EDIT: Well, whilst my logic above seems sound to me, reverting that change has got things working !
Hmmm......
Instead of having that "cancelled" bit inside the while loop (still not quite sure why this wasn't working for you because you said you didn't try and cancel the question, but regardless...
) try an if statement inside the while loop.
So find the while loop and take out that "$question_id_set..." but (presumably you have already done this), and after the curly brace ( { ) add:
Then at the end of the while loop, which I believe (double check this though as I only looked quickly) is:
After that, add:
If you want to stay on the safe side, don't do this until you actually do have a cancelled question though
if( $_POST['question' . $question_id_set[$i]] != 'cancelled' )
{Code: Select all
$users_information[$row['quiz_player']]['info'] = 'Question ' . $question_id_set[$i] . ' incorrect (' . $row['quiz_answer'] . ')';
}Code: Select all
}CricketMX.com in 2022: Still the home of bat's, rat's and other farmyard animals!
subvertbeats
- Know-It-All
Thanks battye, whats your advise ref beta 4, and even the forthcoming final release?
should I try and keep up to date and patch accordingly?
Or should I just lok out for any important security related changes?
all the best
all the best
I suggest upgrading to every new release if possible, there are some great new features in Beta 4.
How many changes did I say you should make to quiz.php? If I recall it was only commenting out one of the SQL queries? Is so, just comment out the same line in the new quiz.php - there are no database structure changes (a few new config rows only) and nothing should affect your control_quiz.php file.
In answer to your PM... yes leaving that line commented out could have some pretty funky effects. It might explain that strange behaviour you were having before.
I've been looking at a lot of code over the past week so I can't remember everything I've written for you, but that quiz you ran probably won't work (if that line has been commented out I imagine that no statistics have been recorded... look in the phpbb_quiz_statistics table, do you see any answers for this quiz submitted by users). You could still try doing the enter_answers to see what happens though. Worst case scenario is you delete the quiz, re-enter it and ask the users to resubmit their predictions.
subvertbeats
- Know-It-All
thanks battye...thought that might be the case..
subvertbeats
- Know-It-All
Battye
Quick Q - do you know of any way for a given quiz I can get a dump of all the answers that each user submitted?
Try running this SQL code in phpMyAdmin:
(replace XXX with the quiz id)
SELECT *
FROM phpbb_quiz_statistics
WHERE quiz_id = XXX
ORDER BY quiz_playerCricketMX.com in 2022: Still the home of bat's, rat's and other farmyard animals!
subvertbeats
- Know-It-All
Thanks Battye, that did the trick.
Ive found an issue (dont know if it affects the core UQM too) whereby if a correct quiz answer has non alphanumeric characters in it eg quotation marks, then it is not counted correctly when the quiz answers are submitted.
Any ideas?
Any ideas?
It doesn't appear to be affecting an un-modded UQM, see http://forums.cricketmx.com/quiz.php?mode=play&q=27 (answers are $2 and "$6" respectively, and it counts them correctly).
subvertbeats
- Know-It-All
Interesting.....its definitely that. If I edit the question options, and change all the users answers for that question in the DB to remove the quotes, then re-enter the answers the correct/incorrect counts are done as expected.battye wrote:It doesn't appear to be affecting an un-modded UQM, see http://forums.cricketmx.com/quiz.php?mode=play&q=27 (answers are $2 and "$6" respectively, and it counts them correctly).
Any ideas? Its not too important since we can just avoid using quotes in question answers, but would be nice to work it out some time.
subvertbeats
- Know-It-All
hey battye I hope all is well with you?
Ive had requests for a modification of the system such that it sends a forum PM to the user with details of their answers when they successfully submit a quiz/competition.
any thoughts on the simplest way to do this?
many thanks
many thanks
subvertbeats
- Know-It-All
Hi battye
OK, so I figured out sending PMs on successful submission of a quiz.
I'll post the code here when complete.
What I would like to do is add to the PM content the list of questions, with the answer chosen by the user for each question
So I need to know how to iterate over all questions in the current quiz and build a string that includes:
- question name
- answer given by user for that question
Could you let me know how to access that info?
Many thanks!
- question name
Many thanks!
I don't have access to the computer right where I keep my local running copy of the UQM database so I can't test the query at the moment but I believe it would be, roughly:
That is just if you need to get the info from the database though. Assuming you are putting your submit_pm code (I believe there is plenty of information on how to do that at phpBB.com - http://www.google.com/search?hl=en&sour ... 5&aql=&oq=) in quiz.php you may not even need to access the database another time though. You could probably hook into some of the existing code.
For instance in quiz.php look for this code:
And below that is $db_answer, so you have the actual answer and $db_answer which is whatever the user submitted. By using $question->show_question() you can obtain the question name.
Good luck!
// assume $quiz_id is initialised earlier
$sql = "SELECT * FROM " . QUIZ_STATISTICS_TABLE . " s, " . QUIZ_TABLE . " q, " . QUIZ_QUESTIONS_TABLE . " t
WHERE t.question_quiz = " . (int) $quiz_id . "
AND s.quiz_question_id = t.question_id
AND s.quiz_user = " . (int) $user->data['user_id'];For instance in quiz.php look for this code:
foreach( $play_quiz as $question )
// Get the actual information
$actual_answer = $question->show_correct();
$question_answers = $question->show_answers(); Good luck!
