Chatstartup.txt is used to preload commands into your channel as soon as it is opened instead of manually typing them all in.
Your problem with text replacement is this:
You cannot do that.Word[15]="Server=#c21#Server#c1#"
Word[15]="server=#c21#Server#c1#"
These aree inside the RCMConf.txt file, dont change these if you dont know what your doing, this is what is put into the channel as the commands are entered to either turn them on or off.$ReplaceTextOn$="Text Replace On"
$ReplaceTextOnNotify$="Text Replace Enabled!"
$ReplaceTextOff$="Text Replace Off"
$ReplaceTextOffNotify$="Text Replace Disabled!"
This is eddittable in the Config.ini file, to access these commands put your cursor into the chat bar and either press page up / page down or you can use that little scroller ball thing in the middle of your mouse to cycle through them, Hope this answers your questions[Commands]
CmdNum=81
Coment="KuruKuru Commands"
Cmd[0]="#usercmd redirect "
Yes, I use MXChat or Nushi Chat as most people know it by, if you go back to page 8 of this post you will see an addon for it that I modifed speficially for to be used with Ouka's server, you do not have to manually type any command in they can all be either executed or they will be inputed into the main chat bar ready for you to hit enter by right-clicking a users name from the userlistLunatic_UK1958 wrote: Users connect using WinMX, can co-hosts access any of the OUKA commands without having to type them?
