Hi,
Is there any progress on this and/or a final date for release? I've read through this topic and there appears to be a few mentions that a release was almost ready but as that timeframe spans a couple of months or so I wonder if there is any light at the end of this tunnel?
Many thanks.
-Z-
I intended on finishing it on Saturday but I came down with a dose of the flu. I'm working on the ACP section while I write this post...
Cheers
Cheers
Ok, good news everyone
I have now finished the MOD and I have sent it to the people in the beta testing group. If there are no problems I will be releasing it to the public shortly.
Thanks for your patience, we're almost there
very nice, thx battye.
Thank you battye
- quahappy
- Happy, not Quappy
If any beta testers are installing this for the first time, please remember to change the SQL table prefix to yours. The present sql_install.txt lists tables as phpbb3_. In most cases, unless you've renamed it for some reason, it should just be phpbb_
battye - Will you be implementing nav bar links? i.e. Board index > Ultimate Quiz :: Index, Board index > Ultimate Quiz :: Statistics, etc. So no matter where you are in UQM, it's easy to return to UQM front page? The main UQM link at my test site is within Menu links - see http://screwballscribble.co.uk/phpbb3testing/index.php.
Quiz ACP settings can be found in ACP > General > Board features.
Off to test all neccessary areas of UQM now.
Problem - can't locate where to create a category. I've attempted to create a quiz and while it asked me to select a Category (of which none exists at moment), it still submitted the quiz to the database.
Thank you everyone that replied
Watch this space, I will add it shortly
I've forgotten to add something very importantProblem - can't locate where to create a category.
same for mezorensen wrote:I really can't wait until this is released This is what I've been wainting for to my forums for ages... Do you know when you are going to release it for the public, battye?
Hi Folks, Battye
i´m translate the languagefiles (and found some bugs i´m translated, sorry) up to this versions.
Two suggestions:
- There isn't a backlink in the quiz_cp panel
- There isn't the section/link for/about the overall header template
language/de/mods/quiz.php
see next post 2nd file
Two suggestions:
* Ultimate Quiz MOD [English]
* @package language
* @version $Id: quiz.php, battye (c) 2004, 2005, 2008
* @copyright (c) 2008 battye, CricketMX.com
* @license http://opensource.org/licenses/gpl-license.php GNU Public License
* DO NOT CHANGE
if (!defined('IN_PHPBB'))
exit;
if (empty($lang) || !is_array($lang))
$lang = array();
// DEVELOPERS PLEASE NOTE
// All language files should use UTF-8 as their encoding and the files must not contain a BOM.
// Placeholders can now contain order information, e.g. instead of
// 'Page %s of %s' you can (and should) write 'Page %1$s of %2$s', this allows
// translators to re-order the output of data while ensuring it remains correct
// You do not need this where single placeholders are used, e.g. 'Message %d' is fine
// equally where a string contains only two placeholders which are used to wrap text
// in a url you again do not need to specify an order e.g., 'Click %sHERE%s' is fine
$lang = array_merge($lang, array(
'QUIZ' => 'Quiz',
// Various
'QUIZ_MUST_BE_LOGGED_IN' => 'Du musst registriert und eingeloggt sein um diese Seite zu sehen.',
'QUIZ_MUST_ADMIN_USER' => 'Nur Administratoren haben hier Zugriff.',
'QUIZ_USER_EDIT_OWN' => 'Als Benutzer kannst du nur dein eigenes Quiz editieren',
// Functions
'SELECT_A_CATEGORY' => 'Wähle eine Kategorie',
'SELECT_A_CATEGORY_EXPLAIN' => 'Wähle eine Kategorie welche das Genre vom Quiz am Besten trifft.',
// Submit quiz
'SELECT_NUMBER' => 'Anzahl der Fragen',
'SELECT_NUMBER_EXPLAIN' => 'Du darfst zwischen <strong>%1$s</strong> und <strong>%2$s</strong> Fragen in diesem Quiz stellen. Wieviele Fragen sollen gestellt werden?',
'SUBMIT_STEP_1' => 'Stufe 1 von 3 - Gib dein Quiz ein!',
'SUBMIT_STEP_2' => 'Stufe 2 von 3 - Gib deine Antworten ein!',
'SUBMIT_STEP_3' => 'Stufe 3 von 3 - Prüfe ob alles korrekt ist!',
'SUBMIT_QUIZ' => 'Quiz beitragen',
'SELECT_QUIZ_NAME' => 'Wähle einen Namen für dieses Quiz',
'SELECT_QUIZ_NAME_EXPLAIN' => 'Das ist der Name der in der Liste der Quizze erscheint. Wähle einen Namen der kurz genug ist aber der Lesern einen Eindruck davon gibt um was es im Quiz geht.',
'ENTER_QUESTION' => 'Gib deine Frage ein',
'IS_TRUE_FALSE' => 'wahr oder falsch Frage',
'MULTIPLE_CHOICE_QUESTION' => 'Multiple choice Frage',
'INPUT_ANSWER_QUESTION' => 'Input answer Frage',
'MULTIPLES_REVEAL' => 'Mehrfachrahmen',
'NOT_TRUE_FALSE' => 'Trenne die Mehrfachauswahl durch Hinzufügen einer neuen Mehrfachantwort auf einer neuen Zeile. Für ein nur Eingabequiz, einfach nur eine einzige Textzeile eingeben.',
'SUBMIT_INFORMATION' => 'Gib Fragen in jeder der nachfolgenden %1$s Felder ein. Für wahr und falsch Fragen, klick die Checkbox zum Beispiel - es muss dann nichts in die Box eingegeben werden. Wenn du die Fragen des Quiz eingibst, gib einfach die Antwort in die grosse Box ein. Für Mehrfachantworten musst du %2$s Alternativen eingeben, jede in einer neuen Zeile. Du wirst nach der richtigen gefragt, die du nach dem Absenden dieser Seite auswählen sollst.',
'VERIFY_SUBMIT_INFORMATION' => 'Für Mehrfachantworten wähle die richtige durch anklicken der box an der linken Seite. Für wahr und falsch Antworten wähle statt dessen wahr oder falsch. Eingabe Antworten müssen nicht geprüft werden, sie werden so genommen wie sie sind.',
'FINAL_VERIFY_SUBMIT' => 'Bitte prüfe alle Eingaben, wenn alle richtig sind klicke auf Absenden unten.',
'TRUE_FALSE_TRUE' => 'Wahr',
'TRUE_FALSE_FALSE' => 'Falsch',
'CORRECT_ANSWER' => 'Richtige Antwort',
'QUIZ_SUBMISSION_SUCCESSFUL' => 'Dein Quiz wurde erfolgreich in die Datenbank übernommen.<br /><br />%sZurück zur Quiz Index Seite.%s',
'OUTSIDE_QUESTION_PARAM' => 'Du hast keine Nummer zwischen <strong>%1$d</strong> und <strong>%2$d</strong> gewählt, geh zurück und versuche es nochmal.',
'NUMBER_QUESTIONS_UNDEFINED' => 'Die Nummer von Fragen in diesem Quiz ist nicht angegeben, bitte geh auf die vorherige Seite und korrigiere dies.',
'TOO_MANY_CHOICES' => 'Eine oder mehrere von deinen Mehrfachauswahlfragen besitzt <strong>mehr als %s</strong> Auswahlmöglichkeiten! Bitte entferne darüberliegende Auswahlen.<br /><br />',
'EMPTY_QUESTION' => 'Du hast eines oder mehrere Fragefelder leergelassen! Klicke den Zurückbutton in deinem Browser um auf die vorherige Seite zurückzukehren und stelle sicher das keine Felder leer gelassen werden.',
'EMPTY_ANSWER' => 'Du hast eines oder mehrere Antwortfelder leergelassen. Klicke den Zurückbutton in deinem Browser um auf die vorherige Seite zurückzukehren und stelle sicher das keine Felder leer gelassen werden.',
'EMPTY_QUIZ_FIELDS' => 'Du hast einige Felder leer gelassen! Stelle sicher das alle Felder richtig ausgefüllt werden.',
'EMPTY_RADIO_BOX' => 'Du hast eine oder mehrere radio Auswahlen nicht ausgewählt, das bedeutet, das du immer noch eine Mehrfachauswahl und/oder wahr falsch Antwort auswählen musst, <strong>oder</strong> du hast keinen Quiznamen oder Kategorie ausgewählt.',
// Index
'QUIZ_PASSWORD_PROTECTED_CAT' => 'Ein Password wird für die Kategorie benötigt',
'VIEW_QUIZ_CATEGORIES' => 'Wähle eine Kategorie',
'NUMBER_OF_QUIZ_INDEX_SINGLE' => '%d Quiz',
'NUMBER_OF_QUIZ_INDEX_PLURAL' => '%d Quizze',
'NUMBER_OF_QUIZ_VIEWS_SINGLE' => '%d Betrachter',
'NUMBER_OF_QUIZ_VIEWS_PLURAL' => '%d Betrachter',
'QUIZ_NAME' => 'Quizname',
'QUIZ_AUTHOR' => 'Autor',
'QUIZ_DATE' => 'Beitragsdatum',
'QUIZ_VIEWS' => 'Betrachtungen',
// Play quiz
