Event Calendar RSVP
havocwreaker
- Frequent Poster
OK everything is done...sorry it took me a while I will now verify its working as it should.
Are you able to post a screenshot of the index page (with an alert appearing)? I'd like to make sure it is appearing as it should
Thanks
Thanks
havocwreaker
- Frequent Poster
hmmm...
I am getting this when I set an alert. What could I have done wrong?
General Error
SQL ERROR [ mysqli ]
Incorrect integer value: 'Today' for column 'alert_text' at row 1 [1366]
SQL
INSERT INTO phpbb_alerts (user_id, alert_text, alert_time, alert_day, alert_day_before, alert_week, alert_week_leading, alert_global) VALUES ('53', 'Today', 1265353200, 1, 0, 0, 0, 0)
BACKTRACE
FILE: includes/db/mysqli.php
LINE: 163
CALL: dbal->sql_error()
FILE: includes/ucp/ucp_alerts.php
LINE: 100
CALL: dbal_mysqli->sql_query()
FILE: includes/functions_module.php
LINE: 507
CALL: ucp_alerts->main()
FILE: ucp.php
LINE: 325
CALL: p_master->load_active()If you look in phpMyAdmin, is the column alert_text set to be of type VARCHAR(255) ?
havocwreaker
- Frequent Poster
Whoops sorry i got it.
`alert_text` VARCHAR( 255 ) NOT NULL ,
I had it set to int...I'm drowsy
havocwreaker
- Frequent Poster
Hmmm...It keeps telling me this date even though I put in today's date:
Your alert for 04 Feb 2010, 23:00 has been submitted to the database. You will be notified this many days before each event:
On the day
Day before
On the day
Day before
- Mod.pdf
- (409.31 KiB) Downloaded 1259 times
Does anything appear on your index page? (purge the cache from the ACP before you look)
If not, can you go into the phpbb_alerts table in the database and post the number you see in the "alert_time" field.
havocwreaker
- Frequent Poster
I get this on the index page
The DB time is:
[phpBB Debug] PHP Notice: in file /index.php on line 135: Division by zero
[phpBB Debug] PHP Notice: in file /index.php on line 136: Division by zero
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4202: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3494)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4204: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3494)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4205: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3494)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 4206: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3494)Code: Select all
1265266800- Attachments
- Mod.pdf
- (713.56 KiB) Downloaded 1325 times
That certainly is very strange. I just want to confirm two things..
1) what does the forum clock say on the index page? is that showing the correct time or is that also slow?
2) what timezone have you selected in your profile?
To get rid of those other errors, in index.php FIND;
REPLACE WITH
$rsvp_yes_percent = number_format(($rsvp_yes / $rsvp_total), 0);
$rsvp_no_percent = number_format(($rsvp_no / $rsvp_total), 0);Code: Select all
$rsvp_yes_percent = ($rsvp_total < 1) ? 0 : number_format(($rsvp_yes / $rsvp_total), 0);
$rsvp_no_percent = ($rsvp_total < 1) ? 0 : number_format(($rsvp_no / $rsvp_total), 0);CricketMX.com in 2022: Still the home of bat's, rat's and other farmyard animals!
havocwreaker
- Frequent Poster
Index page time is: It is currently 06 Feb 2010, 03:22
Time Zone: UTC -8 Pacific Standard Time
havocwreaker
- Frequent Poster
Other errors gone.
Thank you for all of this help.
havocwreaker
- Frequent Poster
I'm going to have to go to bed now. My eyes are closing. I'll check this in the morning to see if there is anything I can troubleshoot. Thank you for staying around to assist me.
havocwreaker
- Frequent Poster
Any thoughts why this could be happening?
If you enter the exact same set of times here at CMX (UCP -> Alerts) as you do on your site, what results do you get?
Make sure the timezone you are in is the same, for consistency.
havocwreaker
- Frequent Poster
Wow,
I enter today's date and I get:
Your alert for Sat Feb 06, 2010 10:00 pm has been submitted to the database. You will be notified this many days before each event:
On the day
Day before
Could it be something with the Pacific time setting? It's weird that this site does the same as mine. Both go back 2 days.
On the day
Day before
