BitComet v1.10 released on March 9, 2009
v1.10 2009.03.09
GUI Improved: add task search box in toolbar, which can be enable from View menu
GUI Improved: add a button in HTTP task properties dialog to set current download folder as default
GUI Improved: improve the file type filter in BT task properties dialog
GUI Improved: improve the auto shutdown function in Tools menu
GUI Improved: show item number count in HTTP batch download dialog
GUI Improved: new command in context menu of task archive list: show torrent file properties dialog
GUI Improved: show task index and total count in floating window when it's large enough
GUI Improved: new setting in advance page of option dialog: User-Agent string for all HTTP task
GUI Improved: add support for several new languages (see lang\HowTo-Translate.txt)
GUI Improved: do not switch to task list after download a torrent file from torrent collection list
GUI Bugfix: download several torrents from torrent collection list and display their task properties dialog at the same time may cause program no response
GUI Bugfix: files large than 4GB can be downloaded to volume using exFAT
Core Improve: improve file boundary data save for BT task
Core Improve: enhance virus protect auto-config
Core Improve: HTTP download task support redirection to relative path
Core Bugfix: authentication information is not send to server in very few situations of HTTP redirection
Core Bugfix: private BT task will search peers in DHT network in very few situations
Core Bugfix: uploading of Long-Time seeding is unstable
Download links:
BitComet v1.10 setup.exe
BitComet v1.10.zip
BitComet v1.10 eMule plugin.exe
New BitComet Version Released
- p2p-sharing-rules
- Moderator
BitComet 1.11 Apr. 28, 2009
GUI Improved: elevation is not needed to associate torrent file in Windows Vista
GUI Improved: save to My Document in HTTP batch download dialog is supported
GUI Improved: the client version and transfer mode of Long-Time Seeding peer is
displayed in peer list of BT task
GUI Improved: add piece error column in peer list of BT task, hidden by default
GUI Improved: display connection time of Long-Time Seed in peer list of BT task
GUI Bugfix: when using multi-monitor, BitComet do not restore window position to the monitor last exit from.
GUI Bugfix: can't sort peer list by the cols that in the right of any hidden column
Core Improve: support the UDP transfer mode of Long-Time Seeding, can be enabled in advanced options
Core Improve: support test UDP port in WAN/LAN ip detector
Core Improve: stop connect to a peer that send too many error pieces
Core Improve: improve connection algorithm for Long-Time seeding
Core Improve: improve the compatibility to the old versions of eMule plugin, support v1.06 and later
Core Improve: delete Thumbs.db when remove task downloaded files
Core Improve: set taskname.piece_part.bc! as hidden file, avoiding deleted accidently
Core Improve: update bittorrent client identification code
Core Bugfix: program crash when using proxy server
Core Bugfix: user and password setting for proxy server do not work
Core Bugfix: making torrent file fail if containing empty sub-folders
Core Bugfix: invalid local IP displayed in statistics pane
Core Bugfix: publish date of very few torrent display incorrect in torrent collection list
Download links:
BitComet 1.11.exe
BitComet 1.11.zip
Download links:
BitComet 1.11.exe
BitComet 1.11.zip
- p2p-sharing-rules
- Moderator
BitComet v1.12
Release date: May 18 2009
GUI Improved: remove torrent share list in simplified Chinese version
Download links
BitComet 1.12.exe
BitComet 1.12.zip
Download links
BitComet 1.12.exe
BitComet 1.12.zip
- p2p-sharing-rules
- Moderator
BitComet v1.13
Release date: June 22 2009
Changelog
GUI Improved: add "Uploading" queue to the left fav bar
GUI Improved: BT task file list in properties dialog and right-bottom pane changes to tree list for directory structure
GUI Improved: BT task file list in properties dialog and right-bottom pane support sorting
GUI Improved: add new commands to context menu of BT task file list: expand/collapse folders
GUI Improved: add check box to BT task file list pane for each file and folder, to switch download it or not
GUI Improved: add connection status icon for each peer in BT task peer list
GUI Improved: add "new peer" command to context menu of BT task peer list
GUI Improved: BT task peer list displays prompt string when frozen by ScrollLock
GUI Improved: support only export selected tasks into backup file
GUI Improved: support import tasks from backup file and merge them into task list
GUI Improved: select whether import global program settings while import tasks from backup file
GUI Improved: language list in Tools menu changes to a 2-level sub menu
GUI Improved: add loading page to task content, Snapshot, Comment and Recommend pane
GUI Improved: do not clear rate graph in floating window when stop all tasks
GUI Improved: do not show the message of missing BitCometAgent.dll when program start
GUI Improved: optimize reconnect time after Comet Passport sign in failed
GUI Bugfix: when open a GB2312 encoding torrent file in traditional Chinese Windows, the task name and publish info displays incorrectly after change character encoding
GUI Bugfix: TCP, UDP mode setting of Long-Time seeding in advanced options can not be saved
GUI Bugfix: restore the torrent archive list which removed in v1.12
GUI Bugfix: if select none of files in BT task to download, the task progress will display incorrectly when program start next time
