The Articles Topic
Adding the censor_text() function call means if there are any swear words (or anything else in the word filter) in the message they will be censored. If you don't expect this to be a problem, it doesn't matter whether the functional call is there or not.
To have the link displayed properly, replace:
echo $topic_link;
With:
echo '<a href="' . $topic_link . '">Read more</a>';
Similarly for the other items, you can add the HTML tags.
ie. to make the topic title bold (ie. <b>) and add a new line below it (ie. <br /> - you add a <br /> for each line you want to appear. So if you wanted 2 blank lines between the topic title and whatever comes next, you would put 3 <br />'s in total):
echo '<b>' . $topic_title . '</b><br />';
And so on :)
frantic purple
Okay I got everything to work. But how do I get CSS to work in "theupdater" script, not just HTML tags. Here's the script so far:
* home.php
* September 29, 2009
$phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './forum/';
$user->session_begin();
$auth->acl($user->data);
$user->setup('viewforum');
* posts and topics */
global $db, $auth;
        switch($type)
            case 'forum':
                $type = 'forum_id';
                break;
            case 'topic':
                $type = 'topic_id';
                break;
            default:
    // no restrictions
    $out_where = '';
    if( $size_gen_id > 0 )
        if( $type == 'topic_id' )
            $sql     = 'SELECT topic_id FROM ' . TOPICS_TABLE . '
                        WHERE ' .  $db->sql_in_set('topic_id', $gen_id) . '
                        AND ' .  $db->sql_in_set('forum_id', $auth_f_read);
            $result     = $db->sql_query($sql);
            unset($gen_id);
            $gen_id = $topic_id_list;
    $j = 0;
        $j++;
    return $out_where;
$search_limit = 5;
    $forum_id = array(1, 4);
    $topic_id = array();
$posts_ary = array(
        'SELECT'    => 'p.*, t.*',
        'FROM'      => array(
            POSTS_TABLE     => 'p',
        'LEFT_JOIN' => array(
            array(
                'ON'    => 't.topic_first_post_id = p.post_id'
        'WHERE'     => str_replace( array('WHERE ', 'forum_id'), array('', 't.forum_id'), $forum_id_where) . '
                        AND t.topic_approved = 1',
         $topic_author       = get_username_string('full', $posts_row['topic_poster'], $posts_row['topic_first_poster_name'], $posts_row['topic_first_poster_colour']);
         $topic_date       = $user->format_date($posts_row['topic_time']);
         $topic_link       = append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . $posts_row['forum_id'] . '&t=' . $posts_row['topic_id']);
    echo '<h1>' . $topic_title . '</h1>';
    echo $topic_date . '<br />Written by ';
    echo $topic_author . '<br /><br />';
    echo $post_text;
Also what do I need to do to add a "comment link", also stating how many comments there are so far regarding that post. Do I need to add a line here:
If so where do I find this information so I can add other things in the future? Thank you so much.
Topic information can be found in the phpbb_topics table. With the SQL know-how you are not just limited to the topics table (view http://www.phpbbdoctor.com/doc_columns.php?id=21 for a list of the different things you can add) but for simple information it should be sufficient. For the number of comments;
Find
After add
$topic_replies       = $posts_row['topic_replies'];
Find
Replace with
echo '<a href="' . $topic_link . '">Comment link (' . $topic_replies . ')</a>';
As for your CSS, you are best putting that in your website index code, by putting it between <style type="text/css"> and </style> tags within the <head> part of the code.
<?php include("site/template/config.php"); ?>
<meta http-equiv="content-type" content="text/html;charset=utf-8" />
<head>
<style type="text/css">CSS CODE NEEDS TO GO HERE</style>
<title>MeanVent Studios | Home</title>
<meta name="description" content="Changing the rules of video game development. And being mean while doing it." />
</head>
<body>
<?php include("site/template/theupdater.php"); ?>
<b>Hello</b>
<?php include("site/template/footer.php"); ?>
<i>Testing Testing One Two...is this thing on?</i>
</body>
frantic purple
Thank you so much! Everything works great! However I now have another small thing I cannot figure out. I created a CSS file for "theupdater" script. But when I check my website to see if it worked, everything works except for the background-color. Therefore I must have linked the CSS file right, right? So why will all the CSS code work except for the background-color? Thanks.
Here's the CSS file:
body
background-color:#000000;
h1
font-family:"Courier New";
font-size:20px;
font-weight:bold;
font-style:normal;
color:purple;
p
font-family:"Arial";
font-size:14px;
font-weight:normal;
font-style:italic;
color:green;
</style>
I'm sorry, I'm not much of a guru with CSS. My best guess is that something might be overriding it so maybe check to make sure background-color isn't being used somewhere else?
