I just had a look at the code responsible for the stats, it might be a quick fix (it seemed to fix the problem here at CMX just then).
Open includes/quiz_stats_class.php
FIND:
		$sql = 'SELECT SUM(quiz_correct) AS sum_correct, SUM(quiz_incorrect) AS sum_incorrect, user_id FROM ' . QUIZ_STATISTICS_OVERVIEW_TABLE . '
				GROUP BY quiz_correct
				ORDER BY sum_correct DESC';
REPLACE WITH
				GROUP BY user_id
I'll get to the script question in a minute :)
subvertbeats
Your attention to detail is applaudable...ill check this now
edit: looks fixed here too!
Try this, open subvertbeats_quiz.php (control_quiz.php) and FIND:
foreach($users_names as $key => $val)
REPLACE WITH
				$counter = 0;
					if( $counter == 0 )
						$counter++;
						echo 'QUIZ ID: ' . $quiz_id_key . '<br />';
Then FIND:
					echo 'Info for ' . $val . ';<br />';
					echo '-- Correct: ' .  $correct_answers . '<br />';
					echo '-- Incorrect: ' .  $incorrect_answers . '<br />';
					echo '-- Quiz ID: ' . $quiz_id_key . '<br />';
REPLACE WITH
					echo $val . ' (correct: ' .  $correct_answers . ', incorrect: ' .  $incorrect_answers . ')<br />';
subvertbeats
I think we're almost there....
User Dent answered question 31 INCORRECTLY. They entered the answer F.
User subvertbeats answered question 31 CORRECTLY
User Dent answered question 30 INCORRECTLY. They entered the answer D.
User subvertbeats answered question 30 INCORRECTLY. They entered the answer D.
User Dent answered question 29 CORRECTLY
User subvertbeats answered question 29 INCORRECTLY. They entered the answer A.
QUIZ ID:
Dent (correct: 1, incorrect: 2)
subvertbeats (correct: 1, incorrect: 2)
SQL Query entered
So, QUIZ ID and QUIZ NAME are not being outputted (need these), and the per user per question responses are still being printed (want to get rid of these, ideally just by commenting out so can re-enable later if any debugging needed)
Sorry for the delay in replying, I was adding a new stats module (users with the highest quiz percentage) you can see it at http://forums.cricketmx.com/quiz.php?mode=stats (down the bottom).
To comment out the question parts... find these two lines and add // before them:
							echo 'User <strong>' . $user_name_fetch . '</strong> answered question <strong>' . $question_id_set[$i] . '</strong> CORRECTLY<br />';
							echo 'User <strong>' . $user_name_fetch . '</strong> answered question <strong>' . $question_id_set[$i] . '</strong> INCORRECTLY. They entered the answer <strong>' . $row['quiz_answer'] . '</strong>.<br />';
To fix the QUIZ_ID bit, find:
					if( $counter == 0 )
						$counter++;
BEFORE ADD (there is another instance of this a little bit below, below the $incorrect_answers line - you can remove that now).
$quiz_id_key = $users_information[$key]['quiz_id'];
To add the quiz name afterwards:
Now to add the QUIZ NAME...
REPLACE WITH
 echo 'QUIZ ID: ' . $quiz_id_key . ' QUIZ NAME: ' . get_quiz_title($quiz_id_key) . '<br />';
Let me know if that works.
subvertbeats
Ok.....
So, its all looking great.
One safety feature Id like to put in is for the stats for a given comp to be removed when you change the answers (i.e. to prevent stats being recorded twice).
In reality, it shouldnt happen - but human error could easily mean an incorrect result is submitted with the form, or a result may be overturned after the event, in which case we need to update the quiz with the new answer.
Currently, new statistics get added when you resubmit answers
if its too complex dont worry, I guess Im hoping its a simple thing to do.
One the enter answers page, the questions are still in an incorrect order.
Strange, as I cant see why that would be. Is it working of for you there?