Core Improve: improve taskname.piece_part.bc! file structure, which used to save file boundary data for BT task, therefore decreased memory usage
Core Improve: BT task Anti-Leech setting changes to three levels: "disable", ""auto", "strict"
Core Improve: improve network modular code, avoid program losing response when download in high speed
Core Improve: add disk cache for UDP Long-Time seeding, 50MB max
Core Improve: set the thread priority of UDP Long-Time seeding below normal
Core Bugfix: memory leak in UDP uploading modular of Long-Time seeding
Core Bugfix: too many memory and CPU used when Long-Time seeding in high speed using UDP
Download links
BitComet 1.13_setup.exe
BitComet 1.13.zip
Changelog
Download links
BitComet 1.13.zip
- p2p-sharing-rules
- Moderator
BitComet 1.14
Released date: July 31, 2009
Changelog
GUI Improved: support Web Seed when make torrent file
GUI Improved: support modify Web Seed list in BT task properties dialog
GUI Improved: display download/upload rate of user group in peer list of BT task
GUI Improved: display downloading piece position in peer list of BT task
GUI Improved: display balloon on system tray icon when disk busy leading to GUI losing response
GUI Improved: new appearance option: minimize when program start
GUI Improved: add loading page to bookmark in left fav bar
GUI Improved: loading torrent collection list from xml file in working thread, avoid GUI freezing
GUI Improved: decrease the delay switching to torrent collection list from task list
GUI Improved: add new command in context menu of floating window: start uploading all
GUI Improved: change the BitComet icon in system tray to grey when program exiting
GUI Improved: new setting in connection panel of option dialog: Alternate max upload rate when not downloading
GUI Improved: statistics panel displays current download rate limit and upload rate limit
GUI Improved: individual max concurrent downloading task numbers for BT tasks and HTTP tasks in option dialog
GUI Improved: new "Force" option for BT task protocol encryption in option dialog
GUI Improved: new setting in Long-Time Seeding panel of option dialog: Auto upload rate control
GUI Improved: statistics panel displays current upload rate limit of long-time seeding
GUI Improved: BitComet not responding dialog will be closed automatically after GUI resumed
GUI Bugfix: can't add HTTP Tracker whose port is 80 in BT task properties dialog
GUI Bugfix: if task selection state changed before task delete dialog displayed, the task will be deleted may not be the originally selected
Core Improve: BT task supports downloading from Web Seed, compatible with BitTorrent mainline
Core Improve: decrease CPU usage of DHT modular
Core Improve: ban the peers from the specified IP even they changed peer ID
Core Improve: improve connection algorithm for UDP download from Long-Time seed
Core Improve: send no-retry instruction to remote UDP peers when exiting
Core Improve: improve connection algorithm for BT uploading
Core Improve: give BT upload connection higher priority when auto upload rate control of long-time seeding enabled
Core Bugfix: max simultaneous half-open TCP connection number in advanced option page does not take effect
Core Bugfix: making torrent file may fail if there're too many files in the specified folder
Download links
BitComet 1.14_setup.exe
BitComet 1.14.zip
Changelog
Download links
BitComet 1.14.zip
- p2p-sharing-rules
- Moderator
BitComet 1.15
Released date: Sept 25, 2009
Changelog
GUI Improved: task information panel lists change to task information tabs, support drag & drop and context menu
GUI Improved: redesign "Task Summary" tab
GUI Improved: task "Recommend" page changes to "Start Page" tab
GUI Improved: hide unnecessary task tabs when no task selected or task stopped
GUI Improved: add "Network Setting Wizard" to "Network" page in Option dialog
GUI Improved: improve context menu of status bar, add "port mapping again" and "help"
GUI Improved: add download/upload limit setting to context menu of floating window and system tray icon
GUI Improved: show "ED2K link" in file list of BT task
GUI Improved: highlight the current time block in scheduler setting page
GUI Bugfix: password not cleared when change user name in CometPassport sign in dialog
GUI Bugfix: pieces status and upload speed of emule plugin display incorrectly in peer list
Core Improve: emule plugin upgraded to v0.49c
Core Improve: improve connection algorithm of Long-Time seed for high-speed network
Core Improve: "Start all seeding" from context menu of floating window do not start tasks with file missing
Core Improve: improve DNS query
Core Improve: update task finish time when BT task download finished again after selecting more files to download
Core Bugfix: EVENT_COMPLETE should be sent to tracker only when all files in BT task downloaded, not only selected (v1.13 and v1.14)
Core Bugfix: connection number too small after some files in BT task finished
Core Bugfix: UPNP modular can not exit normally sometimes
Core Bugfix: task should enter in queue if when started during stopped time of schedule
Core Bugfix: remove port mapping of eMule plugin when program exiting
Download links
BitComet 1.15.exe
BitComet 1.15.zip
BitComet 1.15 plugin.exe
Changelog
Download links
BitComet 1.15.exe
BitComet 1.15.zip
- p2p-sharing-rules
- Moderator
BitComet 1.16
Release date: Nov. 10, 2009
changelog
GUI Improved: add "Task Tags" page to Options dialog, default download folder for each tag can be set here.
