The Articles Topic
markoff wrote:
Articles Bot wrote:
This article is a follow-on from the blog post I made at phpBB.com not too long ago. I recommend reading that post first before reading this, as all of the information you need might be in that po...
Read more
Hello, I was wondering if you had any tips for adding a "View older entries" at the bottom of the blog posts, from the main page. So I could display 10 blog posts, and then click the link to view another 10 older posts.
Thanks. Using your blog code now and it helped me out a lot
Hi markoff, welcome to CMX :)
See this code here:
$topics = 'SELECT * FROM ' . TOPICS_TABLE . '
' . $forum_id_where . '
AND topic_status <> ' . ITEM_MOVED . '
AND topic_approved = 1
ORDER BY topic_id DESC';
$topics_result = $db->sql_query_limit($topics, $search_limit);
See how sql_query_limit is used? Information about that can be found at http://wiki.phpbb.com/Dbal.sql_query_limit
So $db->sql_query_limit($topics, 10, 10); would select 10 results with an offset of 10 (ie. results 10 to 20).
Do you have any experience with PHP? Because you could do this dynamically by introducing another variable to put as the 3rd parameter (after $search_limit) which changes from 0 to 10 depending on whether the "display more" link has been clicked. If not, let me know and I can help you out with this :)
markoff
Thanks so much.. that is exactly what I needed to know. I am learning PHP as I go and have been modifying your code a bit to serve my needs. Its a lot of fun and this setup has added an entirely new dimension to my site.. I really appreciate it!
neljan
Read more
Me again :)
I'm using the function to display the contents of posts on external pages, then :
$search_limit = 1;
$forum_id = array(834);
$topic_id = array(11497);
$posts_ary = array(
        'FROM'      => array(
            POSTS_TABLE     => 'p',
        'LEFT_JOIN' => array(
            array(
            array(
        'WHERE'     =>  str_replace( array('WHERE ', 'topic_id'), array('', 't.topic_id'), $topic_id_where) . '
                         AND t.topic_approved = 1',
         $post_link       = append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . $posts_row['forum_id'] . '&t=' . $posts_row['topic_id'] . '&p=' . $posts_row['post_id']) . '#p' . $posts_row['post_id'];
The problem is, if I choose to display posts from a forum that a user does not have permissions to, they get this error:
SQL ERROR [ mysql4 ]
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'AND t.topic_status <> 2 AND t.topic_approved = 1 ORDER ' at line 2 [1064]
Perhaps a bug?
anyway, since the forum I'm targetting is a hidden forum, intended for staff to post announcements to be displayed on external pages for everyone (regardless of whether they have access to the hidden forum or not) I would like to remove the part of the function that checks for permissions.
Should I delete (from functions)...
Then change...
if ($type == 'topic_id')
$sql = 'SELECT topic_id FROM ' . TOPICS_TABLE . '
WHERE ' . $db->sql_in_set('topic_id', $gen_id) . '
AND ' . $db->sql_in_set('forum_id', $auth_f_read);
Or is it something else?
Thanks very much.
neljan
Ok I changed this:
to
$auth_f_read = array_keys($auth->acl_getf('f_read', false);
to fix it.
frantic purple
Okay so I got the script to work perfectly, but now I'm having trouble with the page it's on. Here's the process I went through at phpBB.com: http://www.phpbb.com/community/posting. ... p=13061904. Anything I put after the script will not show up on the webpage. I think it has something to do with the script not finishing or something but I'm not entirely sure or how to fix it for that matter. Here's the script:
* home.php
* September 29, 2009
$phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './forum/';
$user->session_begin();
$auth->acl($user->data);
$user->setup('viewforum');
* posts and topics */
global $db, $auth;
        switch($type)
            case 'forum':
                $type = 'forum_id';
                break;
            case 'topic':
                $type = 'topic_id';
                break;
            default:
    // no restrictions
    $out_where = '';
    if( $size_gen_id > 0 )
        if( $type == 'topic_id' )
            $result     = $db->sql_query($sql);
            unset($gen_id);
            $gen_id = $topic_id_list;
    $j = 0;
        $j++;
    return $out_where;
$search_limit = 5;
    $forum_id = array(1, 4);
    $topic_id = array();
$posts_ary = array(
        'SELECT'    => 'p.*, t.*',
        'FROM'      => array(
            POSTS_TABLE     => 'p',
            array(
                'ON'    => 't.topic_first_post_id = p.post_id'
        'WHERE'     => str_replace( array('WHERE ', 'forum_id'), array('', 't.forum_id'), $forum_id_where) . '
         $topic_author       = get_username_string('full', $posts_row['topic_poster'], $posts_row['topic_first_poster_name'], $posts_row['topic_first_poster_colour']);
         $topic_date       = $user->format_date($posts_row['topic_time']);
         $topic_link       = append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . $posts_row['forum_id'] . '&t=' . $posts_row['topic_id']);
         'TOPIC_AUTHOR'       => $topic_author,
         'TOPIC_DATE'       => $topic_date,
         'TOPIC_LINK'       => $topic_link,
page_header('External page');
        'body' => 'external_body.html'
    page_footer();
Thanks in advance. :)
Hi frantic purple, welcome to CMX :)
What do you mean by "anything you put after the script"?