Here is my completes control_quiz.php
// control_quiz.php
include($phpbb_root_path . 'includes/functions_quiz.' . $phpEx);
$user->session_begin();
$auth->acl($user->data);
   if( !$auth->acl_get('a_') )
      die('No access');
      if( $_GET['mode'] == 'deactivate' )
         $deactivate_id = (int) $_GET['id'];
         $sql = "UPDATE " . QUIZ_TABLE . " SET quiz_deactivate = 1
               WHERE quiz_id = $deactivate_id";
         $db->sql_query($sql);
         die('Quiz id ' . $deactivate_id . ' has been deactivated');
      if( $_GET['mode'] == 'activate' )
         $activate_id = (int) $_GET['id'];
         $sql = "UPDATE " . QUIZ_TABLE . " SET quiz_deactivate = 0
               WHERE quiz_id = $activate_id";
         die('Quiz id ' . $activate_id . ' has been activated');
      if( $_GET['mode'] == 'enter_answers' )
         if( $_GET['a'] == 'submit' )
            $question_id_hidden = $_POST['questions'];
            $question_id_set = explode(',', $question_id_hidden);
            $question_id_set_count = sizeof($question_id_set) - 1;
            $users = array();
            $users_information = array();
            $users_names = array();
            for($i = 0; $i < $question_id_set_count; $i++ )
                     WHERE quiz_question_id = ' . $question_id_set[$i] . '
                     ORDER BY quiz_question_id ASC';
                  $user_sql = 'SELECT username FROM ' . USERS_TABLE . '
                            WHERE user_id = ' . $row['quiz_player'];
                  $user_result = $db->sql_query($user_sql);
                  $user_name_fetch = $db->sql_fetchfield('username');
                  $db->sql_freeresult($user_result);
                  $users_names[$row['quiz_player']] = $user_name_fetch;
                  $is_correct = 0;
                  $is_incorrect = 0;
                  if( $row['quiz_answer'] == $_POST['question' . $question_id_set[$i]] )
                     // echo 'User <strong>' . $user_name_fetch . '</strong> answered question <strong>' . $question_id_set[$i] . '</strong> CORRECTLY<br />';
                     $users_information[$row['quiz_player']]['quiz_correct']++;
                     $users_information[$row['quiz_player']]['quiz_id'] = $row['quiz_id'];
                     $users_information[$row['quiz_player']]['info'] = 'Question ' . $question_id_set[$i] . ' correct';
                     // echo 'User <strong>' . $user_name_fetch . '</strong> answered question <strong>' . $question_id_set[$i] . '</strong> INCORRECTLY. They entered the answer <strong>' . $row['quiz_answer'] . '</strong>.<br />';
                     $users_information[$row['quiz_player']]['quiz_incorrect']++;
                     $users_information[$row['quiz_player']]['info'] = 'Question ' . $question_id_set[$i] . ' incorrect (' . $row['quiz_answer'] . ')';
            /* for( $j = 0, $j_count = sizeof($users); $j < $j_count; $j++ )
               echo 'Username: ' . $users_names[$users[$j]] . '<br />';
               echo '-- Correct: ' .  $users_information[$users[$j]]['quiz_correct'] . '<br />';
               echo '-- Incorrect: ' .  $users_information[$users[$j]]['quiz_incorrect'] . '<br />';
               echo '-- Quiz ID: ' .  $users_information[$users[$j]]['quiz_id'] . '<br />';
            $counter = 0;
               if( $counter == 0 )
                  $counter++;
               // $key is the user_id, $val is the username
               $correct_answers = ($users_information[$key]['quiz_correct']) ? $users_information[$key]['quiz_correct'] : 0;
               $incorrect_answers = ($users_information[$key]['quiz_incorrect']) ? $users_information[$key]['quiz_incorrect'] : 0;
               $statistical_overview_setup[] = array(
                  'quiz_id'         => (int) $quiz_id_key,
                    'quiz_correct'      => (int) $correct_answers,
                    'quiz_incorrect'   => (int) $incorrect_answers,
                  'user_id'         => (int) $key,
                  'quiz_time'         => (int) 0,
            $db->sql_multi_insert(QUIZ_STATISTICS_OVERVIEW_TABLE, $statistical_overview_setup);
            echo 'SQL Query entered';
            die();
         $quiz_id = (int) $_GET['id'];
         $sql = 'SELECT * FROM ' . QUIZ_QUESTIONS_TABLE . '
               WHERE quiz_related_id = ' . $quiz_id;
