'SELECT_A_CATEGORY_EXPLAIN'		=> 'Wähle eine Kategorie welche das Genre vom Quiz am Besten trifft.',
	// Submit quiz
	'SELECT_NUMBER'					=> 'Anzahl der Fragen',
	'SELECT_NUMBER_EXPLAIN'			=> 'Du darfst zwischen <strong>%1$s</strong> und <strong>%2$s</strong> Fragen in diesem Quiz stellen. Wieviele Fragen sollen gestellt werden?',
	'SUBMIT_STEP_1'					=> 'Stufe 1 von 3 - Gib dein Quiz ein!',
	'SUBMIT_STEP_2'					=> 'Stufe 2 von 3 - Gib deine Antworten ein!',
	'SUBMIT_STEP_3'					=> 'Stufe 3 von 3 - Prüfe ob alles korrekt ist!',
	'SUBMIT_QUIZ' 					=> 'Quiz beitragen',
	'SELECT_QUIZ_NAME' 				=> 'Wähle einen Namen für dieses Quiz',
	'SELECT_QUIZ_NAME_EXPLAIN'		=> 'Das ist der Name der in der Liste der Quizze erscheint. Wähle einen Namen der kurz genug ist aber der Lesern einen Eindruck davon gibt um was es im Quiz geht.',
	'ENTER_QUESTION'				=> 'Gib deine Frage ein',
	'IS_TRUE_FALSE'					=> 'wahr oder falsch Frage',
	'MULTIPLE_CHOICE_QUESTION'		=> 'Mehrfach Auswahl Frage',
	'INPUT_ANSWER_QUESTION'			=> 'Eingabe Antwort Frage',
	'MULTIPLES_REVEAL'				=> 'Mehrfachrahmen',
	'NOT_TRUE_FALSE'				=> 'Trenne die Mehrfachauswahl durch Hinzufügen einer neuen Mehrfachantwort auf einer neuen Zeile. Für ein nur Eingabequiz, einfach nur eine einzige Textzeile eingeben.',
	'SUBMIT_INFORMATION'			=> 'Gib Fragen in jeder der nachfolgenden %1$s Felder ein. Für wahr und falsch Fragen, klick die Checkbox zum Beispiel - es muss dann nichts in die Box eingegeben werden. Wenn du die Fragen des Quiz eingibst, gib einfach die Antwort in die grosse Box ein. Für Mehrfachantworten musst du %2$s Alternativen eingeben, jede in einer neuen Zeile. Du wirst nach der richtigen gefragt, die du nach dem Absenden dieser Seite auswählen sollst.',
	'VERIFY_SUBMIT_INFORMATION' 	=> 'Für Mehrfachantworten wähle die richtige durch anklicken der box an der linken Seite. Für wahr und falsch Antworten wähle statt dessen wahr oder falsch. Eingabe Antworten müssen nicht geprüft werden, sie werden so genommen wie sie sind.',
	'FINAL_VERIFY_SUBMIT'			=> 'Bitte prüfe alle Eingaben, wenn alle richtig sind klicke auf Absenden unten.',
	'TRUE_FALSE_TRUE'				=> 'Wahr',
	'TRUE_FALSE_FALSE'				=> 'Falsch',
	'CORRECT_ANSWER'				=> 'Richtige Antwort',
	'QUIZ_SUBMISSION_SUCCESSFUL'	=> 'Dein Quiz wurde erfolgreich in die Datenbank übernommen.<br /><br />%sZurück zur Quiz Index Seite.%s',
	'OUTSIDE_QUESTION_PARAM'		=> 'Du hast keine Nummer zwischen <strong>%1$d</strong> und <strong>%2$d</strong> gewählt, geh zurück und versuche es nochmal.',
	'NUMBER_QUESTIONS_UNDEFINED'	=> 'Die Nummer von Fragen in diesem Quiz ist nicht angegeben, bitte geh auf die vorherige Seite und korrigiere dies.',
	'TOO_MANY_CHOICES'				=> 'Eine oder mehrere von deinen Mehrfachauswahlfragen besitzt <strong>mehr als %s</strong> Auswahlmöglichkeiten! Bitte entferne darüberliegende Auswahlen.<br /><br />',
	'EMPTY_QUESTION'				=> 'Du hast eines oder mehrere Fragefelder leergelassen! Klicke den Zurückbutton in deinem Browser um auf die vorherige Seite zurückzukehren und stelle sicher das keine Felder leer gelassen werden.',
