[WinMX] what can i do?
jctoad
Red XIII wrote:i did that and still no go :shock: this is beginning to piss me off :x
Format c: :?: I would back up files first though and get win xp or 2k to replace 98.
Don't count your toads until they're running around with their heads cut off.
Boozybaz
Alcoholic
Alcoholic
yer i 2nd that, you need to get away from win 98, XP is so much better and even 2k and ME are better, but i would reccomend a switch to XP
Red XIII
Sultan Ruler Of The Poles!
hrrrmmmm ill prolly do 2000, because 98SE/2000 are unarguably the 2 best windows OS' ever made 8)
Boozybaz
Alcoholic
Alcoholic
haha OMG what planet are you on???
i have used all windows since 95, 98 is good for what it is and does but come on you gotta go with the flow and update when updates come out
2k was crap
ME i actually liked and would go bhack to
but XP is easily the best and easiest to use, although it takes a while to adjust 2
Come on, jump on the XP band wagon Red. Your a loser if you don't :lol:
jctoad
If you had xp there would still be options to try to fix this problem, but with 98 there isn't much more you can do to try to fix it.
One and a half years on 98 is a pretty good life. It's time reformat. You can put it off, but there will be more strange problems coming down the road.
Boozybaz
Alcoholic
Alcoholic
agreed drop 98' and jump on the XP bandwagon, grinch is giving driving lessons
so ok you might fail the 1st 100 times, but you'll get there in the end :D
I've used the following:
95, 98, ME, XP Home. The one that I think is best is Windows ME, really it is! :roll:
I had Windows 3.1 all the way up to XP Pro. I've used all of them. I had success with Win ME, I wouldn't say that it was great but it was stable on my machine when all my friends had problems with it. My recommendation is that you go with XP. It is a really stable OS if you take care of it. When it crashes, it crashes cause I make it crash. IE still has it's problems though.
Boozybaz
Alcoholic
Alcoholic
ME is very good in my opinion..
XP home is ok but the hassle of activation is a bitch unless you get a original copy
XP pro is amazing i have a copy of XP pro no activation on the tracker all i gotta do is seed it and your away
Red XIII
ME sucked when i tried using it on my moms comp for a while, ive been using 98 for like 5 years now o.o idk ill put XP on here when i think ill absolutely need to format.
Myth!
i just heard this might be a problem with riched20.dll not registering.....vladds has some info apparently RedXIII
There are 10 kinds of people...those who understand binary and those who don't.
Red XIII
i searched and have both Riched.dll and riched20.dll what do i do to possibly cure it? get rid of one of em?
septic544
Dno if this will make me look stupid or ne fin but o well.... someone came into my room when i had it open a while back and asked me this... i told them to get the RICHED32.DLL and this person came back and told me this has cured the problem.... hope this helps :)
Great to see ya Sep!!