GUI Improved: improve "Directories" page in Options dialog, task tags for each candidate download directory can be set here.
GUI Improved: set task tag and default download folder for new task automatically according to file extension name.
GUI Improved: improve drop list of save folder in task properties dialog, display candidate download directories and corresponding tags
GUI Improved: add "Set as Default Directory" button in BT task properties dialog
GUI Improved: add "Super Seeding" option in advanced page of BT task properties dialog
GUI Improved: add BT task log list
GUI Improved: add preview/open button in BT task file list
GUI Improved: display user group info in peer list of BT task in blue
Core Improve: support Super Seeding for BT task (for initial seeding server only)
Core Improve: improve preview download mode for BT task
Core Bugfix: save task list failed in Vista/Win7 64bit
Core Bugfix: data in first/last piece of file may not be saved properly when select part of files in BT task to download
Core Bugfix: failed to remove torrent file with read-only attribute in program data folder when remove BT task
Download links:
BitComet v1.16 setup.exe
BitComet v1.16.zip
changelog
Download links:
BitComet v1.16.zip
- p2p-sharing-rules
- Moderator
BitComet Client v1.17
Release date: Dec. 28, 2009
Changelog
GUI Improved: support download Magnet URI when click "Open Torrent from URL" from file menu
GUI Improved: change "copy BC link" in context menu of task list, Torrent History and Torrent Exchange to "Copy Magnet URI"
GUI Improved: new auto-shutdown condition: shutdown at specified time
GUI Improved: display information of every connection to the same server in connection tab of HTTP task
GUI Improved: add context menu to BT task file list header, to select columns to display
GUI Improved: display the preview buttons of files in BT task file list according to each file's downloading progress
GUI Improved: support mouse wheel in task summary
GUI Improved: remove "Task Content" tab
GUI Improved: highlight the row on which mouse hovers in file list, peer list and tracker list
GUI Improved: rename "Super-Seeding" to "Initial-Seeding" in BT task properties dialog
GUI Improved: display local-language name of every language in Tools menu, besides theirs English name
GUI Improved: remove es_ar language due to the limit in launchpad.net, and add Uighur
GUI Improved: rename Torrent Archive under Torrent Share to Torrent Share under Torrent Exchange, and add Torrent History in addition
GUI Improved: display introduction page when click Torrent Exchange in left fav tree
GUI Improved: new option in BT task page of options dialog: add to Torrent History when open .torrent file
GUI Improved: new option in BT task page of options dialog: list of BitTorrent clients allowed connecting to
GUI Improved: new option in Integration page of options dialog: associate with Magnet URI
GUI Improved: option to restart program immediately when send crash report
GUI Improved: when opening video file, use the player program configured in advanced option
GUI Bugfix: fix many spell mistakes in GUI (thanks to greywizard)
GUI Bugfix: cannot input Web Seed address longer than one row of the input edit-box
Core Improve: support BitTorrent Extension Protocol of metadata exchange, compatible with BitTorrent mainline
Core Improve: support BitTorrent Extension Protocol of report DHT port, compatible with BitTorrent mainline
Core Bugfix: display file failed to create in task log when start new BT task in certain situation
Core Bugfix: can not open torrent file containing multi-files, in which the name field ends with space
Download links
BitComet v1.17 setup.exe
BitComet v1.17.zip
Changelog
Download links
BitComet v1.17.zip
- p2p-sharing-rules
- Moderator
BitComet 1.18
Release date: Jan. 20, 2010
Changelog:
GUI Improved: display the properties of multiple tasks will show a task statistics dialog
GUI Improved: drag&drop a Magnet URI or HTTP URL to main window of BitComet will launch a download
GUI Improved: add legend to the piece map tab of task
GUI Improved: new setting in advanced page of option dialog: system.use_app_data, detailed info refer to wiki
GUI Improved: display error message when failed to load/save task list xml file
GUI Improved: new command in context menu of tracker list: add tracker