         echo '<form action="control_quiz.php?mode=enter_answers&id=' . $quiz_id . '&a=submit" method="post">';
         $question_id_hidden = '';
            $question_id_hidden .= $row['quiz_question_id'] . ',';
            echo '<strong>Question: ' . $row['quiz_question'] . '</strong><br />';
            // echo 'Correct answer: <input type="text" name="question' . $row['quiz_question_id'] . '" />';
            echo 'Correct answer:';
            $ans = 'SELECT quiz_answer FROM ' . QUIZ_DATA_TABLE . '
                  WHERE quiz_question_id = ' . $row['quiz_question_id'];
            $ans_res = $db->sql_query($ans);
            while( $ans_row = $db->sql_fetchrow($ans_res) )
               echo '<input type="radio" value="' . $ans_row['quiz_answer'] . '" name="question' . $row['quiz_question_id'] . '" /> ' . $ans_row['quiz_answer'] . '&nbsp;&nbsp;&nbsp;';
            echo '<br /><br />';
         echo '<input type="hidden" value="' . $question_id_hidden . '" name="questions" />';
         echo '<input type="submit" value="Submit" name="submit" />';
         echo '</form>';
         die(); // new
         echo 'Mode types:<br />
            <strong>control_quiz.php?mode=deactivate&id=XXX</strong><br />
            <strong>control_quiz.php?mode=activate&id=XXX</strong><br />
            <strong>control_quiz.php?mode=enter_answers&id=XXX</strong>';
         die();
You could remove all stats for a certain quiz with a single SQL query, run in phpMyAdmin:
DELETE FROM phpbb_quiz_statistics_overview WHERE quiz_id = XXX;
Then re-run the control_quiz script with the correct answer.
Does the incorrect order matter? It doesn't really have an effect on anything. I did try and order them by id, but it seems like quite a minor thing.
subvertbeats
It is indeed a minor thing, and with that SQL code to delete the stats for a given quiz ID I think we're set!
Ive updated the OP, and everything in Phase 1 seems to be taken care of!
subvertbeats
Ahh not quite there....
The correct/incorrect ordering seems wrong:
QUIZ ID: 8 QUIZ NAME: Heres my test comp
subvertbeats (correct: 2, incorrect: 1)
SQL Query entered
(in the above example subvertbeats should be above Dent, with less incorrect answers).
Is this working on your side?
edit: just fyi this is important because we get hundreds of users entering the comps, so proper sorting here enables us to easily find the winners, without risk of error
Hmm, okay. I don't want to go too far down this path because this could be a very timely exercise.
				$counter = 0;
				$highest_correct = 0;
AFTER ADD
				$output_array = array();
REPLACE WITH
					$output_array[$correct_answers][] = $val . ' (correct: ' .  $correct_answers . ', incorrect: ' .  $incorrect_answers . ')<br />';
					$highest_correct = ($correct_answers > $highest_correct) ? $correct_answers : $highest_correct;
BEFORE ADD
				for( $m = 0; $m <= $highest_correct; $m++ )
					$size_current_ca = sizeof($output_array[$m]);
					if( $size_current_ca > 0 )
						for( $n = 0; $n < $size_current_ca; $n++ )
							echo $output_array[$m][$n];
subvertbeats
Many thanks battye......Looks to be working, but in reverse:
QUIZ ID: 9 QUIZ NAME: Test Event
Kamara666 (correct: 0, incorrect: 3)
jnrpepaseed (correct: 1, incorrect: 2)
Dragonfoxy (correct: 1, incorrect: 2)
SQL Query entered
Is it simple to swap the order to be correct descending (aka incorrect ascending) ?
Find:
REPLACE WITH
for( $m = $highest_correct; $m >= 0; $m-- )
subvertbeats
In the spirit of the site....and to remember one of the greats
subvertbeats
One usage question on this battye....
If a match is cancelled, perhaps mid way through the week, when the comp is still open and lots of people have made their votes already, what is the correct procedure to remove that question from the comp (or mark it as invalid if removal is not possible), such that future entrants dont vote on that particular match, and most importantly, so the results for that particular match are not counted?
Thanks for your advice...
subvertbeats wrote:One usage question on this battye....
Subvertbeats...CMX's quiet achiever! :wink:
Congratulations on the Image rank that I missed at 25 posts...
and the new rank of Image you achieved at 50 posts! =D>
http://forums.cricketmx.com/viewtopic.p ... 221#p99221