'PLAY_QUIZ' => 'Spiel Quiz',
'QUIZ_SAVE' => 'Sichere Quiz',
'QUIZ_TIME_REMAINING' => 'Zeit verbleibend (Sekunden)',
'QUIZ_NO_TYPE_SUBMIT' => 'Dieses Quiz war weder gesichert noch beigetragen',
// Answers page
'SHOW_RESULTS_INCORRECT' => 'Du antwortest<strong>%s</strong><br />Die richtige Antwort war <strong>%s</strong>',
'SHOW_RESULTS_CORRECT' => 'Du antwortest richtig <strong>%s</strong>',
'TIME_SUMMARY' => 'Du löstest das Quiz in <strong>%d</strong> Sekunden',
'RESULTS_SUMMARY' => 'Richtige Antworten: <strong>%d</strong><br />Unrichtige Antworten: <strong>%d</strong>',
'QUIZ_RESULTS' => 'Quiz Resulate',
'QUIZ_TIME_EXCEEDED' => 'Du hast die erlaubte Zeit für dieses Quiz überschritten. Du brauchtest <strong>%d</strong> Sekunden. Deine Antworten wurden nicht gespeichert.',
'QUIZ_PROGRESS_SAVED' => 'Dieses Quiz wurde gespeichert. Du kannst es zu einem späteren Zeitpunkt fortsetzen',
'CHEATING_ATTEMPT' => 'Du siehst diese Meldung, weil eines von den folgenden Ereignissen erfolgte::<br /><br />- Ein Mogelversuch wurde festgestellt. Du kannst nicht ein Quiz verlassen und später es wieder aufnehmen ohne den Speicherprozess zu durchlaufen.<br />- Du hast versucht ein Quiz wieder beizutragen, dessen Zeitlimit ablief<br />- Du spieltest dieses Quiz schon und der Admin erlaubte keine Mehrfachversuche.',
'MULTIPLE_SUBMISSION' => 'Es scheint das du versucht hast dieses Quiz mehrfach beizutragen.',
// statistics
'QUIZ_STATISTICS' => 'Quiz Statistik',
'QUIZ_PLAYER' => 'Quiz Spieler',
'QUIZ_CORRECT' => 'Richtig ',
'QUIZ_INCORRECT' => 'Unrichtig ',
'QUIZ_PERCENTAGE' => 'Prozentzahl',
// statistic module names
'QUIZ_BEST_RESULTS_STATS' => 'Beste Resultate',
'QUIZ_MOST_PLAYED_STATS' => 'Meist gespielt',
'QUIZ_MOST_CORRECT_ANSWERS_STATS' => 'Meiste richtige Antworten',
// 'QUIZ_HIGH_PERCENT_ANSWERS_STATS' => 'Höchste Prozentzahl von richtigen Antworten',
// QUIZ_CP.PHP
'QUIZ_CP' => 'Quiz Kontrollseite',
'QUIZ_CP_LOWER' => 'Quiz Kontrollseite',
'QUIZ_MOVE' => 'Bewege',
'QUIZ_EDIT' => 'Editiere',
'QUIZ_DELETE' => 'Lösche',
'QUIZ_DELETE_ASK' => 'Lösche das Quiz',
'QUIZ_DELETE_ASK_CONFIRM' => 'Bist du dir sicher dies Quiz zu löschen?',
'QUIZ_DELETE_SUCCESSFUL' => 'Das Quiz wurde erfolgreich aus der Datenbank entfernt.<br /><br />%sZurück zur Quiz Kontrollseite.%s',
'QUIZ_MOVE_ASK' => 'Verschiebe dieses Quiz',
'QUIZ_MOVE_ASK_CONFIRM' => 'In welche Kategorie soll das Quiz verschoben werden? Wenn du soweit bist, drücke Eingabe. Die Kategorie ist derzeit in: <strong>%s</strong>',
'QUIZ_MOVE_TO' => 'Verschiebe von <strong>%s</strong> nach:',
'QUIZ_MOVE_SUCCESSFUL' => 'Das Quiz wurde erfolgreich verschoben.<br /><br />%sZurück zur Quiz Kontrollseite.%s',
'QUIZ_MOVE_UNSUCCESSFUL' => 'Du hast keine Kategorie ausgesucht. Bitte klick den Zurückknopf im Browser um zur vorherigen Seite zurückzukehren.',
'QUIZ_EDIT_ASK' => 'Editiere dieses Quiz',
'QUIZ_EDIT_ASK_CONFIRM' => 'Editiere die untenstehenden Optionen und klick Eingabe wenn du fertig bis. Vergesse nicht das Kästchen der richtigen Antwort anzukreuzen.',
'QUIZ_EDIT_SUCCESSFUL' => 'Das Quiz wurde erfolgreich editiert.<br /><br />%sZurück zur Quiz Kontrollseite.%s',
language/de/acp/board.php
Good Work ... testing now.
* acp_board [Deutsch — Du]
* @package language
* @version $Id: board.php 192 2007-05-17 19:54:57Z philipp $
* @copyright (c) 2005 phpBB Group; 2006 phpBB.de
* Deutsche Ãœbersetzung durch die Ãœbersetzer-Gruppe von phpBB.de:
* (http://www.phpbb.de/go/3/uebersetzer)
* Frank Doerr, Dirk Gaffke, Christopher Gerharz, Ingo Köhler, Philipp Kordowich, Ingo Migliarina, Paul Rauch
* DO NOT CHANGE
exit;
$lang = array();
// Board Settings
'ACP_BOARD_SETTINGS_EXPLAIN' => 'Hier kannst du einige grundlegende Einstellungen deines Boards vornehmen, ihm einen passenden Namen und eine Beschreibung geben und, neben anderen Werten, die Standard-Einstellungen für Zeitzone und Sprache anpassen.',
'CUSTOM_DATEFORMAT' => 'Eigenes …',
'DEFAULT_DATE_FORMAT' => 'Datumsformat',
'DEFAULT_DATE_FORMAT_EXPLAIN' => 'Die Syntax entspricht der der <a href="http://www.php.net/date"><code>date()</code></a>-Funktion von PHP.',
'DEFAULT_LANGUAGE' => 'Standard-Sprache',
'DEFAULT_STYLE' => 'Standard-Style',
'DISABLE_BOARD' => 'Board deaktivieren',
'DISABLE_BOARD_EXPLAIN' => 'Hiermit sperrst du das Board für alle Benutzer. Wenn du möchtest, kannst du eine kurze Nachricht (bis zu 255 Zeichen) angeben.',
'OVERRIDE_STYLE' => 'Benutzer-Style überschreiben',
'OVERRIDE_STYLE_EXPLAIN' => 'Verwendet den Standard-Style statt den individuell von den Benutzern gewählten Styles.',
//MOD Forum Statistics
'ALLOW_GUESTS_VIEW_FS' => 'Erlaube Gästen die deaillierte Forum Statistik',
//END MOD
'SITE_DESC' => 'Beschreibung des Boards',
'SITE_NAME' => 'Name des Boards',
'SYSTEM_DST' => 'Automatische Sommerzeit',
'SYSTEM_TIMEZONE' => 'Zeitzone',
//Welcome_Mod language settings_->
'TIME_OF_DAY_MESSAGE' => 'Zeit der Tagesnachricht',
'TIME_AFTERNOON' => 'Nachmittagzeit',
'TIME_AFTERNOON_EXPLAIN' => 'Anzeigenachricht an die Benutzer zwischen 12:00 ~ 18:00',
'TIME_EARLY' => 'Vormittagszeit',
'TIME_EARLY_EXPLAIN' => 'Anzeigenachricht an die Benutzer zwischen 5:00 ~ 7:59',
'TIME_EVENING' => 'Abendzeit',
'TIME_EVENING_EXPLAIN' => 'Anzeigenachricht an die Benutzer zwischen 18:00 ~ 23:59',
'TIME_LATE' => 'Nachtzeit',
'TIME_LATE_EXPLAIN' => 'Anzeigenachricht an die Benutzer zwischen 0:00 ~ 4:59',
'TIME_MORNING' => 'Morgenzeit',
'TIME_MORNING_EXPLAIN' => 'Anzeigenachricht an die Benutzer zwischen 8:00 ~ 11:59',
//End-Welcome_Mod language settings-->
'WARNINGS_EXPIRE' => 'Gültigkeit von Verwarnungen',
'WARNINGS_EXPIRE_EXPLAIN' => 'Die Anzahl der Tage, nach denen eine Verwarnung automatisch aus dem Benutzer-Profil gelöscht wird.',
// Board Features
'ACP_BOARD_FEATURES_EXPLAIN' => 'Hier kannst du einige Funktionen des Boards aktivieren bzw. deaktivieren.',
'QUIZ_SUBMIT_MIN_SETTING' => 'minimale Anzahl von Fragen',
'QUIZ_SUBMIT_MIN_EXPLAIN' => 'minimale Anzahl von Fragen bei Quiz erlaubt.',
'QUIZ_SUBMIT_MAX_SETTING' => 'maximale Anzahl von Fragen',
'QUIZ_SUBMIT_MAX_EXPLAIN' => 'maximale Anzahl von Fragen bei Quiz erlaubt.',
'QUIZ_SUBMIT_MAX_MULTIPLE_CHOICE_SETTING' => 'maximale Anzahl von Auswahlen',
'QUIZ_SUBMIT_MAX_MULTIPLE_CHOICE_SETTING_EXPLAIN' => 'maximale Anzahl von Auswahlen bei Quiz erlaubt.',
'QUIZ_SAVED_ENABLED_SETTING' => 'Erlaube gespeicherte Quizze',
'QUIZ_SAVED_ENABLED_SETTING_EXPLAIN' => 'Können Benutzer Quiz speichern und fortsetzen?',
'QUIZ_SHOW_ANSWERS_SETTING' => 'Zeige Antworten',
'QUIZ_SHOW_ANSWERS_SETTING_EXPLAIN' => 'Sollten Benutzern die richtigen Antworten gezeigt werden?',
'QUIZ_TIME_LIMIT_PER_QUESTION_SETTING' => 'Zeitlimit per Frage',
'QUIZ_TIME_LIMIT_PER_QUESTION_SETTING_EXPLAIN' => 'Wie lange haben Benutzer Zeit zum Beantworten einer Frage? 0 zum abschalten.',
'QUIZ_SHOW_HOW_MANY_STATS_SETTING' => 'Statistiklisten',
'QUIZ_SHOW_HOW_MANY_STATS_SETTING_EXPLAIN' => 'Wie viele Resultate sollen per Statistikliste angezeigt werden?',
'QUIZ_USER_EDIT_OWN_QUIZ_SETTING' => 'Editiere eigenes Quiz',
'QUIZ_USER_EDIT_OWN_QUIZ_SETTING_EXPLAIN' => 'Können Benutzer ihr eigenes Quiz editieren/verschieben/löschen?',
'ALLOW_ATTACHMENTS' => 'Dateianhänge erlauben',
'ALLOW_BIRTHDAYS' => 'Geburtstage aktivieren',
'ALLOW_BIRTHDAYS_EXPLAIN' => 'Aktiviert die Eingabe von Geburtstagen und die Anzeige des Alters im Profil. Beachte, dass für die Geburtstagsanzeige in der Foren-Übersicht eine getrennte Option in den Einstellungen zur Serverlast existiert.',
'ALLOW_BOOKMARKS' => 'Setzen von Lesezeichen für Themen erlauben',
'ALLOW_BOOKMARKS_EXPLAIN' => 'Der Benutzer darf persönliche Lesezeichen speichern.',
'ALLOW_BBCODE' => 'BBCode erlauben',
'ALLOW_FORUM_NOTIFY' => 'Beobachten von Foren erlauben',