	'EMPTY_ANSWER'					=> 'Du hast eines oder mehrere Antwortfelder leergelassen. Klicke den Zurückbutton in deinem Browser um auf die vorherige Seite zurückzukehren und stelle sicher das keine Felder leer gelassen werden.',
	'EMPTY_QUIZ_FIELDS'				=> 'Du hast einige Felder leer gelassen! Stelle sicher das alle Felder richtig ausgefüllt werden.',
	'EMPTY_RADIO_BOX'				=> 'Du hast eine oder mehrere radio Auswahlen nicht ausgewählt, das bedeutet, das du immer noch eine Mehrfachauswahl und/oder wahr falsch Antwort auswählen musst, <strong>oder</strong> du hast keinen Quiznamen oder Kategorie ausgewählt.',
	'QUIZ_ADMIN_SUBMIT_ONLY_ERROR'	=> 'Nur Administratoren können Quizze beisteuern',
	// Index
	'QUIZ_PASSWORD_PROTECTED_CAT'	=> 'Ein Password wird für die Kategorie benötigt',
	'VIEW_QUIZ_CATEGORIES'			=> 'Wähle eine Kategorie',
	'NUMBER_OF_QUIZ_INDEX_SINGLE'	=> '%d Quiz',
	'NUMBER_OF_QUIZ_INDEX_PLURAL'	=> '%d Quizze',
	'NUMBER_OF_QUIZ_VIEWS_SINGLE'	=> '%d Betrachter',
	'NUMBER_OF_QUIZ_VIEWS_PLURAL'	=> '%d Betrachter',
	'QUIZ_NAME'						=> 'Quizname',
	'QUIZ_AUTHOR'					=> 'Autor',
	'QUIZ_DATE'						=> 'Beitragsdatum',
	'QUIZ_VIEWS'					=> 'Betrachtungen',
	'QUIZ_IN_PROGRESS'				=> '(gesichert)',
	'QUIZ_IN_PLAYED'				=> '(gespielt)'
	// Play quiz
	'PLAY_QUIZ'						=> 'Spiel Quiz',
	'QUIZ_SAVE'						=> 'Sichere Quiz',
	'QUIZ_TIME_REMAINING'			=> 'Zeit verbleibend (Sekunden)',
	'QUIZ_NO_TYPE_SUBMIT'			=> 'Dieses Quiz war weder gesichert noch beigetragen',
	'QUIZ_USER_CANNOT_PLAY_OWN'		=> 'Benutzer sind von Spielen ausgeschlossen, die sie selbst beitrugen.',
	// Answers page
	'SHOW_RESULTS_INCORRECT'		=> 'Du antwortest<strong>%s</strong><br />Die richtige Antwort war <strong>%s</strong>',
	'SHOW_RESULTS_CORRECT'			=> 'Du antwortest richtig <strong>%s</strong>',
	'TIME_SUMMARY'					=> 'Du löstest das Quiz in <strong>%d</strong> Sekunden',
	'RESULTS_SUMMARY'				=> 'Richtige Antworten: <strong>%d</strong><br />Unrichtige Antworten: <strong>%d</strong>',
	'QUIZ_POINTS_CASH_SUMMARY_WON'		=> 'Du gewannst <strong>%s Punkte</strong> in diesem Quiz.',
	'QUIZ_POINTS_CASH_SUMMARY_LOST'		=> 'Du verlorst <strong>%s Punkte</strong> in diesem Quiz.',
	'QUIZ_RESULTS'					=> 'Quiz Resulate',
	'QUIZ_RESULTS_WITH_NAME'		=> 'Quiz Resultate für "%s"',
	'QUIZ_TIME_EXCEEDED'			=> 'Du hast die erlaubte Zeit für dieses Quiz überschritten. Du brauchtest <strong>%d</strong> Sekunden. Deine Antworten wurden nicht gespeichert.',
	'QUIZ_PROGRESS_SAVED'			=> 'Dieses Quiz wurde gespeichert. Du kannst es zu einem späteren Zeitpunkt fortsetzen',
	'CHEATING_ATTEMPT'				=> 'Du siehst diese Meldung, weil eines von den folgenden Ereignissen erfolgte::<br /><br />- Ein Mogelversuch wurde festgestellt. Du kannst nicht ein Quiz verlassen und später es wieder aufnehmen ohne den Speicherprozess zu durchlaufen.<br />- Du hast versucht ein Quiz wieder beizutragen, dessen Zeitlimit ablief<br />- Du spieltest dieses Quiz schon und der Admin erlaubte keine Mehrfachversuche.',
