Only quiz moderators can submit quizzes
Let me start off by saying thanks for such a great mod. I installed this a few days ago and everything works great except one part. No matter who I add to the Quiz Moderator list they can not create quizes. Only site admins can. Am I doing something wrong? I checked the database and the names are in the Quiz moderator table.
Are you entering user id's? Sounds like you might be entering their usernames.
Yeah, that's the problem. Enter their user id numbers. Like: 4,76,21,53,11,100,21 .... etc
Fantastic
If you try putting your own user ID in there, what happens when you try to access quizzes?kikkotm wrote:I tried to ban some users to not partecipate to quizzes but it doesn't work.
I insert user's id like 40,34,45..but
I tried with an user ID (i was going on phpbb database to search the exactly id)
I write 40 (the number), I tried to acced with the User Numbero 40, but I could do the test.
I tried also with 39 (the number on the forum list) but the result was the same!!
Try this.
Open functions_quiz.php and FIND:
REPLACE WITH
Does that fix it?
function quiz_permissions()
global $board_config, $lang, $userdata;
if($board_config['Quiz_Register_Play'] == ON) // If this is OFF, basically it means Guests can play quizzes.
if(!$userdata['session_logged_in'])
return message_die(GENERAL_MESSAGE, $lang['Quiz_must_be_registered']);
if($board_config['Quiz_Post_Count_Play'] == ON)
if($userdata['user_posts'] < $board_config['Quiz_Post_Requirement'])
return message_die(GENERAL_MESSAGE, sprintf($lang['Quiz_post_requirement_not_met'], intval($board_config['Quiz_Post_Requirement'])));
$users = explode(',', $board_config['Quiz_Banned']);
for( $o = 0; $o < count($users); $o++ )
if( intval($userdata['user_id']) == intval($users[$o]) )
message_die(GENERAL_MESSAGE, "You cannot play quizzes");
}CricketMX.com in 2022: Still the home of bat's, rat's and other farmyard animals!