'ALLOW_NAME_CHANGE' => 'Namenswechsel erlauben',
'ALLOW_NO_CENSORS' => 'Deaktivieren der Wortzensur erlauben',
'ALLOW_NO_CENSORS_EXPLAIN' => 'Benutzer können die automatische Wortzensur in Beiträgen und Privaten Nachrichten deaktivieren.',
'ALLOW_PM_ATTACHMENTS' => 'Dateianhänge in Privaten Nachrichten erlauben',
'ALLOW_SIG' => 'Signaturen erlauben',
'ALLOW_SIG_BBCODE' => 'BBCode in Signaturen erlauben',
'ALLOW_SIG_FLASH' => 'BBCode-Tag <code>flash</code> in Signaturen erlauben',
'ALLOW_SIG_IMG' => 'BBCode-Tag <code>img</code> in Signaturen erlauben',
'ALLOW_SIG_LINKS' => 'Links in Signaturen erlauben',
'ALLOW_SIG_LINKS_EXPLAIN' => '„Nein“ deaktiviert den <code>[URL]</code> BBCode-Tag und die automatische Verlinkung von URLs.',
'ALLOW_SIG_SMILIES' => 'Smilies in Signaturen erlauben',
'ALLOW_SMILIES' => 'Smilies erlauben',
'ALLOW_TOPIC_NOTIFY' => 'Beobachten von Themen erlauben',
'BOARD_PM' => 'Private Nachrichten',
'BOARD_PM_EXPLAIN' => 'Aktiviert oder deaktiviert Private Nachrichten für alle Benutzer.',
// Avatar Settings
'ACP_AVATAR_SETTINGS_EXPLAIN' => 'Avatare sind im Allgemeinen kleine, einzigartige Bilder, mit denen sich die Mitglieder identifizieren können. Abhängig vom Style werden diese Bilder normalerweise unter dem Benutzernamen angezeigt, wenn Themen betrachtet werden. Hier kannst du die Art der Avatar-Nutzung festlegen. Bitte denke daran, dass du das von dir angegebene Verzeichnis erstellen und sicherstellen musst, dass es vom Webserver beschreibbar ist, damit Avatare hochgeladen werden können. Bedenke außerdem, dass Dateigrößen-Beschränkungen nur bei hochgeladenen Avataren greifen, nicht jedoch bei von anderen Seiten verlinkten Bildern.',
'ALLOW_LOCAL' => 'Galerie-Avatare erlauben',
'ALLOW_REMOTE' => 'Remote-Avatare erlauben',
'ALLOW_REMOTE_EXPLAIN' => 'Avatare, die von einer anderen Website verlinkt werden.',
'ALLOW_UPLOAD' => 'Hochladen von Avataren erlauben',
'AVATAR_GALLERY_PATH' => 'Avatar-Galeriepfad',
'AVATAR_GALLERY_PATH_EXPLAIN' => 'Der Pfad von deinem phpBB-Hauptverzeichnis aus, in dem die Galerie-Avatare liegen (z. B. <samp>images/avatars/gallery</samp>).',
'AVATAR_STORAGE_PATH' => 'Avatar Speicherpfad',
'AVATAR_STORAGE_PATH_EXPLAIN' => 'Der Pfad von deinem phpBB-Hauptverzeichnis aus, in dem die Avatare gespeichert werden (z. B. <samp>images/avatars/upload</samp>).',
'MAX_AVATAR_SIZE' => 'Maximale Abmessungen für Avatare',
'MAX_AVATAR_SIZE_EXPLAIN' => 'Breite × Höhe in Pixel',
'MAX_FILESIZE' => 'Maximale Dateigröße',
'MAX_FILESIZE_EXPLAIN' => 'Für hochgeladene Avatare.',
'MIN_AVATAR_SIZE' => 'Minimale Abmessungen für Avatare',
'MIN_AVATAR_SIZE_EXPLAIN' => 'Breite × Höhe in Pixel',
// Message Settings
'ACP_MESSAGE_SETTINGS_EXPLAIN' => 'Hier kannst du alle Standard-Einstellungen für Private Nachrichten vornehmen.',
'ALLOW_BBCODE_PM' => 'BBCode in Privaten Nachrichten erlauben',
'ALLOW_FLASH_PM' => 'BBCode-Tag <code>[FLASH]</code> in Privaten Nachrichten erlauben',
'ALLOW_FLASH_PM_EXPLAIN' => 'Die Möglichkeit, Flash in Privaten Nachrichten zu verwenden, hängt auch von den gesetzten Berechtigungen ab.',
'ALLOW_FORWARD_PM' => 'Weiterleiten von Privaten Nachrichten erlauben',
'ALLOW_IMG_PM' => 'BBCode-Tag <code>[IMG]</code> in Privaten Nachrichten erlauben',
'ALLOW_MASS_PM' => 'Versand von Privaten Nachrichten an mehrere Mitglieder oder Gruppen erlauben',
'ALLOW_MASS_PM_EXPLAIN' => 'Sending to groups can be adjusted per group within the group settings page.',
'ALLOW_PRINT_PM' => 'Druckansicht in Privaten Nachrichten erlauben',
'ALLOW_QUOTE_PM' => 'Zitate in Privaten Nachrichten erlauben',
'ALLOW_SIG_PM' => 'Signatur in Privaten Nachrichten erlauben',
'ALLOW_SMILIES_PM' => 'Smilies in Privaten Nachrichten erlauben',
'BOXES_LIMIT' => 'Maximale Anzahl von Nachrichten pro Ordner',
'BOXES_LIMIT_EXPLAIN' => 'Benutzer können in einem Ordner nicht mehr als die hier festgelegte Anzahl an Privaten Nachrichten ablegen. Um eine unbegrenzte Anzahl zuzulassen, stelle als Wert 0 ein.',
'BOXES_MAX' => 'Maximale Anzahl an Ordnern',
'BOXES_MAX_EXPLAIN' => 'Standardmäßig können Benutzer diese Anzahl an persönlichen Ordnern für Private Nachrichten erstellen.',
'ENABLE_PM_ICONS' => 'Die Nutzung von Themen-Symbolen in Privaten Nachrichten aktivieren',
'FULL_FOLDER_ACTION' => 'Standard-Verhalten bei vollem Ordner',
'FULL_FOLDER_ACTION_EXPLAIN'=> 'Das standardmäßige Verhalten, wenn der Ordner eines Benutzers voll ist und die von ihm eingestellte Aktion nicht durchführbar ist bzw. diese nicht festgelegt wurde. Eine Ausnahme gilt für den Ordner „Gesendete Nachrichten“, wo das Standard-Verhalten immer so eingestellt ist, dass alte Nachrichten gelöscht werden.',
'HOLD_NEW_MESSAGES' => 'Neue Nachrichten zurückhalten',
'PM_EDIT_TIME' => 'Nachträgliche Bearbeitung einschränken',
'PM_EDIT_TIME_EXPLAIN' => 'Limitiert die Zeit zur Bearbeitung einer gesendeten, aber noch ungelesenen Privaten Nachricht. Um dieses Verhalten abzuschalten, stelle als Wert 0 ein.',
'PM_MAX_RECIPIENTS' => 'Maximale Anzahl zulässiger Empfänger',
'PM_MAX_RECIPIENTS_EXPLAIN' => 'Die maximale Anzahl zulässiger Empfänger für eine Private Nachricht. Bei einem Wert von 0 sind unbegrenzt viele Empfänger zulässig. Diese Einstellung kann gruppenbezogen in den Gruppeneinstellungen angepasst werden.',
// Post Settings
'ACP_POST_SETTINGS_EXPLAIN' => 'Hier kannst du alle Standard-Einstellungen für Beiträge vornehmen.',
'ALLOW_POST_LINKS' => 'Links in Beiträgen/Privaten Nachrichten erlauben',
'ALLOW_POST_LINKS_EXPLAIN' => '„Nein“ deaktiviert den <code>[URL]</code> BBCode-Tag und die automatische Verlinkung von URLs.',
'ALLOW_POST_FLASH' => 'BBCode-Tag <code>[FLASH]</code> in Beiträgen erlauben',
'ALLOW_POST_FLASH_EXPLAIN' => 'Wenn deaktiviert, ist der <code>[FLASH]</code> BBCode-Tag in Beiträgen deaktiviert. Andernfalls wird durch das Berechtigungssystem festgelegt, welche Benutzer den <code>[FLASH]</code> BBCode-Tag benutzen können.',
'ENABLE_QUEUE_TRIGGER' => 'Enable queued posts',
'ENABLE_QUEUE_TRIGGER_EXPLAIN' => 'Ability to put registered users posts to post approval if their post count is lower than the specified value below. This setting has no effect on the permission setting for post/topic approval.',
'QUEUE_TRIGGER_POSTS' => 'Maximum post count for queued posts',
'QUEUE_TRIGGER_POSTS_EXPLAIN' => 'If queued posts is enabled, this is the post count the user need to reach in order to post without post approval. If the users post count is below this number, the post is stored in the queue automatically.',
'BUMP_INTERVAL' => 'Neu-Markierung möglich nach',
'BUMP_INTERVAL_EXPLAIN' => 'Die Zahl der Minuten, Stunden oder Tage, die seit dem letzten Beitrag zu einem Thema vergangen sein müssen, damit das Thema als „Neu“ markiert werden kann.',
'CHAR_LIMIT' => 'Maximale Anzahl der Zeichen pro Beitrag',
'CHAR_LIMIT_EXPLAIN' => 'Die maximale Zahl von Zeichen, die in einem Beitrag zulässig sind; 0 bedeutet unbegrenzt.',
'DISPLAY_LAST_EDITED' => 'Bearbeitungen anzeigen',
'DISPLAY_LAST_EDITED_EXPLAIN' => 'Wähle aus, ob die Information „Zuletzt bearbeitet von“ in Beiträgen angezeigt werden soll.',
'EDIT_TIME' => 'Nachträgliche Bearbeitung einschränken',
'EDIT_TIME_EXPLAIN' => 'Limitiert die Zeit, in der ein neuer Beitrag bearbeitet werden kann; 0 bedeutet unbegrenzt.',
'FLOOD_INTERVAL' => 'Wartezeit zwischen zwei Beiträgen',
'FLOOD_INTERVAL_EXPLAIN' => 'Die Zeit in Sekunden, die ein Benutzer warten muss, bevor er einen neuen Beitrag schreiben kann. Wenn du Benutzern erlauben möchtest, die Wartezeit zu umgehen, musst du deren Befugnisse anpassen.',
'HOT_THRESHOLD' => 'Grenzwert für beliebte Themen',