The last line is page_footer(), so you won't be able to see anything that is done after that point because the footer has already been drawn to the screen :)
frantic purple
battye wrote:Hi frantic purple, welcome to CMX :)
Thanks for the quick response. What I mean by "anything you put after the script" is anything on the index page of my website after the script. For example I have my own footer I would like to place on the website separate from the script, but any HTML, PHP, etc, won't show on the index page after the script has been run. It will however show on the index page if I delete the page_footer(); line in the script. But when I delete the page_footer(); line then the script doesn't show on the index page and the website footer does. So I guess my question is what can I do to have the script and my website footer show on my website index page? Do I have to change something in page_footer(); file? Thank you so much this has been bugging me for weeks. :]
There are a number of ways you could do it. The one that springs to mind for me would be to actually edit overall_footer.html (in styles/prosilver/template) and add a conditional statement to display your desired website footer. ie.
<!-- IF IN_WEBSITE --> html code here... <!-- ENDIF -->
And then modify a bit of the PHP so the templating variable IN_WEBSITE is set to true when this script is being run.
Another option is, if you don't want your script to look like phpBB, to remove all of the templating references and just echo the output. Then you can style it using HTML in any way you want :)
frantic purple
battye wrote:There are a number of ways you could do it. The one that springs to mind for me would be to actually edit overall_footer.html (in styles/prosilver/template) and add a conditional statement to display your desired website footer. ie.
Okay so I think I'm going with option 2 because I would like to have my main website not look like phpBB. All I want is for the posts from one forum (http://meanvent.com/forum/index.php > News & Updates) to show on the website (http://meanvent.com/). Everything looks and works perfectly, except once the PHP script runs the rest of the code gets cut off. Looking at the source code from the index page it seems that the code after the PHP script is not even getting retrieved, which leads me to believe that the PHP script is somehow stopping at the end and not allowing for the rest of the page to do its thing. So, if I'm right, then what exactly do I need to change in the PHP script to make it so all the code after the script will get retrieved (and show up on the page)? Or is there a better way to retrieve the latest posts from a certain forum? Thank you so much. I apologize for the repeated questions, and for not quite getting it.
Website index code
<?php include("site/template/config.php"); ?>
<head>
<meta http-equiv="content-type" content="text/html;charset=utf-8" />
<title>MeanVent Studios | Home</title>
</head>
<body>
<?php include("site/template/theupdater.php"); ?>
<b>Hello</b>
<?php include("site/template/footer.php"); ?>
<i>Testing Testing One Two...is this thing on?</i>
</body>
Internet source code
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
<link rel="stylesheet" type="text/css" href="../styles/global.css" />
<html>
<head>
</head>
<body>
<html>
<head>
<style type="text/css">
body
background-color:#FFFFFF;
h1
font-family:"Courier New";
font-size:20px;
font-weight:bold;
font-style:normal;
color:purple;
h2
font-family:"Arial";
font-size:14px;
font-weight:normal;
font-style:italic;
color:green;
</style>
</head>
<body>
<h1>MeanVent Has Begun</h1>
<h2>September 17th, 2011, 1:34 pm</h2>
Written by <a href="./forum/memberlist.php?mode=viewprofile&u=2" style="color: #AA0000;" class="username-coloured">frantic purple</a><br /><br />
With Blinding Light signing on for the first time, MeanVent Studios has finally started to step towards its ultimate goal of becoming a game development studio, among other things. The first task we Meanies have is to build up our own fortress, our castle, our home: our website. After that we will begin to explore the many ideas we have for our first game. We will let you in on more details soon....<br />
<br />
Forum Registration has now been disabled due to the infinite amount of spammers creating an account. Registration will be back on when we post the first big update for our very first game. Thank you for understanding.<br /><br />
<a href="./forum/viewtopic.php?f=4&t=20">Read more</a><hr /><br /><br />
</body>
</html>
As you can see, these lines are in the index code, but do not show on the internet source code:
<b>Hello</b>
PHP script
Website directory: ("site/template/theupdater.php")
* home.php
global $db, $auth;
        switch($type)
            case 'forum':
                $type = 'forum_id';
                break;
            case 'topic':
                $type = 'topic_id';
                break;
            default:
    // no restrictions
    $out_where = '';
            unset($gen_id);
    $j = 0;
        $j++;
    return $out_where;
$search_limit = 5;
$posts_ary = array(
        'FROM'      => array(
            POSTS_TABLE     => 'p',
            array(
    page_footer();
You need to get rid of the templating references is theupdater.php. Like this:
    page_footer();
And instead of having $template->assign_block_vars('announcements', array(.... replace each with an echo. Like:
echo censor_text($topic_title);
echo $topic_author;
echo censor_text($post_text);
Then you can remove the echo's and add formatting to them (ie. echo '<br />'; for a new line) as necessary :)
frantic purple
Okay so what exactly do I delete from this code:
        page_footer();
And what exactly do I replace the deleted part with? Also do I delete external_body.html? (forum/styles/prosilver/template/external_body.html). Or do I need to change or delete only part of it?