GUI Improved: new setting in connection page of option dialog: randomize port each start
GUI Improved: display "added date" in torrent history, and hide "snapshots", "comments", "rating", "popular" by default
GUI Improved: display translator info in about dialog
GUI Improved: enhance BHO, display BitComet icon in context menu of IE8
GUI Improved: enhance video downloader extension for Firefox, display captured files in Tools menu besides in context menu
GUI Improved: new setting in BT task page of option dialog: display task properties dialog after torrent downloaded from Magnet URI
GUI Improved: display batch download dialog when multiple torrents selected to download in Torrent Exchange
GUI Bugfix: when shutdown scheduled at specified time, shutdown will still be launched when all download finished
GUI Bugfix: error occurred when non-admin user try to modify IE integration setting under Vista/Win7
GUI Bugfix: task properties dialog displayed incorrectly for right-to-left languages, e.g. Arabic and Hebrew
GUI Bugfix: the setting of shutdown at specified time does not take effect at first time
Core Improve: save bak files for task list xml file up to 7 copies
Core Improve: update BitTorrent client identification code
Core Improve: the BT tasks which haven't downloaded torrent will not enter the task queue
Core Bugfix: enhance the stability of UDP transport
Core Bugfix: enhance the stability of HTTP proxy connection
Download links:
BitComet v1.18 setup.exe
BitComet v1.18.zip
Changelog:
Download links:
BitComet v1.18.zip
- p2p-sharing-rules
- Moderator
BitComet v1.19
Release date: Feb. 21, 2010
Changelog
GUI Improved: Torrent maker dialog changed to modeless window
GUI Improved: supports edit Tracker URL for Magnet URI task before torrent downloaded
GUI Improved: new command in Tools menu: enable eMule plugin, show/hide plugin window
GUI Improved: support set task tags in BT/HTTP task properties dialog
GUI Improved: move downloaded files to tag associated folder optionally when add task tag using task context menu
GUI Improved: supports switch input focus to list control inside task tabs by Tab key
GUI Improved: add icons to task context menu
GUI Improved: display "not supported" in ed2k link field of file list for private torrents
GUI Improved: new setting in advanced page of option dialog: system.show_debug_info
GUI Bugfix: can't drag&drop download links to floating windows from IE8 in Win7
GUI Bugfix: the save path edit-box in BT/HTTP task properties dialog doesn't support mouse wheel
GUI Bugfix: Web interface doesn't support to download Magnet URI
GUI Bugfix: the last task in task list doesn't get refreshed in some situation
Core Improve: support BitTorrent Extension Protocol of peer exchange, compatible with BitTorrent mainline
Core Improve: new eMule plugin (based on Xtreme 7.2 mod)
Core Bugfix: after removing tasks without removing files, the Long-Time Seeding for these files won't stop immediately
Core Bugfix: after disable LT Seeding in option dialog, running tasks won't stop downloading from Long-Time Seeding immediately
Download links:
BitComet v1.19.exe
BitComet v1.19.zip
BitComet 1.19 emule plugin.exe
BitComet 1.19 xtreme plugin.exe
Changelog
Download links:
BitComet v1.19.exe
BitComet v1.19.zip
- p2p-sharing-rules
- Moderator
BitComet v1.20
Release date: March 25, 2010
Changelog
GUI Improved: new command in file menu: "Import Unfinished Download", supports BitComet, uTorrent, Xunlei
GUI Improved: start download from torrent infohash directly in "Open torrent from URL" dialog
GUI Improved: drag & drop task names to rearrange task list(when task list not sorted)
GUI Improved: BT task summary tab: show BT task pieces number; show down/upload speed/size detail info in tooltip when mouse hovers on them
GUI Improved: BT task peer list: new command "Friend Upload Slot" in the context menu, for only one IP at the same time
GUI Improved: BT task tracker list: show seeds, peers, downloaded number returned from tracker
GUI Improved: BT task file list: sort file names in the same order as Windows Explorer(thanks to RadioNoise)
GUI Improved: display snapshots tab in new BT task dialog when open torrent file
GUI Improved: modify the size of BT task properties dialog, compatible with 1024x600 resolution
GUI Improved: for finished BT task, "search for Long-Time Seeds" displayed as "enable Long-Time Seeding", "search for eMule sources" as "enable upload to eMule sources" in task properties dialog