'HOT_THRESHOLD_EXPLAIN' => 'Anzahl der Beiträge in einem Thema, bis es als „beliebtes Thema“ angezeigt wird. Um beliebte Themen zu deaktivieren, stelle als Wert 0 ein.',
'MAX_POLL_OPTIONS' => 'Maximale Anzahl an Umfrage-Optionen',
'MAX_POST_FONT_SIZE' => 'Maximale Schriftgröße in Beiträgen',
'MAX_POST_FONT_SIZE_EXPLAIN' => 'Maximal in Beiträgen zulässige Schriftgröße. Um keine Begrenzung festzulegen, stelle als Wert 0 ein.',
'MAX_POST_IMG_HEIGHT' => 'Maximale Bild-Höhe in Beiträgen',
'MAX_POST_IMG_HEIGHT_EXPLAIN' => 'Die maximale Höhe eines Bildes/einer Flash-Datei in Beiträgen. Um keine Begrenzung festzulegen, stelle als Wert 0 ein.',
'MAX_POST_IMG_WIDTH' => 'Maximale Bild-Breite in Beiträgen',
'MAX_POST_IMG_WIDTH_EXPLAIN' => 'Die maximale Breite eines Bildes/einer Flash-Datei in Beiträgen. Um keine Begrenzung festzulegen, stelle als Wert 0 ein.',
'MAX_POST_URLS' => 'Maximale Anzahl an Links pro Beitrag',
'MAX_POST_URLS_EXPLAIN' => 'Maximale Anzahl von Links in einem Beitrag. Um keine Begrenzung festzulegen, stelle als Wert 0 ein.',
'POSTING' => 'Beiträge schreiben',
'POSTS_PER_PAGE' => 'Beiträge pro Seite',
'QUOTE_DEPTH_LIMIT' => 'Maximale Anzahl verschachtelter Zitate',
'QUOTE_DEPTH_LIMIT_EXPLAIN' => 'Die maximale Zahl an ineinander verschachtelten Zitaten in einem Beitrag. Um keine Begrenzung festzulegen, stelle als Wert 0 ein.',
'SMILIES_LIMIT' => 'Maximale Smilies pro Beitrag',
'SMILIES_LIMIT_EXPLAIN' => 'Die maximale Anzahl an Smilies in einem Beitrag. Um keine Begrenzung festzulegen, stelle als Wert 0 ein.',
'TOPICS_PER_PAGE' => 'Themen pro Seite',
// Signature Settings
'ACP_SIGNATURE_SETTINGS_EXPLAIN' => 'Hier kannst du alle Standard-Einstellungen für Signaturen vornehmen.',
'MAX_SIG_FONT_SIZE' => 'Maximale Schriftgröße',
'MAX_SIG_FONT_SIZE_EXPLAIN' => 'Die maximal erlaubte Schriftgröße, die ein Benutzer für seine Signatur verwenden kann. Um keine Begrenzung festzulegen, stelle als Wert 0 ein.',
'MAX_SIG_IMG_HEIGHT' => 'Maximale Bild-Höhe',
'MAX_SIG_IMG_HEIGHT_EXPLAIN' => 'Die maximal erlaubte Höhe einer Bild- oder Flash-Datei in der Signatur. Um keine Begrenzung festzulegen, stelle als Wert 0 ein.',
'MAX_SIG_IMG_WIDTH' => 'Maximale Bild-Breite',
'MAX_SIG_IMG_WIDTH_EXPLAIN' => 'Die maximal erlaubte Breite einer Bild- oder Flash-Datei in der Benutzer-Signatur. Um keine Begrenzung festzulegen, stelle als Wert 0 ein.',
'MAX_SIG_LENGTH' => 'Maximale Länge',
'MAX_SIG_LENGTH_EXPLAIN' => 'Die maximal erlaubte Anzahl an Zeichen in der Signatur.',
'MAX_SIG_SMILIES' => 'Maximale Smilies',
'MAX_SIG_SMILIES_EXPLAIN' => 'Die maximal erlaubte Anzahl an Smilies in der Signatur. Um keine Begrenzung festzulegen, stelle als Wert 0 ein.',
'MAX_SIG_URLS' => 'Maximale Links',
'MAX_SIG_URLS_EXPLAIN' => 'Die maximal erlaubte Anzahl der Links in der Signatur. Um keine Begrenzung festzulegen, stelle als Wert 0 ein.',
// Custom Title Settings
'ACP_CUSTOM_TITLE_SETTINGS_EXPLAIN' => 'Hier kannst du alle Benutzertitel einstellen.',
'CUSTOM_TITLE_MODE' => 'Rang Ersetz Modus',
'CUSTOM_TITLE_MODE_EXPLAIN' => 'Hier kannst du angeben ob der Rang oder das Rangbild ersetzt werden soll wenn der Benutzer einen Benutzertitel hat. Wenn du \'Keine Ersetzung\',waehlst wird er als separierter Titel angezeigt.',
'CUSTOM_TITLE_MODE_INDEPENDENT' => 'Keine Ersetzung',
'CUSTOM_TITLE_MODE_REPLACE_RANK' => 'Nur Rang ersetzen',
'CUSTOM_TITLE_MODE_REPLACE_BOTH' => 'Ersetze Rang und Bild',
'CUSTOM_TITLE_DAYS' => 'Tage der Registrierung erforderlich',
'CUSTOM_TITLE_POSTS' => 'Posts erforderlich',
'CUSTOM_TITLE_MAXLENGTH' => 'Maximale Laenge',
'CUSTOM_TITLE_MAXLENGTH_EXPLAIN' => 'Dies kontrolliert die max Laenge die ein Benutzerer Titel haben kann. Gib eine Nummer von 0 bis 255 an.',
// Registration Settings
'AB_ANSWER' => 'Anti-Bot Antwort',
'AB_ANSWER_EXPLAIN' => 'Dies ist die Hauptantwort der Frage.',
'AB_ANSWER_2' => 'Anti-Bot Antwort Zwei',
'AB_ANSWER_2_EXPLAIN' => 'Hier kannst du eine zweite Antwort beantworten, eine gute Idee bei einer numerischen Frage.',
'AB_QUESTION_MOD' => 'Anti-Bot Frage',
'AB_QUESTION' => 'Anti-Bot Frage',
'AB_QUESTION_EXPLAIN' => 'Dies ist die Frage die der User zum registrieren beantworten muss.',
'ABQ_ENABLE' => 'Anti-Bot Frage einschalten',
'ABQ_ENABLE_EXPLAIN' => 'Anti-Bot Frage bei Registrierung einschalten.',
'ACP_REGISTER_SETTINGS_EXPLAIN' => 'Hier kannst du Einstellungen bezüglich der Registrierung und der Mitgliederprofile vornehmen.',
'ACC_ACTIVATION' => 'Benutzerkonto-Aktivierung',
'ACC_ACTIVATION_EXPLAIN' => 'Diese Einstellung legt fest, ob Benutzer sofortigen Zugang zum Board haben, oder ob eine Bestätigung erforderlich ist. Du kannst neue Registrierungen auch komplett deaktivieren.',
'ACC_ADMIN' => 'durch Administrator',
'ACC_DISABLE' => 'Deaktiviert',
'ACC_NONE' => 'Keine',
'ACC_USER' => 'durch Benutzer',
// 'ACC_USER_ADMIN' => 'User + Admin',
'ALLOW_EMAIL_REUSE' => 'Mehrfachnutzung der E-Mail-Adresse erlauben',
'ALLOW_EMAIL_REUSE_EXPLAIN' => 'Mehrere Benutzer können sich mit derselben E-Mail-Adresse registrieren.',
'COPPA' => 'COPPA',
'COPPA_FAX' => 'COPPA-Fax-Nummer',
'COPPA_MAIL' => 'COPPA-Post-Adresse',
'COPPA_MAIL_EXPLAIN' => 'Dies ist die Adresse, zu der Eltern die COPPA-Registrierungsformulare senden können.',
'ENABLE_COPPA' => 'COPPA aktivieren',
'ENABLE_COPPA_EXPLAIN' => 'Dadurch müssen Benutzer erklären, ob sie 13 Jahre oder älter sind, um dem amerikanischen COPPA nachzukommen. Wenn diese Einstellung deaktiviert ist, werden die COPPA-spezifischen Gruppen nicht angezeigt.',
'MAX_CHARS' => 'Max.',
'MIN_CHARS' => 'Min.',
'NO_AUTH_PLUGIN' => 'Keine passende Authentifizierungs-Methode gefunden.',
'PASSWORD_LENGTH' => 'Passwortlänge',
'PASSWORD_LENGTH_EXPLAIN' => 'Die minimale und maximale Anzahl an Zeichen in Passwörtern.',
'REG_LIMIT' => 'Registrierungs-Versuche',
'REG_LIMIT_EXPLAIN' => 'Die Zahl der Versuche, die ein Benutzer für die Eingabe des Bestätigungscodes hat, bevor er für die Session gesperrt wird.',
'USERNAME_ALPHA_ONLY' => 'Nur alphanumerische Zeichen',
'USERNAME_ALPHA_SPACERS' => 'Alphanumerische Zeichen und Füllzeichen',
'USERNAME_ASCII' => 'ASCII (keine internationalen Unicode-Zeichen)',
'USERNAME_LETTER_NUM' => 'Alle Buchstaben und Ziffern',
'USERNAME_LETTER_NUM_SPACERS' => 'Alle Buchstaben, Ziffern und Füllzeichen',
'USERNAME_CHARS' => 'Erlaubte Zeichen in Benutzernamen',
'USERNAME_CHARS_ANY' => 'Alle Zeichen',
'USERNAME_CHARS_EXPLAIN' => 'Legt fest, welche Zeichen in Benutzernamen genutzt werden können. Füllzeichen sind: Leerzeichen, -, +, _, [ und ].',
'USERNAME_LENGTH' => 'Länge des Benutzernamens',
'USERNAME_LENGTH_EXPLAIN' => 'Die minimale und maximale Anzahl an Zeichen in Benutzernamen.',
// Visual Confirmation Settings
'ACP_VC_SETTINGS_EXPLAIN' => 'Hier kannst du die Einstellungen zu CAPTCHA und dem visuellem Bestätigungscode vornehmen.',
'CAPTCHA_GD' => 'GD CAPTCHA',
'CAPTCHA_GD_FOREGROUND_NOISE' => 'GD CAPTCHA Vordergrund-Rauschen',
'CAPTCHA_GD_EXPLAIN' => 'Verwendet die GD-Library, um erweiterte CAPTCHA-Codes zu erstellen.',
'CAPTCHA_GD_FOREGROUND_NOISE_EXPLAIN' => 'Fügt den auf der GD-Library basierenden CAPTCHA-Codes ein Vordergrund-Rauschen hinzu, um eine automatische Erkennung zu erschweren.',
'CAPTCHA_GD_X_GRID' => 'GD CAPTCHA Hintergrund-Rauschen x-Achse',
'CAPTCHA_GD_X_GRID_EXPLAIN' => 'Verwende einen niedrigeren Wert, um das GD-basierte CAPTCHA schwerer zu machen. 0 deaktiviert das Hintergrund-Rauschen auf der x-Achse.',
'CAPTCHA_GD_Y_GRID' => 'GD CAPTCHA Hintergrund-Rauschen Y-Achse',
'CAPTCHA_GD_Y_GRID_EXPLAIN' => 'Verwende einen niedrigeren Wert, um das GD-basierte CAPTCHA schwerer zu machen. 0 deaktiviert das Hintergrund-Rauschen auf der y-Achse.',
'CAPTCHA_GD_WAVE' => 'GD CAPTCHA Wellen-Verzerrung',
'CAPTCHA_GD_WAVE_EXPLAIN' => 'Fügt den CAPTCHA-Codes eine Wellen-Verzerrung hinzu.',
