Oukas Chat Server
Jimmys444
TheHawks wrote:I ForGot That I Was Using RoBoMx 2.00Pre
Yes!!! i use RoboMX Version 2.00Pre
Build Date: Mar 19 2005
Build Time: 17:57:18
i dont bilive is this the problem....i have the same and with Metis 2.60 and metis 2.60 is uses RoboMX Version 1.40 :wink: 8) :D
JASON
If your running the server it isn't a problem, I can succesfully join using any chat client using a loopback or my LAN address thats why the problem is hard to find out cause you can't test it out on yourself other people must try to get in. We did get RoboMX to enter the channel but that was after 8 or 9 time attempts using its out-join function :(
<Insert Abuse Here. . . >
JASON
Good news! Ouka has fixed the bug in his server that was preventing some clients from joining the channel and after abit of testing from a very good assistant ;) here it is, all seems to be working again now :arrow: :wink:
BIG Thanks to Ouka for this :D
Recap on what the new commands:
Disabled/Enable #topic #motd #nickname commands
#AdminCmd RCMSLimitationOff
#AdminCmd RCMSLimitationOn
New lines for RCMSConf.txt:
$LimitationOn$="#Comd Limitation Enabled"
$LimitationOnNotify$="Commands Limitation Enabled!"
$LimitationOff$="#Comd Limitation Disabled"
$LimitationOffNotify$="Commands Limitation Disabled!"
P.S I thought Id add here an example of the chatstartup.txt file for people to either view or download (to download the file you must right-click the download tab and select save target as) and use or use it as a template for there own. If it matters this is the exact setup file I use for my own channel :)
ChatStartup.txt
Ouka Chat Server RCMS Chat Startup File
(542 Bytes) Downloaded 614 times
ChatServer_450c_2005_04_05_1000.zip
Ouka Chat Server Ver 4.50c 2005 04 05 1000
(125.82 KiB) Downloaded 539 times
Yes.. its working great...Once again Hats off to you Ouka for a great Chat Server program.. :D
"Very Good Assistant"?.. lol
Its always good to have a good parnter in crime.. . :wink:
TheHawks
Great for updates no time wasted On the Fixes :D
"looks Like someone found a magic Hat" :wink:
Well theres also the language barrier to contend with.
I,m sure Ouka was hard at work at fixing the problem, and now he has, he should take it easy for a while, dont want us to burn the poor guy out
ELEphantman
Ouka Rockz!!
now if only we can get the redirect prob fixed we`ll be all set :lol:
cant wait to try this new version out :wink: room will most likely be up another week b4 it crashes :lol: :D
Lunatic_UK1958
So far so good :)
However, as usual I have another 'hitch'!
In the 'Management Situation' window in Ouka, I have the 'Suneo Block' disabled. However, I still get:
'<Admin> SUNEO (ASCII Art Flooding) is Blocked! [IP:209.##.##.##]
Any ideas why?
Ouka is a great server and getting better all the time. Superb job.
Lunatic_UK1958
and btw.....
Within ouka, when a 'admincmd /banip' or 'kickban' is issued, the username AND IP of the banned user is shown in the 'Penalty List'.
Because this isn't actually stored anywhere, I then have to copy the IPs into my 'ChatStartup.txt' file to reload them when I restart Ouka.
Works great, but there doesn't seem to be a way of storing the IP AND username!
I can only add the lines as:
;UserName IdiotUser
/banip 80.##.##.###
and the banned IPs get reloaded.
But a 'ListBans' won't show WHO the banned user is!
Any suggestions on how I can get the Penalty list to reload the Username AND IP?
Thanks.
JASON
Are you sure you have the English files loaded?
Check that line in the RCMSConf.txt file, make sure it's 0.
IllegalCharBlock="0"
; 0=ANSI_CHARSET (English and Western languages)   1=Shift-JIS_CHARSET (Japanese)
And the penalty list thing, short answer is no using /banip puts the numerical IP and the hexadecimal equivalent in the list using /kickban puts the username and numerical IP address into it, reloading the bans can only give you the numerical and hexadecimal value's in the list, no way of adding the names to it im afraid.
Lunatic_UK1958
Jason,
Checked it and it is set correctly :!:
Shame about the ban list :-(
JASON
Said you disabled the suneo block? I always thought that suneo block thing had to do with certain ascii characters in peoples names, Are they being blokced from entering or being kicked out cause I don't ever get that come up on my screen I did however find #admincmd suneowriteblockon and #admincmd suneowriteblockoff I dont use either of these two commands in my channel so if you've turned it off as you say cause this is the only command referring to "suneo block" try opening your channel without using this command at all and see what happens :?
JASON
Another update from Ouka here, BIG thanks go out to him :D
Download ChatServer 450c 200504091300 here :)
Only thing Ive saw at a glance is a new option in the settings window that enables / disables the information beep :)
ChatServer_450c_2005_04_09_1300.zip
(127.56 KiB) Downloaded 587 times
Cheers Jason, I think my last count of Oukas Servers comes to well over 20 now , he really is a perfectionist 8)
Thanks Ouka 8)
ELEphantman
kool let him perfection , cause its lookin real good already 8)
