WinMx Connection Checker
umm... if i didn't allready know them then there would be no MCMA!
Km said
room listings require UDP encryption which is different to the TCP encryption used for pretty much everything else such as chat connections. The UDP decryption was released by nushi, but its missing one of the UDP tables so encryption cant be done (i left my system generating tables and came up with 3 possible tables that work but all crash after a few uses).
and also
Make your mind up :roll:
you where refering to the TCP encryption that was copy/pasted from nushi's forum to benders site and the tables to go with them from the mxsock dll - everyone has that. the only thing missing is one of the UDP encryption tables for encrypting UDP data. but even if i had it there's probibly not much i'd do with it, i might eventually get around to making a listing server, but it would be more a "see if i can do it" thing than an actual being bothered with it, why go through all the hassle when i can just modify the existing MX room to do what i want it to? :-)