'CAPTCHA_GD_3D_NOISE' => '3D-Rauschen hinzufügen',
'CAPTCHA_GD_3D_NOISE_EXPLAIN' => 'Fügt zusätzliche Objekte über den CAPTCHA-Codes hinzu.',
'CAPTCHA_GD_FONTS' => 'Unterschiedliche Schriften nutzen',
'CAPTCHA_GD_FONTS_EXPLAIN' => 'Diese Einstellung legt fest, wie viele verschiedene Schriftformen genutzt werden. Du kannst nur die Standard-Formen nutzen oder neue Formen aktivieren. Es können auch Kleinbuchstaben hinzugefügt werden.',
'CAPTCHA_FONT_DEFAULT' => 'Standard',
'CAPTCHA_FONT_NEW' => 'Neue Formen',
'CAPTCHA_FONT_LOWER' => 'Auch Kleinbuchstaben',
'CAPTCHA_PREVIEW_MSG' => 'Deine Änderungen an den Einstellungen des Bestätigungscodes wurden nicht gespeichert. Dies ist nur eine Vorschau.',
'CAPTCHA_PREVIEW_EXPLAIN' => 'So wird der Bestätigungscode mit den aktuellen Einstellungen aussehen. Du kannst ihn mit „Vorschau“ aktualisieren. Beachte, dass der Bestätigungscode zufällig erstellt wird und von dem hier angezeigten abweichen wird.',
'VISUAL_CONFIRM_POST' => 'Visuellen Bestätigungscode für Beiträge von Gästen aktivieren',
'VISUAL_CONFIRM_POST_EXPLAIN' => 'Gäste müssen einen durch ein Bild vorgegebenen zufälligen Schlüssel beim Schreiben von Beiträgen eingeben. Dies soll helfen, Massenbeiträge (Spam) zu vermeiden.',
'VISUAL_CONFIRM_REG' => 'Visuellen Bestätigungscode für Registrierungen aktivieren',
'VISUAL_CONFIRM_REG_EXPLAIN' => 'Neue Benutzer müssen einen durch ein Bild vorgegebenen Schlüssel bei der Registrierung eingeben. Dies soll helfen, Massenregistrierungen zu vermeiden.',
'VISUAL_CONFIRM_REFRESH' => 'Benutzer Austausch des Bestätigungscodes erlauben',
'VISUAL_CONFIRM_REFRESH_EXPLAIN' => 'Erlaubt den Benutzern, einen neuen Bestätigungscode anzufordern, wenn sie ihn bei der Registrierung nicht lesen können.',
// Cookie Settings
'ACP_COOKIE_SETTINGS_EXPLAIN' => 'Hier legst du die Einstellungen fest, die verwendet werden, um Cookies an die Browser deiner Benutzer zu senden. In den meisten Fällen sollten die Standardwerte ausreichend sein. Führe Änderungen mit Bedacht durch, falsche Einstellungen könnten deine Benutzer daran hindern, sich anzumelden.',
'COOKIE_DOMAIN' => 'Cookie-Domain',
'COOKIE_NAME' => 'Cookie-Name',
'COOKIE_PATH' => 'Cookie-Pfad',
'COOKIE_SECURE' => 'Sicherer Server',
'COOKIE_SECURE_EXPLAIN' => 'Falls dein Server über SSL läuft, aktiviere diese Option, ansonsten lass sie deaktiviert. Wenn diese Option aktiviert ist, obwohl der Server nicht über SSL aufgerufen wird, können Fehler bei der Weiterleitung auftreten.',
'ONLINE_LENGTH' => 'Zeitspanne für die Online-Anzeige',
'ONLINE_LENGTH_EXPLAIN' => 'Die Zeit in Minuten, nach der inaktive Benutzer nicht mehr in der „Wer ist online“-Anzeige erscheinen. Je größer dieser Wert ist, desto größer ist die Rechenleistung, die zur Erstellung dieser Liste benötigt wird.',
'SESSION_LENGTH' => 'Sitzungslänge',
'SESSION_LENGTH_EXPLAIN' => 'Die Zeit in Sekunden, nach der Sitzungen ungültig werden.',
// Load Settings
'ACP_LOAD_SETTINGS_EXPLAIN' => 'Hier kannst du einige Board-Funktionen aktivieren und deaktivieren, um die beanspruchte Rechenleistung zu verringern. Auf den meisten Servern ist es allerdings nicht nötig, irgendeine Funktion zu deaktivieren. Andererseits kann es auf einigen Systemen oder auf Servern, die man sich mit anderen teilt, durchaus Vorteile bringen, wenn Funktionen abgeschaltet werden, die nicht wirklich benötigt werden. Du kannst hier auch Limits für die Systemauslastung und für die aktiven Sitzungen festlegen, bei deren Überschreitung das Board offline geht.',
'CUSTOM_PROFILE_FIELDS' => 'Zusätzliche Profil-Felder',
'LIMIT_LOAD' => 'Schränke Systemauslastung ein',
'LIMIT_LOAD_EXPLAIN' => 'Wenn die durchschnittliche Systemauslastung der letzten Minute (load average) diesen Wert überschreitet, geht das Board automatisch offline. 1.0 steht für eine ca. 100-prozentige Auslastung eines Prozessors. Diese Einstellung steht nur auf System zur Verfügung, die auf UNIX basieren und bei denen dieser Wert zugänglich ist. Der Wert stellt sich auf 0 zurück, wenn phpBB diesen Wert nicht auslesen konnte.',
'LIMIT_SESSIONS' => 'Schränke Sitzungen ein',
'LIMIT_SESSIONS_EXPLAIN' => 'Wenn die Zahl der Sitzungen innerhalb einer Minute diesen Wert überschreitet, geht das Board offline. Um keine Begrenzung festzulegen, stelle als Wert 0 ein.',
'LOAD_CPF_MEMBERLIST' => 'Erlaubt Styles, zusätzliche Profil-Felder in der Mitgliederliste anzuzeigen',
'LOAD_CPF_VIEWPROFILE' => 'Zusätzliche Profil-Felder in Mitgliederprofilen anzeigen',
'LOAD_CPF_VIEWTOPIC' => 'Zusätzliche Profil-Felder in der Themen-Ansicht anzeigen',
'LOAD_USER_ACTIVITY' => 'Aktivität der Mitglieder anzeigen',
'LOAD_USER_ACTIVITY_EXPLAIN' => 'Zeigt im Profil und im persönlichen Bereich an, in welchen Foren und Themen ein Mitglied am aktivsten ist. Es wird empfohlen, diese Funktion in Foren zu deaktivieren, die mehr als eine Million Beiträge haben.',
'RECOMPILE_STYLES' => 'Rekompilieren veralteter Style-Komponenten',
'RECOMPILE_STYLES_EXPLAIN' => 'Prüft auf neue Style-Komponenten und rekompiliert diese.',
'YES_ANON_READ_MARKING' => 'Gelesen-Markierung für Gäste',
'YES_ANON_READ_MARKING_EXPLAIN' => 'Speichert auch für Gäste, ob ein Thema gelesen oder ungelesen ist. Wenn diese Option deaktiviert ist, erscheinen Beiträge für Gäste immer als gelesen.',
'YES_BIRTHDAYS' => 'Anzeige der Geburtstage aktivieren',
'YES_BIRTHDAYS_EXPLAIN' => 'Wenn deaktiviert, wird die Liste der Geburtstage nicht länger angezeigt. Um diese Funktion zu aktivieren, muss die Geburtstagsfunktion ebenfalls aktiviert werden.',
'YES_JUMPBOX' => 'Anzeige der Jumpbox aktivieren',
'YES_MODERATORS' => 'Anzeige der Moderatoren aktivieren',
'YES_ONLINE' => 'Online-Anzeige der Mitglieder aktivieren',
'YES_ONLINE_EXPLAIN' => 'Zeigt in der Foren-Ãœbersicht, in den Foren und den Themen an, welches Mitglied online ist.',
'YES_ONLINE_GUESTS' => 'Online-Anzeige der Gäste aktivieren',
'YES_ONLINE_GUESTS_EXPLAIN' => 'Zeigt Informationen zu Gästen in „Wer ist online“ an.',
'YES_ONLINE_TRACK' => 'Anzeige des Online-/Offline-Symbols aktivieren',
'YES_ONLINE_TRACK_EXPLAIN' => 'Zeigt im Profil und der Themen-Ansicht den Online-Status des Mitglieds an.',
'YES_POST_MARKING' => 'Themen-Markierung aktivieren',
'YES_POST_MARKING_EXPLAIN' => 'Zeigt an, ob ein Benutzer in einem Thema schon einen Beitrag erstellt hat.',
'YES_READ_MARKING' => 'Serverseitige Gelesen-Markierung aktivieren',
'YES_READ_MARKING_EXPLAIN' => 'Speichert Informationen zu gelesenen/ungelesenen Beiträgen in der Datenbank statt im Cookie.',
// Auth settings
'ACP_AUTH_SETTINGS_EXPLAIN' => 'phpBB unterstützt Authentifizierungs-Plugins oder -Module. Mit diesen kannst du festlegen, wie Benutzer authentifiziert werden, wenn sie sich im Forum anmelden. Standardmäßig gibt es drei Plugins: DB, LDAP und Apache. Nicht alle Methoden benötigen zusätzliche Angaben, fülle daher nur Felder aus, wenn sie für die gewählte Methode von Belang sind.',
'AUTH_METHOD' => 'Authentifizierungs-Methode wählen',
'APACHE_SETUP_BEFORE_USE' => 'Du musst die Apache-Authentifizierung konfigurieren, bevor diese Methode in phpBB eingestellt wird. Beachte, dass der Benutzername der Apache-Authentifizierung deinem phpBB-Benutzernamen entsprechen muss. Die Apache-Authentifizierung kann nur mit mod_php (nicht mit der CGI-Version) und deaktiviertem safe_mode verwendet werden.',
'LDAP_DN' => 'LDAP-Basis <var>DN</var>',
'LDAP_DN_EXPLAIN' => 'Distinguished Name des Verzeichnisses, in dem sich die Benutzer-Daten befinden, z. B. <samp>o=Meine Firma,c=DE</samp>.',
'LDAP_EMAIL' => 'LDAP-E-Mail-Attribut',