	'MULTIPLE_SUBMISSION'			=> 'Es scheint das du versucht hast dieses Quiz mehrfach beizutragen.',
	'QUIZ_PLAY_ONCE_ONLY'			=> 'Du darfst nur einmal ein Quiz spielence.<br />%sKlick hier um zum Quizindex zurückzurkehren.%s',
	// statistics
	'QUIZ_STATISTICS'				=> 'Quiz Statistik',
	'QUIZ_PLAYER'					=> 'Quiz Spieler',
	'QUIZ_CORRECT'					=> 'Richtig ',
	'QUIZ_INCORRECT'				=> 'Unrichtig ',
	'QUIZ_PERCENTAGE'				=> 'Prozentzahl',
	// statistic module names
	'QUIZ_BEST_RESULTS_STATS'			=> 'Beste Resultate',
	'QUIZ_MOST_PLAYED_STATS'			=> 'Meist gespielt',
	'QUIZ_MOST_CORRECT_ANSWERS_STATS'	=> 'Meiste richtige Antworten',
	// 'QUIZ_HIGH_PERCENT_ANSWERS_STATS'	=> 'Höchste Prozentzahl von richtigen Antworten',
	// QUIZ_CP.PHP
	'QUIZ_CP'						=> 'Quiz Kontrollseite',
	'QUIZ_CP_LOWER'					=> 'Quiz Kontrollseite',
	'QUIZ_MOVE'						=> 'Bewege',
	'QUIZ_EDIT'						=> 'Editiere',
	'QUIZ_DELETE'					=> 'Lösche',
	'QUIZ_DELETE_ASK'				=> 'Lösche das Quiz',
	'QUIZ_DELETE_ASK_CONFIRM'		=> 'Bist du dir sicher dies Quiz zu löschen?',
	'QUIZ_DELETE_SUCCESSFUL'		=> 'Das Quiz wurde erfolgreich aus der Datenbank entfernt.<br /><br />%sZurück zur Quiz Kontrollseite.%s',
	'QUIZ_MOVE_ASK'					=> 'Verschiebe dieses Quiz',
	'QUIZ_MOVE_ASK_CONFIRM'			=> 'In welche Kategorie soll das Quiz verschoben werden? Wenn du soweit bist, drücke Eingabe. Die Kategorie ist derzeit in: <strong>%s</strong>',
	'QUIZ_MOVE_TO'					=> 'Verschiebe von <strong>%s</strong> nach:',
	'QUIZ_MOVE_SUCCESSFUL'			=> 'Das Quiz wurde erfolgreich verschoben.<br /><br />%sZurück zur Quiz Kontrollseite.%s',
	'QUIZ_MOVE_UNSUCCESSFUL'		=> 'Du hast keine Kategorie ausgesucht. Bitte klick den Zurückknopf im Browser um zur vorherigen Seite zurückzukehren.',
	'QUIZ_EDIT_ASK'					=> 'Editiere dieses Quiz',
	'QUIZ_EDIT_ASK_CONFIRM'			=> 'Editiere die untenstehenden Optionen und klick Eingabe wenn du fertig bis. Vergesse nicht das Kästchen der richtigen Antwort anzukreuzen.',
	'QUIZ_EDIT_SUCCESSFUL'			=> 'Das Quiz wurde erfolgreich editiert.<br /><br />%sZurück zur Quiz Kontrollseite.%s',
	/* // ACP
	'ACP_QUIZ' 			=> 'Quiz Admin',
	'ACP_QUIZ_INDEX_TITLE'	=> 'Quiz Admin',
	'ACP_QUIZ_CATEGORY'		=> 'Quiz Kategorien',
	'ACP_QUIZ_NEW_CATEGORY'		=> 'Erstelle neue neue Quiz Kategorie',
	'ACP_DELETE_QUIZ_CATEGORY'	=> 'Lösche Quiz Kategorie',
	'ACP_DELETE_QUIZ_CATEGORY_EXPLAIN'	=> 'Wähle in welche neue Kategorie die Quizze verschoben werden sollen. Keine Quizze werden gelöscht, um diese zu löschen musst du ins Quiz Control Panel.',
	'QUIZ_CATEGORY_LEGEND'		=> 'Quiz Kategorien',
	'QUIZ_CATEGORY_CHANGE_LEGEND'	=> 'Bearbeite',
	'QUIZ_ADD_NEW_CATEGORY'		=> 'Füge neue Kategorie hinzu',
	'QUIZ_CHANGE_CAT_NAME'		=> 'Kategoriename',
	'QUIZ_CHANGE_CAT_DESC'		=> 'Kategoriebeschreibung',
	'QUIZ_SETTINGS_LEGEND'		=> 'Quiz Einstellungen',
	'QUIZ_CANNOT_MIN_MAX_SWITCH'	=> 'Du kannst nicht eine minimale Anzahl von Fragen haben, die höher als das Maximum ist. Gehe zurück und korrigiere dies.',