Articles Bot
Forum Bot
Forum Bot
Queen Elizabeth II visted Australia for the 16th time as the English monarch during the Commonwealth Heads of Government Meeting between 28 and 30 October 2011. CHOGM was staged in Perth, Western Australia and the event marked the Queen's 8th visit to the state.
The Queen had several engagements in...
Read more
View all articles at http://www.cricketmx.com/articles/
I'm only a forum bot!
frantic purple
Everything was working perfectly until this happened. When the main website address (http://meanvent.com/) is typed in the URL bar, it automatically forwards to a weird error page in the forum (http://meanvent.com/forum). However when the script is deleted from the index page the site shows everything like it should. There's also another thing that happens where the forum shows the message: This board has no forums. However the forums show up when I log in as an Admin, but I checked to make sure the forums can be viewed by everyone. The same thing happens when I go to the main site (http://meanvent.com/) and am also logged into the forum (http://meanvent.com/forum). The script works perfectly and the error doesn't show (although the message: This board has no forums still shows up at the forum).
Script:
* home.php
global $db, $auth;
        switch($type)
            case 'forum':
                $type = 'forum_id';
                break;
            case 'topic':
                $type = 'topic_id';
                break;
            default:
    // no restrictions
    $out_where = '';
            unset($gen_id);
    $j = 0;
        $j++;
    return $out_where;
$search_limit = 5;
$posts_ary = array(
        'FROM'      => array(
            POSTS_TABLE     => 'p',
            array(
    echo $post_text . '<br /><br />';
    echo 'Written by ' . $topic_author . ' - ';
    echo $topic_date . ' - ';
    echo '<a href="' . $topic_link . '">Comments (' . $topic_replies . ')</a>' . '<br /><hr>';
So I'm just wondering why exactly this is happening? Was my website hacked? Or did the web host (http://bluehost.com/) have something to do with it? Thanks I'm pretty lost on this one. It was working perfectly one day then a week or so later it just didn't work, even though I haven't edited any of my website when this happened.
frantic purple, I just wanted to let you know I've read your post but I don't have enough time right now to write a detailed reply. The fact that it was working and then suddenly it stopped working is very strange. What was the filename of the script? index.php or home.php?
Is the forum supposed to be at http://meanvent.com/forum?
frantic purple
Script file name: theupdater.php
(http://meanvent.com/site/template/theupdater.php)
Yes the forum is at http://meanvent.com/forum. Thank you so much for helping out, it was the weirdest thing. Also take your time, your the one helping me, remember? :) I'm thankful you've answered all of my annoying questions this far.
In your FTP, do you see an index.php file inside the main directory (ie. the directory above forum/)?
Do you see a .htaccess file?
Don't post either of those files publicly, but please PM me the contents. I guess there is some redirection happening but I'm not sure why.
Articles Bot
Forum Bot
Forum Bot
The Killers new EP, (RED) Christmas EP, is one of the diverse Christmas compilations going around featuring the classic pop-rock sound fans of The Killers will be familiar with as well an upbeat country track, a Mexican style mariachi offering and more relaxed ballad. This has been a long time comin...
Read more
Articles Bot
Forum Bot
Forum Bot
The Coca Cola BottleBat is this summers cricket promotion. It is tough for companies to keep ideas fresh and it is even harder to top the promotions of years gone by - the talking Boonie figurines offered by VB with a carton of beer several years ago were immensely popular.
The Coca Cola BottleBat ...
Read more
Articles Bot
Forum Bot
Forum Bot
In the past when I have performed deserialisation (taking the hierarchical contents of an XML file and converting that that to an object hierarchy at run time) I have used methods such as XmlDocument and manually created objects, or created my own classes and implemented a more traditional style of ...
Read more
Johny
Articles Bot wrote:
Population wise Australia is quite small, such that even the largest city - Sydney (4.5 million) - it has fewer people than Singapore (4.9 million) despite the advantage of land and room for expansion. Australia is a fantastic country in many ways, but in my opinion decentralised urban centres with ...
Read more
Digg this article
Hi guys! I am new here. I just want to ask if anyone here knows about Mandai Foodlink http://www.foodlinkmandai.com/. I accidentally visited their site while I am doing my research about Singapore's delicacies and food. Though, I read some review about it I am still not sure what mandai foodlink is. Is this a resto or a food centre?
So what kind of research are you doing? Are you a web designer. Your posts there sort of indicate that in the other forums.
Food Link Mandai seems to be some sort of food court/development complex, can't say for sure though....Not sure why you're quoting the Articles bot on a two year old post, I really hope you're a real person :)