'LDAP_EMAIL_EXPLAIN' => 'Gib hier den Namen des E-Mail-Attributes (falls existent) ein, um die E-Mail-Adresse für neue Benutzer automatisch zu setzen. Wenn dieses Feld freigelassen wird, ist bei Benutzern, die sich zum ersten Mal anmelden, keine E-Mail-Adresse gesetzt.',
'LDAP_INCORRECT_USER_PASSWORD' => 'Die Verbindung zum LDAP-Server mit der angegebenen Benutzernamen und Passwort ist gescheitert.',
'LDAP_NO_EMAIL' => 'Das angegebene E-Mail-Attribut existiert nicht.',
'LDAP_NO_IDENTITY' => 'Kann keine Anmeldekennung für %s finden.',
'LDAP_PASSWORD' => 'LDAP-Passwort',
'LDAP_PASSWORD_EXPLAIN' => 'Lasse das Feld für eine anonyme Verbindung frei; ansonsten gebe das Passwort für obigen Benutzer an. Erforderlich bei Active Directory-Servern. <strong>WARNUNG:</strong> Dieses Passwort wird im Klartext in der Datenbank gespeichert und ist daher für jeden einsehbar, der Zugriff auf die Datenbank oder diese Konfigurationsseite hat.',
'LDAP_PORT' => 'Port des LDAP-Servers',
'LDAP_PORT_EXPLAIN' => 'Du kannst optional einen Port angeben, der statt dem Standardport 389 für die Verbindung zum LDAP-Server verwendet werden soll.',
'LDAP_SERVER' => 'LDAP-Server-Name',
'LDAP_SERVER_EXPLAIN' => 'Wenn LDAP genutzt wird, ist dies der Servername oder die IP-Adresse des LDAP-Servers. Alternativ kannst du eine URL der Form <samp>ldap://hostname:port/</samp> angeben.',
'LDAP_UID' => 'LDAP <var>uid</var>',
'LDAP_UID_EXPLAIN' => 'Attribut, unter dem nach einem angegebenen Benutzernamen gesucht werden soll, z. B. <var>uid</var>, <var>sn</var>, usw.',
'LDAP_USER' => 'LDAP-Benutzer <var>dn</var>',
'LDAP_USER_EXPLAIN' => 'Lasse das Feld für eine anonyme Verbindung frei. Wenn ausgefüllt, wird phpBB den angegebenen Benutzer dazu verwenden, um sich für die Suche nach dem passenden Benutzer wie <samp>uid=Benutzername,ou=Organisationseinheit,o=Firma,c=DE</samp> anzumelden. Erforderlich bei Active Directory-Servern.',
'LDAP_USER_FILTER' => 'LDAP Benutzer-Filter',
'LDAP_USER_FILTER_EXPLAIN' => 'Du kannst optional die durchsuchten Objekte durch weitere Filter einschränken. Zum Beispiel führt <samp>objectClass=posixGruppe</samp> zur Benutzung von <samp>(&(uid=$username)(objectClass=posixGruppe))</samp>.',
// Server Settings
'ACP_SERVER_SETTINGS_EXPLAIN' => 'Hier kannst du einige Einstellungen bezüglich Server und Domain vornehmen. Bitte stelle sicher, dass die Daten, die du eingibst, auch wirklich stimmen, denn fehlerhafte Angaben könnten zu E-Mails führen, die falsche Informationen enthalten. Wenn du den Domain-Namen eingibst, denk daran, dass http:// oder eine andere Protokoll-Bezeichnung darin enthalten ist. Ändere den Port nur, wenn du weißt, dass dein Server einen anderen Port nutzt; Port 80 ist in den allermeisten Fällen richtig.',
'ENABLE_GZIP' => 'gzip-Komprimierung aktivieren',
'ENABLE_GZIP_EXPLAIN' => 'Der Seiteninhalt wird vor dem Senden an den Benutzer komprimiert. Dies kann den Netzverkehr reduzieren, wird aber auch zu einer Erhöhung der CPU-Last sowohl auf Server- als auch auf Benutzerseite führen.',
'FORCE_SERVER_VARS' => 'Erzwinge Server-URL-Einstellungen',
'FORCE_SERVER_VARS_EXPLAIN' => 'Wenn dies auf „Ja“ gestellt wird, werden die hier vorgenommenen Server-Einstellungen anstelle der automatisch ermittelten Werte genommen.',
'ICONS_PATH' => 'Speicherpfad für Themen-Symbole',
'ICONS_PATH_EXPLAIN' => 'Pfad von deinem phpBB-Hauptverzeichnis aus, z. B. <samp>images/icons</samp>.',
'PATH_SETTINGS' => 'Pfad-Einstellungen',
'RANKS_PATH' => 'Speicherpfad für Rang-Bilder',
'RANKS_PATH_EXPLAIN' => 'Pfad von deinem phpBB-Hauptverzeichnis aus, z. B. <samp>images/ranks</samp>.',
'SCRIPT_PATH' => 'Scriptpfad',
'SCRIPT_PATH_EXPLAIN' => 'Der Pfad in dem sich phpBB befindet, relativ zum Domainnamen; z. B. <samp>/phpBB3</samp>.',
'SERVER_NAME' => 'Domain-Name',
'SERVER_NAME_EXPLAIN' => 'Die Domain, auf der das Board läuft (bspw. <samp>www.phpbb.de</samp>).',
'SERVER_PORT' => 'Server-Port',
'SERVER_PORT_EXPLAIN' => 'Der Port, auf dem der Server läuft, für gewöhnlich 80. Ändere den Wert nur, wenn er sich davon unterscheidet.',
'SERVER_PROTOCOL' => 'Server-Protokoll',
'SERVER_PROTOCOL_EXPLAIN' => 'Dies wird als Server-Protokoll verwendet, wenn diese Einstellungen erzwungen werden. Ansonsten, oder wenn dieses Feld leer ist, werden die Einstellungen für „Sicherer Server“ aus den Cookie-Einstellungen genommen (<samp>http://</samp> oder <samp>https://</samp>).',
'SERVER_URL_SETTINGS' => 'Server URL-Einstellungen',
'SMILIES_PATH' => 'Speicherpfad für Smilies',
'SMILIES_PATH_EXPLAIN' => 'Pfad von deinem phpBB-Hauptverzeichnis aus, z. B. <samp>images/smilies</samp>.',
'UPLOAD_ICONS_PATH' => 'Speicherpfad der Dateityp-Gruppen-Symbole',
'UPLOAD_ICONS_PATH_EXPLAIN' => 'Pfad von deinem phpBB-Hauptverzeichnis aus, z. B. <samp>images/upload_icons</samp>.',
// Security Settings
'ACP_SECURITY_SETTINGS_EXPLAIN' => 'Hier können die Einstellungen zu Sitzungen und zur Anmeldung festgelegt werden.',
'ALL' => 'Alle',
'ALLOW_AUTOLOGIN' => 'Dauerhafte Anmeldung erlauben',
'ALLOW_AUTOLOGIN_EXPLAIN' => 'Legt fest, ob Benutzer sich automatisch bei jedem Besuch des Boards anmelden können.',
'AUTOLOGIN_LENGTH' => 'Verfallszeit für Anmelde-Schlüssel',
'AUTOLOGIN_LENGTH_EXPLAIN' => 'Die Anzahl der Tage, nach denen ein Anmelde-Schlüssel für die automatische Anmeldung verfällt. Um den Schlüssel nicht verfallen zu lassen, stelle als Wert 0 ein.',
'BROWSER_VALID' => 'Browser prüfen',
'BROWSER_VALID_EXPLAIN' => 'Aktiviert die Prüfung des Browsers für die jeweilige Sitzung, um die Sicherheit zu erhöhen.',
'CHECK_DNSBL' => 'IP gegen Schwarze DNS-Liste prüfen',
'CHECK_DNSBL_EXPLAIN' => 'Wenn aktiviert, wird die IP-Adresse des Benutzers bei der Registrierung und bei der Beitragserstellung gegen folgende DNSBL-Dienste geprüft: <a href="http://spamcop.net">spamcop.net</a>, <a href="http://dsbl.org">dsbl.org</a> und <a href="http://www.spamhaus.org">www.spamhaus.org</a>. Diese Prüfung kann, abhängig von der Serverkonfiguration, etwas Zeit in Anspruch nehmen. Wenn Verzögerungen oder zu viele falsche Ablehnungen beobachtet werden, sollte diese Prüfung deaktiviert werden.',
'CLASS_B' => 'A.B',
'CLASS_C' => 'A.B.C',
'EMAIL_CHECK_MX' => 'E-Mail-Domain auf gültigen MX-Eintrag prüfen',
'EMAIL_CHECK_MX_EXPLAIN' => 'Wenn aktiviert, wird die Domain der E-Mail-Adresse bei der Registrierung und der Änderung des Profils auf einen gültigen MX-Eintrag geprüft.',
'FORCE_PASS_CHANGE' => 'Passwortänderung erzwingen',
'FORCE_PASS_CHANGE_EXPLAIN' => 'Verlangt von den Benutzern, ihr Passwort nach einer festgelegten Anzahl an Tagen zu erneuern. Um dieses Verhalten abzuschalten, stelle als Wert 0 ein.',
'FORM_TIME_MAX' => 'Maximale Zeit zur Ãœbermittlung eines Formulars',
'FORM_TIME_MAX_EXPLAIN' => 'Die Zeit, die ein Benutzer hat, um ein Formular abzusenden. Stelle als Wert -1 ein, um das Verhalten abzuschalten. Beachte, dass ein Formular unabhängig dieser Einstellung ungültig werden kann, wenn die Sitzung abläuft.',
'FORM_SID_GUESTS' => 'Formulare an Gast-Sitzungen binden',
'FORM_SID_GUESTS_EXPLAIN' => 'Wenn aktiviert, ist ein Formular bei Gästen nur für die aktuelle Sitzung gültig. Dies kann bei manchen Internet-Providern zu Problemen führen.',
'FORWARDED_FOR_VALID' => '<var>X_FORWARDED_FOR</var>-Kopfzeilen prüfen',
'FORWARDED_FOR_VALID_EXPLAIN' => 'Sitzungen werden nur fortgesetzt, wenn die übermittelte <var>X_FORWARDED_FOR</var>-Kopfzeile mit der der letzten Anfrage identisch ist. Die in <var>X_FORWARDED_FOR</var> angegebene Adresse wird ebenfalls auf Sperrung geprüft.',
'IP_VALID' => 'Überprüfung der Sitzungs-IP',
'IP_VALID_EXPLAIN' => 'Legt fest, welche Teile der IP eines Benutzers zur Validierung einer Sitzung herangezogen werden. <samp>Alle</samp> bedeutet, dass die komplette IP Adresse verglichen wird; <samp>A.B.C</samp> vergleicht die ersten drei Oktetts; <samp>A.B</samp> vergleicht die ersten zwei Oktetts; <samp>Keine</samp> deaktiviert die Prüfung. Bei IPv6-Adressen prüft <samp>A.B.C</samp> die ersten 4 Blöcke und <samp>A.B</samp> die ersten 3.',