GUI Improved: new global option: maximum number of concurrent seeding BitTorrent tasks
GUI Improved: new global option: Don't use proxy for tracker/peer connections
GUI Improved: new global option: specify separated listen port for Web UI
GUI Improved: supports Occitan language(see lang\HowTo-Translate.txt)
GUI Improved: when using remote desktop, disable highlight the row on which mouse hovers in file list, peer list and tracker list
GUI Improved: improve compatibility of install package with Vista/Win7
GUI Bugfix: tailing space in tracker address leads to connection failure
GUI Bugfix: can't start BitTorrent download when drag&drop a Magnet URI text to floating window
Core Improve: use UTF-8 encoding when making torrent file by default for all language versions of Windows
Core Improve: improve algorithm, reduce CPU usage of DHT modular, avoid GUI blocked
Core Improve: improve algorithm, reduce CPU usage of Long-Time Seeds download modular, avoid GUI blocked
Core Improve: support HTTPS tracker
Core Bugfix: after Scheduler stopped all tasks, the option of "Auto start task when download rate less than specified rate" will still start tasks
Core Bugfix: after BT task stopped, corresponding DHT connections didn't stop totally
Core Bugfix: invalid DHT packet may lead to program crash(thanks to Pierre Noguès)
Core Bugfix: task list backup file from v1.19 can't be imported by itself
Download links
BitComet 1.20.exe
BitComet 1.20.zip
Changelog
Download links
BitComet 1.20.exe
BitComet 1.20.zip
- p2p-sharing-rules
- Moderator
BitComet v1.21
Release date: May 28, 2010
Changelog
GUI Improved: support open magnet URI with multiple tracker parameters
GUI Improved: include multiple tracker parameters when copy magnet URI from BitTorrent task
GUI Improved: download installation package of new version in background automatically if enabled
GUI Improved: support SHA1 verification for downloaded file in HTTP task properties dialog
GUI Improved: display confirmation dialog when choose re-download HTTP task
GUI Improved: improve icons in context menu of task list
GUI Improved: rename "Web Interface" to "Remote Download" in Option dialog
GUI Improved: username, password and referrer can be specified when add HTTP download in Remote Download web page
GUI Improved: add log list for HTTP task connections in Remote Download web page
GUI Improved: add start/stop operations in task info web page of Remote Download
GUI Improved: Firefox extension supports capture .hlv video file
GUI Improved: when using multiple user accounts of Windows, each user has individual task list and program settings
GUI Bugfix: share ratios of BitTorrent tasks are displayed incorrectly when program just started
GUI Bugfix: displaying tooltip in toolbar may lead to crash
Core Improve: support file path longer than 260 characters
Core Improve: remove LUA scripts support for intelligent rename of HTTP download
Core Bugfix: fail to download HTTP URL containing single quotes
Download links
BitComet 1.21.exe
BitComet 1.21.zip
Changelog
Download links
BitComet 1.21.exe
BitComet 1.21.zip
- p2p-sharing-rules
- Moderator
BitComet 1.22
Release date: June 20, 2010
Changelog
GUI Improved: improve IE context menu display effect under Vista/Win7
GUI Bugfix: tab key response incorrectly in Torrent Maker dialog
Core Improve: improve compatibility of UDP transmission modular with third-party software
Core Improve: eMule plugin upgraded to v0.50a
Core Bugfix: failed to fetch cookie info from Firefox 3.0 and above when HTTP downloading
Core Bugfix: failed to save DHT nodes file when program exiting in some situation
Core Bugfix: fix DNS query function
Core Improve: do not reset task progress to 0% when disk drive inaccessible(e.g. flash disk unplugged)
Core Bugfix: fail to save task list when use_app_data == false under Vista/win7 (v1.21)
Core Bugfix: improve kernel stability
Download links
BitComet 1.22
BitComet 1.22.zip
eMule plugin v1.22 (0.50a)
Changelog
Download links
BitComet 1.22
BitComet 1.22.zip
- p2p-sharing-rules
- Moderator
BitComet 1.23
Release date: Aug 31, 2010
Changelog
GUI Improved: add Summary tab to Torrent History and Torrent Share list
GUI Improved: open Torrent from URL dialog supports multiple URLs
GUI Improved: export all torrents in one time by selecting multiple tasks in task list, Torrent History or Torrent Share list