	'QUIZ_CANNOT_LOW_MAX'			=> 'Du musst mindestens 2 Mehrfachauswahlen haben.  Gehe zurück und korrigiere dies.',
	'QUIZ_CANNOT_DELETE_CATEGORY'	=> 'Diese Kategorie kann nicht gelöscht und die Quizze nicht verschoben werden. Dies kann zwei Ursachen haben:<br />1. Du hast keine neue Kategorie für die Quizze ausgesucht.<br />2. Du hast die zu löschende Kategorie ausgewählt.<br /><br />Bitte gehe zurück und korrigiere dies.',
	'QUIZ_SUBMIT_MIN_SETTING'		=> 'Minimale Anzahl von Fragen',
	'QUIZ_SUBMIT_MIN_EXPLAIN'		=> 'Die minimale Anzahl von Fragen für ein Quiz.',
	'QUIZ_SUBMIT_MAX_SETTING'		=> 'Maximum Anzahl von Fragen',
	'QUIZ_SUBMIT_MAX_EXPLAIN'		=> 'Die maximale Anzahl von Fragen für ein Quiz.',
	'QUIZ_SUBMIT_MAX_MULTIPLE_CHOICE_SETTING'	=> 'Maximale Anzahl von Auswahlen',
	'QUIZ_SUBMIT_MAX_MULTIPLE_CHOICE_SETTING_EXPLAIN'	=> 'Die maximale Anzahl von Auswahlen für ein Quiz in Mehrfachauswahl.',
	'QUIZ_SAVED_ENABLED_SETTING'	=> 'Allow saved quizzes',
	'QUIZ_SAVED_ENABLED_SETTING_EXPLAIN'	=> 'Können Benutzer Quizze speichern und später fortsetzen?',
	'QUIZ_PLAY_ONCE_SETTING'	=> 'Benutzer können jeweils ein Quiz spielen',
	'QUIZ_PLAY_ONCE_EXPLAIN'	=> 'Ja bedeutet das Benutzer nur je ein Quiz spielen können. Dies ändert nichts an der EInstellung zum Speichern und Fortsetzung.',
	'QUIZ_SHOW_ANSWERS_SETTING'			=> 'Zeige Antworten',
	'QUIZ_SHOW_ANSWERS_SETTING_EXPLAIN'	=> 'Zeige Benutzern die richtigen Antworten?',
	'QUIZ_TIME_LIMIT_PER_QUESTION_SETTING'			=> 'Zeitlimit per Frage',
	'QUIZ_TIME_LIMIT_PER_QUESTION_SETTING_EXPLAIN'	=> 'Wie lange haben die Benutzer für die Antworten auf Fragen Zeit? 0 zum abschalten.',
	'QUIZ_SHOW_HOW_MANY_STATS_SETTING'			=> 'Statistiklisten',
	'QUIZ_SHOW_HOW_MANY_STATS_SETTING_EXPLAIN'	=> 'Wie viele  Resultate sollen für jede Statistikliste angezeigt werden?',
	'QUIZ_USER_EDIT_OWN_QUIZ_SETTING'			=> 'Bearbeite eigenes Quiz',
	'QUIZ_USER_EDIT_OWN_QUIZ_SETTING_EXPLAIN'	=> 'Können Benutzer ihre eigenen Quizze bearbeiten/löschen?',
	'QUIZ_CASH_ON'			=> 'Punkteabhängigkeit einschalten.',
	'QUIZ_CASH_ON_EXPLAIN'	=> 'Bei Einschalten der Funktionalität erlaubst du den Benutzern Punkte bei den Qiuzzen zu gewinnen und zu verlieren. Einschalten wird auch Cashfunktionen einschalten, wenn die Konfiguration aufgefrischt wird.',
	'QUIZ_CASH_WIN'	=> 'Wie viele Punkte für jede korrekte Antwort?',
	'QUIZ_CASH_LOSE'	=> 'Wie viele Punkte verloren für jede falsche Antwort?',
	'QUIZ_CATEGORY_ADDED_SUCESSFULLY'	=> 'Die Kategorie wurde hinzugefügt.',
	'QUIZ_CATEGORY_EDITED_SUCESSFULLY'	=> 'Die Kategorie wurde bearbeitet und erfolgreich aufgefrischt',
	'QUIZ_CONFIG_CHANGED_SUCESSFULLY'	=> 'Die Kategorie wurde erfolgreich aufgefrischt.',
	'QUIZ_CATEGORY_DELETED_SUCCESSFULLY'	=> 'Die Kategorie wurde erfolgreich gelöscht. Die Quizze wurden erfolgreich verschoben.',*/
info_acp_quiz.php
* @package language
* DO NOT CHANGE
	exit;
	$lang = array();
 'QUIZ' => 'Quiz',
	// Various
	// Functions
	// Submit quiz
	// Index
	// Play quiz
	// Answers page
	// statistics
	// QUIZ_CP.PHP
	/* // ACP
Btw.