'MAX_LOGIN_ATTEMPTS' => 'Maximale Anzahl an Anmeldeversuchen',
'MAX_LOGIN_ATTEMPTS_EXPLAIN' => 'Nach dieser Anzahl fehlgeschlagener Anmeldungen muss der Benutzer seine Anmeldung zusätzlich durch einen visuellen Bestätigungscode bestätigen.',
'NO_IP_VALIDATION' => 'Keine',
'NO_REF_VALIDATION' => 'Keine',
'PASSWORD_TYPE' => 'Passwort-Komplexität',
'PASSWORD_TYPE_EXPLAIN' => 'Legt die bei der Wahl oder Änderung eines Passworts erforderliche Komplexität fest. Nachfolgende Optionen beinhalten jeweils die darüberstehenden.',
'PASS_TYPE_ALPHA' => 'Muss Buchstaben und Ziffern enthalten',
'PASS_TYPE_ANY' => 'Keine Erfordernisse',
'PASS_TYPE_CASE' => 'Muss Groß- und Kleinbuchstaben enthalten',
'PASS_TYPE_SYMBOL' => 'Muss Sonderzeichen enthalten',
'REF_HOST' => 'Prüfe nur den Hostnamen',
'REF_PATH' => 'Prüfe auch den Skript-Pfad',
'REFERER_VALID' => 'Referer pürfen',
'REFERER_VALID_EXPLAIN' => 'Wenn aktiviert, wird der Referer von POST-Anfragen gegen die Einstellungen des Hostnamen/Skript-Pfads geprüft. Dies kann bei Boards zu Problemen führen, die mehrere Domains oder eine externe Anmeldung nutzen.',
'TPL_ALLOW_PHP' => 'Erlaube PHP in Templates',
'TPL_ALLOW_PHP_EXPLAIN' => 'Wenn diese Option eingeschaltet ist, werden <code>PHP</code>- und <code>INCLUDEPHP</code>-Anweisungen in Templates erkannt und ausgeführt.',
// Email Settings
'ACP_EMAIL_SETTINGS_EXPLAIN' => 'Diese Informationen werden benötigt, wenn das Board E-Mails an deine Benutzer sendet. Stelle bitte sicher, dass die von dir angegebene Adresse gültig ist; geblockte oder nicht zustellbare Nachrichten werden an diese Adresse geschickt. Falls dein Webhosting-Provider keinen PHP-basierten E-Mail Service anbietet, kannst du deine Nachrichten auch direkt über SMTP versenden. Dies erfordert die Angabe der Adresse eines geeigneten Servers (frage falls nötig deinen Provider). Falls der Server eine Authentifizierung erfordert (und nur, wenn dies der Fall ist), gib den Benutzernamen und das Passwort ein und wähle eine Authentifizierungsmethode aus.',
'ADMIN_EMAIL' => 'Antwort-E-Mail-Adresse',
'ADMIN_EMAIL_EXPLAIN' => 'Diese technische Kontakt-Adresse wird als Antwort-Adresse für alle E-Mails genommen. Sie wird in allen E-Mails als <samp>Rückleitungs</samp>- und <samp>Absender</samp>-Adresse verwendet.',
'BOARD_EMAIL_FORM' => 'E-Mails über das Board versenden',
'BOARD_EMAIL_FORM_EXPLAIN' => 'Anstatt die E-Mail-Adresse der Benutzer anzuzeigen, können diese ihre E-Mails über das Board versenden.',
'BOARD_HIDE_EMAILS' => 'E-Mail-Adressen verstecken',
'BOARD_HIDE_EMAILS_EXPLAIN' => 'Diese Funktion hält E-Mail-Adressen komplett privat.',
'CONTACT_EMAIL' => 'Kontakt-E-Mail-Adresse',
'CONTACT_EMAIL_EXPLAIN' => 'Diese Adresse wird angegeben, wann immer eine spezifische Kontaktmöglichkeit benötigt wird, z. B. bei Spam, Fehlermeldungen etc. Sie wird in allen E-Mails als <samp>Von</samp>- und <samp>Antwort</samp>-Adresse verwendet.',
'EMAIL_FUNCTION_NAME' => 'Name der E-Mail-Funktion',
'EMAIL_FUNCTION_NAME_EXPLAIN' => 'Die PHP-Funktion, die genutzt wird, um E-Mails zu versenden.',
'EMAIL_PACKAGE_SIZE' => 'Größe von E-Mail-Paketen',
'EMAIL_PACKAGE_SIZE_EXPLAIN' => 'Dies ist die Anzahl der E-Mails, die maximal in einem Paket gesendet werden können. Diese Einstellung greift für die interne Nachrichten-Warteschlange; verwende 0, wenn du Probleme mit nicht versandten Benachrichtigungs-E-Mails hast.',
'EMAIL_SIG' => 'E-Mail-Signatur',
'EMAIL_SIG_EXPLAIN' => 'Dieser Text wird an alle E-Mails angehängt, die das Board versendet.',
'ENABLE_EMAIL' => 'Aktiviere E-Mail-Funktionalität',
'ENABLE_EMAIL_EXPLAIN' => 'Wenn dies deaktiviert ist, werden keinerlei E-Mails vom Board versendet.',
'SMTP_AUTH_METHOD' => 'Authentifizierungsmethode für SMTP',
'SMTP_AUTH_METHOD_EXPLAIN' => 'Nur benötigt, wenn ein Benutzername/Passwort eingegeben ist. Frage deinen Webhosting-Provider, falls du nicht sicher bist, welche Methode du wählen sollst.',
'SMTP_CRAM_MD5' => 'CRAM-MD5',
'SMTP_DIGEST_MD5' => 'DIGEST-MD5',
'SMTP_LOGIN' => 'LOGIN',
'SMTP_PASSWORD' => 'SMTP-Passwort',
'SMTP_PASSWORD_EXPLAIN' => 'Gib nur ein Passwort ein, wenn dein SMTP-Server dies erfordert.',
'SMTP_PLAIN' => 'PLAIN',
'SMTP_POP_BEFORE_SMTP' => 'POP-BEFORE-SMTP',
'SMTP_PORT' => 'SMTP-Server-Port',
'SMTP_PORT_EXPLAIN' => 'Ändere diese Einstellung nur, wenn du weißt, dass dein SMTP-Server einen anderen Port nutzt.',
'SMTP_SERVER' => 'SMTP-Server-Adresse',
'SMTP_SETTINGS' => 'SMTP-Einstellungen',
'SMTP_USERNAME' => 'SMTP-Benutzername',
'SMTP_USERNAME_EXPLAIN' => 'Gib nur einen Benutzernamen ein, wenn dein SMTP-Server dies erfordert.',
'USE_SMTP' => 'SMTP-Server für E-Mail nutzen',
'USE_SMTP_EXPLAIN' => 'Wähle „Ja“ aus, wenn du E-Mails über einen SMTP-Server senden möchtest (oder musst), anstatt die PHP-eigene Mail-Funktion zu nutzen.',
// Jabber settings
'ACP_JABBER_SETTINGS_EXPLAIN' => 'Hier kannst du die Nutzung von <a href="http://de.wikipedia.org/wiki/Jabber">Jabber</a> für Instant Messages und Benachrichtigungen des Boards aktivieren und kontrollieren. Jabber ist ein OpenSource-Protokoll und daher für jeden verfügbar. Einige Jabber-Server nutzen Gateways oder Transport-Dienste, die es dir erlauben, Benutzer anderer Netzwerke zu kontaktieren. Nicht alle Server bieten alle Transport-Dienste an, und Änderungen an den Protokollen können Transport-Dienste am Funktionieren hindern. Stelle sicher, dass du die korrekten Daten eines bereits registrierten Jabber-Kontos eingibst — phpBB verwendet die Daten so, wie sie hier eingegeben sind.',
'JAB_ENABLE' => 'Jabber aktivieren',
'JAB_ENABLE_EXPLAIN' => 'Aktiviert die Nutzung von Jabber-Nachrichten und -Benachrichtigungen.',
'JAB_GTALK_NOTE' => 'Beachte, dass GTalk nicht funktionieren wird, da die <samp>dns_get_record</samp>-Funktion nicht gefunden werden konnte. Diese Funktion ist in PHP 4 nicht verfügbar und nicht in Windows-Plattformen implementiert. Sie funktioniert derzeit nicht auf BSD-basierten Systemen inklusive Mac OS.',
'JAB_PACKAGE_SIZE' => 'Jabber-Paketgröße',
'JAB_PACKAGE_SIZE_EXPLAIN' => 'Dies ist die Anzahl der Nachrichten, die in einem Paket gesendet werden. Um die Nachrichten sofort zu senden, stelle als Wert 0 ein.',
'JAB_PASSWORD' => 'Jabber-Passwort',
'JAB_PORT' => 'Jabber-Port',
'JAB_PORT_EXPLAIN' => 'Lass dieses Feld frei, es sei denn, du weißt, dass es nicht Port 5222 ist.',
'JAB_SERVER' => 'Jabber-Server',
'JAB_SERVER_EXPLAIN' => 'Siehe %sjabber.org%s für eine Liste an Servern.',
'JAB_SETTINGS_CHANGED' => 'Jabber-Einstellungen erfolgreich geändert.',
'JAB_USE_SSL' => 'Mit SSL verbinden',
'JAB_USE_SSL_EXPLAIN' => 'Wenn aktiviert, wird versucht, eine sichere Verbindung zu verwenden. Der Jabber-Port wird auf 5223 geändert, sofern Port 5222 angegeben ist.',
'JAB_USERNAME' => 'Jabber-Benutzername',
'JAB_USERNAME_EXPLAIN' => 'Gebe einen bereits registrierten Benutzernamen an. Der Benutzername wird nicht auf Gültigkeit geprüft.',
// User notify mod
'USER_NOTIFY' => 'Benutzer bei Antworten benachrichtigen',
'USER_NOTIFY_EXPLAIN' => 'Der Vorgabewert bein Registrieren bei Antworten benachrichtigen.',
// Start Rectrict functions mod
'ACP_RESTRICT_FUNCTIONS' => 'Eingeschränkte Funktionen',
'ACP_RESTRICT_FUNCTIONS_EXPLAIN' => 'Hier kannst du einige Funktionen einschränken bis der Benutzer eine Anzahl Beiträge erreicht.',
'PM_ALLOWED_AFTER' => 'PNs erstellen erlauben nach',
'PM_ALLOWED_AFTER_EXPLAIN' => 'Schränke PNs erstellen ein bis der Benutzer x Beiträge erreicht. Gib 0 als Entsperrung ein um Pns fuer alle Benutzer zu gestatten.',
