Erorr! In Quiz Install
bIgEr
CREATE TABLE phpbb_quiz_statistics ( `stats_id` int(5) NOT NULL default '', `quiz_id` int(10) NOT NULL default '', `user_id` int(10) NOT NULL default '', `stats_correct` INT(5) NOT NULL default '0', `stats_incorrect` INT(5) NOT NULL default '0', `stats_percentage` INT(3) NOT NULL default '0');
I have this error.
bIgEr
SQL query:
CREATE TABLE phpbb_quiz_statistics(
`stats_id` int( 5 ) NOT NULL default '',
`quiz_id` int( 10 ) NOT NULL default '',
`user_id` int( 10 ) NOT NULL default '',
`stats_correct` INT( 5 ) NOT NULL default '0',
`stats_incorrect` INT( 5 ) NOT NULL default '0',
`stats_percentage` INT( 3 ) NOT NULL default '0'
MySQL said:
#1067 - Invalid default value for 'stats_id'
While i try manual
bIgEr
Second Erorr.
Query 17 did not execute correctly
DEBUG MODE
SQL Error : 1054 Unknown column 'user_points' in 'field list'
UPDATE phpbb_config SET config_value = user_points WHERE config_name = 'Quiz_Cash_Currency'
Line : 84
File : admin_quiz.php
2 Erorrs :(
Coding is not my forte but...Google is my friend :wink:
I searched for...
http://www.google.com/search?hl=en&q=Qu ... arch&meta=
The first result would appear to be what you are looking for...
Yep, that's right.
I have just updated the sticky to have a link as well, because a few people have asked this.
I get the error "Query 17 did not execute correctly". Help.
This is very easy to fix. It is just a small bug in admin_quiz.php. Replace the current admin_quiz.php file with the file found at http://forums.cricketmx.com/viewtopic.php?p=57367#57367 and you will not get error.
bIgEr
You didn't answer this one.
that's in database erorr
bIgEr
DEBUG MODE
SQL Error : 1146 Table 'ecmekoh_portal.phpbb_quiz_statistics' doesn't exist
SELECT stats_id FROM phpbb_quiz_statistics ORDER BY stats_id DESC LIMIT 1
Line : 31
File : functions_quiz.php
Comes with error.
I know why comes see post 1 :)
Do you use MySQL?
bIgEr
Yes i'm using MYSQL.
Something wrong with `stats_id` as i see
I vaguely remember fixing this a few years ago.
Try:
CREATE TABLE phpbb_quiz_statistics ( `stats_id` int(5) NOT NULL default '0', `quiz_id` int(10) NOT NULL default '0', `user_id` int(10) NOT NULL default '0', `stats_correct` INT(5) NOT NULL default '0', `stats_incorrect` INT(5) NOT NULL default '0', `stats_percentage` INT(3) NOT NULL default '0');
Does that work?
bIgEr
Your SQL query has been executed successfully (Query took 0.0111 sec)
Thank You :)
No worries! :mrgreen:
bIgEr
Quiz Results
Correct Answers: 5 Incorrect Answers: 0
100%
You took 0 minutes, 5 seconds
Now works great .
Thanks again .. And thanks for this MOD