GUI Improved: display "click to add" in file list when BitTorrent task missing ED2K links
GUI Improved: add Snapshot and Comment tab to Torrent History and Torrent Share list
GUI Improved: new command in context menu of Torrent History: "add to task list"
GUI Improved: support import unfinished download files with any extension name
GUI Improved: new advanced option: allow preview program to open files of any type from file list (thanks to greywizard)
GUI Improved: enhance video file capture ability of Firefox extension
GUI Change: CometPassport renamed to CometID
GUI Bugfix: percent of score bar for CometID level up displays invalid for level 50+ (v1.22)
GUI Bugfix: after modifying save path in task properties dialog and selecting moving files, the downloaded files are copied to new folder, not moved
GUI Bugfix: no beeps after download completed (v1.22)
GUI Bugfix: after changing torrent file encoding in task properties dialog, the task name in Torrent History is not refreshed
GUI Bugfix: cannot send crash report under XP
GUI Bugfix: after switched to Torrent History, some buttons in toolbar should disabled
Core Improve: supports HTTP 301/302 redirecting for Web Seed
Core Improve: eMule plugin Xtreme Mod upgraded to v8.0 (eMule v0.50a)
Core Improve: after error code received from Tracker, increase retry interval and re-connect later
Core Improve: increase priority of HTTP tracker connection
Core Improve: improve piece request algorithm for BitTorrent task, reduce CPU usage
Core Bugfix: if BitTorrent task containing multiple files, multiple eMule plugin will be launched incorrectly(v0.50a)
Core Bugfix: failed to generate Crash Report in Vista/Win7 (v1.22)
Core Bugfix: upload task number limit works incorrectly when there are any task whose torrent not downloaded yet
Core Bugfix: perform hash-check if file changed or missing when start BitTorrent task
Core Bugfix: FTP download did not handle the error of disconnect by server unexpectedly
Core Bugfix: FTP download failed to resume download from certain FTP servers
Download links
BitComet 1.23_setup.exe
BitComet 1.23.zip
BitComet 1.23 emule plugin.exe
BitComet 1.23 xtreme plugin.exe
Changelog
Download links
BitComet 1.23.zip
- p2p-sharing-rules
- Moderator
BitComet 1.24
Release date: Nov. 11, 2010
Changelog
GUI Improved: add "VIP Accelerate" for BitTorrent download, enable from the VIP icon in task list
GUI Improved: new global settings: move downloaded files to specified folder after task finished
GUI Improved: add task filter on the top of task list, filter tasks by states, tags and keywords
GUI Improved: move task tag list from the favorites bar at left to the task filter bar above task list
GUI Improved: add keyboard shortcut Ctrl+F to find task
GUI Improved: show batch download dialog when open multiple magnet links using Ctrl+U
GUI Improved: change the text of preview/open in task list to icon
GUI Improved: remove the upper limit of the peer number displayed in peer list of BitTorrent task and display all
GUI Improved: display a yellow warning icon for tasks that failed to move/rename files after download finished
GUI Improved: improve the "Search ED2K links" dialog launched from the file list of BitTorrent task
GUI Improved: add thumbnail picture for task bar button in Windows 7, to display downloading task information
GUI Improved: display download progress on task bar button in Windows 7
GUI Improved: add frequent used operations to context menu of task bar button in Windows 7
GUI Improved: new global settings to specify main window action when program starts, minimized or closed
GUI Improved: new option for auto-shutdown, to action once or forever
GUI Improved: OpenDir, Properties and Delete buttons in toolbar available when switched to Torrent History list
Core Improve: support "VIP Accelerate" for BitTorrent download
Core Improve: keep original creator name of torrent file when save torrent as
Core Bugfix: connect to peers returned from DHT network using encryption protocol by force (thanks to Ori)
Core Bugfix: VideoSnapshot.exe can not exit normally when processing abnormal video files
Core Bugfix: change the limit of disk cache up to 2GB
Download links
BitComet 1.24 setup.exe
BitComet 1.24.zip
BitComet 1.24 emule plugin.exe
BitComet 1.24 xtreme plugin.exe
Changelog
Download links
BitComet 1.24.zip