'SMILIES_ALLOWED_AFTER' => 'Smilies erlauben nach',
'SMILIES_ALLOWED_AFTER_EXPLAIN' => 'Schränke Smilies benutzen ein bis der Benutzer x Beiträge erreicht. Gib 0 als Entsperrung ein um Smilies benutzen fuer alle Benutzer zu gestatten.',
'ICONS_ALLOWED_AFTER' => 'Themen und PN Icons erlauben nach',
'ICONS_ALLOWED_AFTER_EXPLAIN' => 'Schränke Themen und PN Ikons benutzen ein bis der Benutzer x Beiträge erreicht. Gib 0 als Entsperrung ein um Themen und PN Zeichen benutzen fuer alle Benutzer zu gestatten.',
'ATTACHMENTS_ALLOWED_AFTER' => 'Anhänge hochladen erlauben nach',
'ATTACHMENTS_ALLOWED_AFTER_EXPLAIN' => 'Schränke Dateianhänge hochladen erlauben ein bis der Benutzer x Beiträge erreicht. Gib 0 als Entsperrung ein um Dateianhang fuer alle Benutzer zu gestatten.',
'TOPICS_ALLOWED_AFTER' => 'Neue Themen erstellen erlauben nach',
'TOPICS_ALLOWED_AFTER_EXPLAIN' => 'Schränke Neue Themen erstellen in jedem Forum ein bis der Benutzer x Beiträge erreicht. Gib 0 als Entsperrung ein um Neue Themen zu erstellen fuer alle Benutzer zu gestatten.',
'POLLS_ALLOWED_AFTER' => 'Neue Umfragen erstellen erlauben nach',
'POLLS_ALLOWED_AFTER_EXPLAIN' => 'Schränke neue Umfragen erstellen ein bis der Benutzer x Beiträge erreicht. Gib 0 als Entsperrung ein um neue Umfragen zu erstellen fuer alle Benutzer zu gestatten.',
'CHANGING_STYLES_ALLOWED_AFTER' => 'Stylewechsel erlauben nach',
'CHANGING_STYLES_ALLOWED_AFTER_EXPLAIN' => 'Schraenke Style wechseln ein bis der Benutzer x Beiträge erreicht . Gib 0 als Entsperrung ein um einen Style Wechsel fuer alle Benutzer zu gestatten.',
'AVATARS_ALLOWED_AFTER' => 'Avatare erlauben nach',
'AVATARS_ALLOWED_AFTER_EXPLAIN' => 'Schränke Avatare nutzen ein bis der Benutzer x Beiträge erreicht. Gib 0 als Entsperrung ein um Avatare nutzen fuer alle Benutzer zu gestatten.',
'SIGNATURES_ALLOWED_AFTER' => 'Signatur erlauben nach',
'SIGNATURES_ALLOWED_AFTER_EXPLAIN' => 'Schränke Signatur benutzen ein bis der Benutzer x Beiträge erreicht. Gib 0 als Entsperrung ein um Signatur zu benutzen fuer alle Benutzer zu gestatten.',
'WEBSITES_ALLOWED_AFTER' => 'Webseite im Profil benutzen nach',
'WEBSITES_ALLOWED_AFTER_EXPLAIN' => 'Schränke Webseiten im Profil benutzen ein bis der Benutzer x Beiträge erreicht. Gib 0 als Entsperrung ein um Webseiten zum Profil hinzu zu fuegen fuer alle Benutzer zu gestatten.',
'INCLUDE_ADMINS' => 'Adminstratoren eingeschlossen',
'INCLUDE_ADMINS_EXPLAIN' => 'Wenn ja, brauchen Administratoren diese Anzahl Beiträge für diese Funktionen.',
'INCLUDE_MODS' => 'Moderator eingeschlossen',
'INCLUDE_MODS_EXPLAIN' => 'Wenn ja, brauchen Moderator diese Anzahl Beiträge für diese Funktionen.',
// End Rectrict functions mod
//-- mod : Contact board administration ------------------------------------------------------------
//-- add
'ACP_CONTACT_ADMIN_SETTINGS_EXPLAIN'=> 'Dies ist die Konfigurationseite für den “Kontakt Board Administration†MOD von eviL<3. Die “Generelle Kontakt Seiten Einstellung†Abteilung enthält generelle Einstellungen und die Einstellungen der “Kontakt Bot†Abteilung beziehen sich allein auf “Forum Beiträge†und “Private Nachrichten†Kontaktmethode.',
// General config options
'CONTACT_GENERAL_SETTINGS' => 'Generelle Kontakt Seiten Einstellung',
'CONTACT_ENABLE' => 'Kontakt Seite ein',
'CONTACT_ENABLE_EXPLAIN' => 'Wenn ausgeschaltet, zeigt die Kontaktseite einen Fehler an wenn sie besucht wird und der Link wird nicht im Kopf angezeigt.',
'CONTACT_CONFIRM' => 'Visuelle Bestätigung ein',
'CONTACT_CONFIRM_EXPLAIN' => 'Wenn diese Option ausgeschaltet wird, haben Gäste eine visuelle Bestätigung zum Absenden ihrer Nachrichten. Dies ist nutzlich zum Verhindern automatischer Nachrichten. Bemerkung: Diese Option ist nur für die Kontakt Seite, sie beeinflusst keine anderen visuelleb Bestätigungen.',
'CONTACT_CONFIRM_GUESTS' => 'Visuelle Bestätigung nur für Gäste',
'CONTACT_CONFIRM_GUESTS_EXPLAIN' => 'Wenn eingeschaltet, wird die visuelle Bestätigung nur für Gäste angezeigt (falls die Option aktiviert wurde).',
'CONTACT_MAX_ATTEMPTS' => 'Maximal Bestätigungsversuche',
'CONTACT_MAX_ATTEMPTS_EXPLAIN' => 'Wie oft darf ein Benutzer versuchen die richtige Bestätigung einzugeben? Gib 0 für unbegrenzte Besuche ein.',
'CONTACT_METHOD' => 'Kontakt Methode',
'CONTACT_REASONS' => 'Kontakt Gründe',
'CONTACT_REASONS_EXPLAIN' => 'Gib Gründe für Kontakte ein, getrennt durch neue Zeilen. Wenn du das nicht nutzen willst, lass das Feld leer.',
// Bot config options
'CONTACT_BOT_SETTINGS' => 'Kontakt Bot Einstellungen',
'CONTACT_BOT_USER' => 'Kontakt Bot Benutzer',
'CONTACT_BOT_USER_EXPLAIN' => 'Enter die User ID vom Benutzer hier, der der Autor der Forumsnachrichten ist, wenn die Kontaktmethode auf “Forum Beitrag†eingestellt wurde, oder die PM, im Falle von “Privat Nachrichtenâ€',
'CONTACT_BOT_FORUM' => 'Kontakt Bot Forum',
'CONTACT_BOT_FORUM_EXPLAIN' => 'Wähl das Forum, in das der Kontakt Bot hineinposten soll, wenn die Kontakt Methode auf “Forum Beitrag†eingestellt wurde.',
// Contact methods
'CONTACT_METHOD_EMAIL' => 'Email',
'CONTACT_METHOD_POST' => 'Forum Beitrag',
'CONTACT_METHOD_PM' => 'Private Nachricht',
//-- fin mod : Contact board administration --------------------------------------------------------
// Signature Restrictions - Begin Code Alteration
'SIG_RESTRICT' => 'Signatur Einschränkungen',
'SIGRESTRICT_ENABLE' => 'Signatur Einschränkungen einschalten',
'SIGRESTRICT_ENABLE_EXPLAIN' => 'Benutzte dies um die Einstellungen für diese Gruppe an und aus zu schalten. Du kannst jede einzelne Einstellung unten ausschalten indem du 0 einträgst.',
'SIGRESTRICT_NOGET_HANDLE' => 'Speichere bei Bildgrößenfehlern',
'SIGRESTRICT_NOGET_HANDLE_EXPLAIN' => 'Soll die Signatur gespeichert werden, wenn die Größe nicht bestimmt werden kann? Bei "Nein" wird eine Fehlermeldung angezeigt.',
'SIGRESTRICT_MAX_LINES' => 'Maximale Linienlänge',
'SIGRESTRICT_MAX_LINES_EXPLAIN' => 'Maximale Länge in Zeilennummer für Signatur erlaubt.',
'SIGRESTRICT_MAX_IMAGES' => 'Maximale Bilder erlaubt',
'SIGRESTRICT_MAX_IMAGES_EXPLAIN' => 'Maximale Anzahl of Bilder erlaubt in user signatures. This does not include smilies.',
'SIGRESTRICT_MAX_LINE_CHARS' => 'Maximale Zeichens per line',
'SIGRESTRICT_MAX_LINE_CHARS_EXPLAIN' => 'Maximale Anzahl of Zeichen per Linie in Signaturen erlaubt.',
'SIGRESTRICT_MAX_LINE_CHARS_SILENT' => 'Zeichenumbrüche bei maximal Zeichen',
'SIGRESTRICT_IMAGE_LINE_PX' => 'Linienhöhe',
'SIGRESTRICT_IMAGE_LINE_PX_EXPLAIN' => "Höhe einer normalen Textlinie. Um herauszufinden, ob ein Bild mehr als eine Linie braucht, wird die Höhe des Bildes durch die Anzahl der Linien geteilt. Linien über diesem Wert wären das Maximum.",
'SIGRESTRICT_IMAGE_WIDTH_PX' => 'Zeichen Weite',
'SIGRESTRICT_IMAGE_WIDTH_PX_EXPLAIN' => "Weite eines Textzeichen. Die Weite der Bilder wird durch diese Anzahl geteilt um herauszufinden, ob ein Bild mehr als die höchste Menge an Zeichen in einer Linie benötigt.",
'SIGRESTRICT_MAX_LINE_CHARS_SILENT_EXPLAIN' => 'Wenn eine Linie das Maximum an Zeichen überschreitet, wird es mehr als eine Linie gezählt, jedesmal wenn ein Zeilenumbruch erfolgt. Wenn du "Nein" setzt erscheint eine Fehlermeldung.',
// Signature Restrictions - End Code Alteration
- quahappy
- Happy, not Quappy
I've presently placed UQM link in a Menu links MOD at my test site but of course the majority might not have this so here's a quick fix for now:Lugsciath wrote:- There isn't the section/link for/about the overall header template
Edit overall_header.html
FIND:
<li class="icon-faq"><a href="{U_FAQ}" title="{L_FAQ_EXPLAIN}">{L_FAQ}</a></li>
<li><a href="http://<yoursiteurl>/quiz.php">Ultimate Quiz MOD</a></li>
<li><a href="quiz.php">Ultimate Quiz MOD</a></li>