external_body.html:
<html>
<head>
body
h1
font-size:20px;
font-weight:bold;
font-style:normal;
color:purple;
h2
font-size:14px;
font-weight:normal;
font-style:italic;
color:green;
</style>
</head>
<body>
<!-- BEGIN announcements -->
<h1>{announcements.TOPIC_TITLE}</h1>
<h2>{announcements.TOPIC_DATE}</h2>
Written by {announcements.TOPIC_AUTHOR}<br /><br />
{announcements.POST_TEXT}<br /><br />
<a href="{announcements.TOPIC_LINK}">Read more</a><hr /><br /><br />
<!-- END announcements -->
</body>
</html>
Or do I need to change the page_footer(); file? Because when I delete this the rest of the index page shows, but the script doesn't work. Thank you so much, sorry for not understanding the previous post.
You can remove all of
        page_footer();
And where you have
You can also remove that too, but replace it with things like
echo $topic_author;
... (etc)
To output the various bits you want shown.
You don't need to change page_footer(). Don't delete external_body.html just yet. By the end of this it won't serve a purpose, but I wouldn't get rid of it just yet.
frantic purple
Okay so now the script "theupdater" looks like this:
* home.php
global $db, $auth;
        switch($type)
            case 'forum':
                $type = 'forum_id';
                break;
            case 'topic':
                $type = 'topic_id';
                break;
            default:
    // no restrictions
    $out_where = '';
            unset($gen_id);
    $j = 0;
        $j++;
    return $out_where;
$search_limit = 5;
$posts_ary = array(
        'FROM'      => array(
            POSTS_TABLE     => 'p',
            array(
    echo $topic_author;
    ... (etc)
<head>
<meta name="description" content="Changing the rules of video game development. And being mean while doing it." />
</head>
<body>
<b>Hello</b>
</body>
However the webpage http://www.meanvent.com is blank. Here's the webpage source code:
<html>
<head>
</head>
<body>
As you can see the script "theupdater" and all of the code underneath does not show in the source code. The other problem of course being the script "theupdater" no longer working.
I'm surprised it didn't return an error message! I actually think it is but the error is being suppressed (due to the level of error reporting on your site), hence there is a blank page.
I didn't actually mean to put ... (etc) in the code, I meant "et cetera" for the "output the various bits you want shown". So if you want to output the topic date for example, you would include echo $topic_date; but if you didn't want to include the topic date then you wouldn't include that part. Please read the bottom http://forums.cricketmx.com/viewtopic.p ... 39#p106839 (the post above) very carefully. Notice how what is one the right hand side of the => is being used in the echo lines.
frantic purple
It works now, I just don't know how to format it. I tried adding some tags like <h1>, etc. but I couldn't get any to work, so I guess I just need to know where to put them to format the output of the script. Here's the script "theupdater" as is:
* home.php
global $db, $auth;
        switch($type)
            case 'forum':
                $type = 'forum_id';
                break;
            case 'topic':
                $type = 'topic_id';
                break;
            default:
    // no restrictions
    $out_where = '';
            unset($gen_id);
    $j = 0;
        $j++;
    return $out_where;
$search_limit = 5;
$posts_ary = array(
        'FROM'      => array(
            POSTS_TABLE     => 'p',
            array(
    echo $topic_title;
    echo $topic_date;
    echo $topic_author;
    echo $post_text;
    echo $topic_link;
Here's the webpage the script is on: http://www.meanvent.com/. As you can see everything is there, it just needs to be formatted to look nice and pretty. So where do I add the formatting tags <>, like <b>, etc. in the script to format it? Or do I do something else to format it? Thank you so much! Oh and I didn't add the "censor" part after the "echo". Should I add "censor" or is there any point to it? Also the "echo $topic_link" shows but not as a link. It's probably pretty simple but what do I do to make it show as a link on the webpage? Thank you so much, sorry for the question overload.