I miss the password field for categories? I need it in case i want to use the quizmod for educations, such as tests etc.
Thanks for the translations Lugsciath. I've put a link to them in the first post here and phpBB.com. I originally intended to include passworded categories (in fact, I think the categories table has a password column to show my intentions) but I decided to hold passwords and usergroup permissions off until a future version.
I guess I could still include passwords, but it would be the quizzes that are password protected. So a user could still view the category contents, but as soon as they click a quiz it will ask for a password. Would this be okay?
Lugsciath
For the first time, yes ;) ... i switched the categories password in phpmyAdmin on, btw. It seams to work good. ;), also - only the acp part is missing :) (great job, bzw)!.
Thanks Lugsciath! :)
I am so happy to finally have some time to spend on UQM! :D
I have added passwords to the list of things to do for Beta 4 http://forums.cricketmx.com/viewtopic.p ... 041#p99041 :wink:
Stef67 wrote:Super Battye code you gave works perfectly
When editing a question that I bbcodes the integration are not kept, how to change that?
Stef67, I think I have found the problem :wink:
OPEN quiz_cp.php
			$quiz_question = strip_bbcode($questions_row['quiz_question'], $questions_row['quiz_uid']);
REPLACE WITH
			$quiz_question = decode_message($questions_row['quiz_question'], $questions_row['quiz_uid']);
Fixed for Beta 4 :)
Stef67
battye wrote:Is the "questions not appearing" only happening for some quizzes?
Yes ! :wink:
For this to bbcodes seems to work like that! =D>
Otherwise I think that when creating a quiz it will be better to have question 1, question 2, question 3, ... rather than Enter your question, it would know where it is
I've included an exciting new feature for Beta 4 :D
It is a survey results feature, and allows you to see how users have gone when answering quizzes. I think a screenshot will describe this best :)
It can be turned on and off in the ACP.
Survey results feature
I'm pleased to announce the release of Beta 4 :D
Thanks to mtrs and quahappy for their fantastic support and suggestions throughout the creation of Beta 4 :)
The full list of additions and changes can be found at http://forums.cricketmx.com/viewtopic.p ... 041#p99041
The main new features are a "survey results" feature and a "passworded categories" feature.
The upgrade instructions can be found in the DIY area of the MOD install file (don't forget to reupload all quiz related files and purge the cache in the ACP). For new users installing UQM, there is a UMIL package which you can use (thank you to mtrs for his assistance with this).
