An update and a bug fix today. This release should fix the freezing problem. Also if your auto update still isn't working you should replace autoupdate.exe and autoupdate.ini with the ones from the arhive here.
Also several new things this time as well.
#admincmd /listhidden or /listhidden
#admincmd /listignore or /listignore
#admincmd /kickip <IP> or /kickip <IP>
#admincmd writeprotecton / #admincmd writeprotectoff
The first 3 should be self explanitory. Write protect simply blocks messages with words in it you don't want. This doesn't effect admins. You'll need to add the following to your RCMSConfig.txt if you want the notices in english
$WriteProtectOff$="Message Blocker Off!"
$WriteProtectOffNotify$="Message Blocker Diabled!"
$WriteProtectOn$="Message Block On"
$WriteProtectOnNotify$="Message Blocker Enabled"
An example of adding blocked words in rcmsconfig.txt is
[Blockwrite] ; (0-127)
Word[0]="@hotmail"
Word[1]="@yahoo"
Word[3]="http"
Oukas Chat Server
- A Forum Addict
- ChatServerE_500b_2005_05_28_1700.zip
- (121.89 KiB) Downloaded 616 times
I have downloaded the last version. ChatServerE_500b_2005_05_28_1700.zip
It works fine on W2000 but it does nos saves the new "#admincmd writeprotecton /#admincmd writeprotectoff" command from the "Management situation" panel to the ChatStartUp.txt file. Y think it is the "Message Block On" setting.
Anyway. Thanks Jasson and Ouka for the help provided
copialo tu mismo dentro de ChatStartup.txt y veras que el server activa el comando cada vez que inicias el oukaserver
new "test" version from our friend Ouka (the cat)
ChatServerE_500b_2005_06_05_0000.zip
Test place:
Connection request from client (accept) processing
around
enjoy it !!!
Test place:
around
enjoy it !!!
- ChatServerE_500b_2005_06_05_0000.zip
- (122.16 KiB) Downloaded 562 times
Any idea what this is... To be honest I still haven't figured out the vote command in the earlier releaseFast-007 wrote: Test place:
around
<Insert Abuse Here. . . >
i think it means , that the redirect work better now , less ghost after redirect i just test that today and it work better
- A Forum Addict
The vote command only works with Ouka Chat Client2.
When voting is enabled those using Ouka's client will notice the exit button changes to "Vote".
Then you can click the vote button and vote for whatever it is you're voting on. You'll notice a number appears by your name when you click vote and will increase each time you press it.
I guess it's intended to be used as one of those "press 1 for <whatever>, press 2 for <this idea>" so you press vote until the number you wanted to vote for displays. *shrug* I suppose someone would find it useful, but I dunno who lol
As for the new update? your guess is as good as mine.
new "test" version "c" version
ChatServerE_500c_2005_06_07_1900.zip
Test place:
Processing at time of client
come awaying * The maximum number of come awaying people, Lee direct for load test.
dont ask me what it means i have traduced it with google !!! xD
( i think lee direct means redirect )
and i have noticed that RoboMX version 1.4 , RoboMX 1.51 and Nushi Chat Client have problems to enter the channel with this version , the Ouka Chat Client version 1 and 2 , dont have any problems to enter the channel
Test place:
- ChatServerE_500c_2005_06_07_1900.zip
- (122.48 KiB) Downloaded 563 times
- A Forum Addict
A better translation would be
Testing Phase:
Client joining time dealt with/disposed.
*The greatest number of users joining in redirect's stress testing.
The readme that's always absent from the english version says:
2005/06/07 Ver5.00c Join time process reviewed.
So the negotiation between server and client's been changed to fix timeouts.
And he's stress testing redirects, presumably to find/fix the issue with redirects not really working.
Testing Phase:
new ouka server
ChatServerE_500c_2005_06_10_1600.zip
Test phase:
Processing at time of client come awaying (transmission timing of topic and user list et cetera)
enjoy !!!!
Test phase:
enjoy !!!!
- ChatServerE_500c_2005_06_10_1600.zip
- (122.89 KiB) Downloaded 532 times
Thanks for the updates Fast-007 & Protoman
you are welcome , thats why im here for
i could do anything for my friend Ouka (the cat)
new server
ChatServerE_500c_2005_06_11_1700.zip
Correction edition
of 500c_2005_06_10_1600 After processing the information of come awaying of one constant or more,
After that information of come awaying without being processed only retreating/quitting room information the place where it is processed correction
enjoy !!
Correction edition
enjoy !!
- ChatServerE_500c_2005_06_11_1700.zip
- (122.9 KiB) Downloaded 568 times
#admincmd crackerblockon <-- ON
#admincmd crackerblockoff <-- OFF