Download v2.0.0 Beta 4
RAR: http://www.cmxmods.net/downloads/Ultima ... Beta_4.rar
ZIP: http://www.cmxmods.net/downloads/Ultima ... Beta_4.zip
Lugsciath
german Translation:
language/de/mods/info_acp_quiz.php
* @package language
* @version $Id: info_acp_quiz.php, battye (c) 2004, 2005, 2008, 2009
* DO NOT CHANGE
exit;
$lang = array();
// ACP
'QUIZ_CHANGE_CAT_PASSWORD' => 'Kategoriepasswort',
'QUIZ_CHANGE_CAT_PW_DESC' => 'Nach Eingabe eines Passworts werden die Benutzer nach einem Passwort gefragt, dies ist ein Grundschutz und nichts für sensible Daten. Gib nichts ein für keinen Einschränkung.',
'QUIZ_SAVED_ENABLED_SETTING' => 'Erlaube gespeicherte Quizze',
'QUIZ_SURVEYS_SETTING' => 'Schalte Ergebnisübersicht ein',
'QUIZ_SURVEYS_SETTING_EXPLAIN' => 'Auf der Ergebnisübersicht können Benutzer die Ergebnisse der Anderen in einer Gegenüberstellung sehen.',
'QUIZ_INDEX_INTRO_SETTING' => 'Gib eine Willkommensnachricht auf dem Quizindex an',
'QUIZ_INDEX_INTRO_SETTING_EXPLAIN' => '255 Zeichen Grenze, gib nichts ein, wenn keine Nachricht gewünscht.',
'QUIZ_PLAY_OWN_SETTING' => 'Spiele eigenes Quiz',
'QUIZ_PLAY_OWN_SETTING_EXPLAIN' => 'Setze dies auf "nein" wenn du nicht magst, das Spiele ihre eigenen Quizze spielen. Dies ist nützlich wenn diese Spieler nicht leicht Punkte bekommen sollen, weil sie die Antworten kennen.',
'QUIZ_ADMIN_SUBMIT_SETTING' => 'Nur Administratoren erlauben Quizze einzureichen',
'QUIZ_ADMIN_SUBMIT_SETTING_EXPLAIN' => 'Wenn dies auf Ja gesetzt ist, können Nichtadministratoren keine Quizze beisteuern.',
language/de/mods/quiz.php
* @package language
* DO NOT CHANGE
exit;
$lang = array();
'QUIZ' => 'Quiz',
// Various
// Functions
// Submit quiz
// Index
// Play quiz
'QUIZ_PASSWORD_PROTECTED' => 'Du brauchst ein Passwort!',
'QUIZ_ENTER_PASSWORD' => 'Gib bitte das Passwort für diese Kategorie ein um ein Quiz spielen zu können:',
// Answers page
'QUIZ_RETURN_INDEX_CATEGORY' => 'Klick %shier%s um zum Quizindex zurück zu kehren.<br />Klick %shier%s um zur Ketagorie des Quiz zurück zu kehren.',
'QUIZ_NO_ID_VISIBLE' => 'Kann Quizseite nicht darstellen, da die ID nicht sichtbar ist',
'QUIZ_SURVEY_FEATURE' => 'Ergebnisübersichtsseite',
'QUIZ_SURVEY_FEATURE_EXPLAIN' => 'Der Administrator schaltete die Ergebnisübersicht ein, welche einen Vergleich mit anderen Benutzerergebnissen mit diesem Quiz erlaubt. Die potentiellen Antworten werden unter jeder Frage angezeigt.',
// statistics
// QUIZ_CP.PHP
/* // ACP
The quiz_link.php is already translated without changes from uqm Beta3 (only 2 Lines of translating :) )
Thanks Lugsciath :D
I have included both yours and Apophis72's translations in the first post of this topic and at phpBB.com :)
Stef67
Hello,
Here is the archive of the French language version 2 beta 4
French language
subvertbeats
Hey battye
B4 is going great !
On the new highest percentage stats table though, there seems to be a small problem.
Highest percentage of correct answers
Competition player Correct Incorrect Percentage
einarst 9 2 82%
Jamal 8 3 73%
kangnamwon 4 7 36%
chris 4 7 36%
sindr0m 4 7 36%
uchubaco 4 7 36%
choraocapo 3 8 27%
Kamara666 11 0 100%
Ive stripped a load of data out of that to keep this post small....but the thing to notice is that all the users are listed in the correct order - apart from the final user 'kamara666' who has 100% and should be at the top of the list, but is instead at the bottom.
I believe its related to this code in quiz_stats_class.php
		$sql = 'SELECT user_id, SUM(quiz_correct) AS sum_correct, SUM(quiz_incorrect) AS sum_incorrect, (SUM(quiz_correct) / SUM(quiz_incorrect)) AS equation
				 FROM ' . QUIZ_STATISTICS_OVERVIEW_TABLE . '
				GROUP BY user_id
				ORDER BY equation DESC';
where equation = correct_answers / incorrect_answers
which in the case of 100% = x / 0
I believe in order to address this, the code needs to be changed to:
		$sql = 'SELECT user_id, SUM(quiz_correct) AS sum_correct, SUM(quiz_incorrect) AS sum_incorrect, (SUM(quiz_correct) / (SUM(quiz_correct) + SUM(quiz_incorrect))) AS equation
				GROUP BY user_id
subvertbeats, thanks for picking up on that - I had not realised it was doing that. I will include the SQL change in whatever the next version is (I suspect RC1, unless there are enough little bugs like this to warrant a beta 5) :)
