Ultimate Quiz MOD v1.2.x/v1.3.x FAQ
Does it work with phpBB v2.0.22?
Yes
I get the error "Query 17 did not execute correctly". Help.
This is very easy to fix. It is just a small bug in admin_quiz.php. Replace the current admin_quiz.php file with the file found at http://forums.cricketmx.com/viewtopic.php?p=57367#57367 and you will not get error.
How to get this working with the POINTS MOD?
Read this topic: http://forums.cricketmx.com/viewtopic.php?t=4205
Information about Quiz Packs and .qp files Time Limits and Playing Quizzes Once
http://forums.cricketmx.com/viewtopic.php?t=4174
If you have time limits enabled, and also want users to play quizzes once only, then there is a small fix you can apply so that when the users exceed their time limit, they cannot have a second bite at the cherry - it records them as already having played it in the database.
Dynamic timer in the quiz
http://forums.cricketmx.com/viewtopic.p ... 354#p92354
All the code changes required to add a live updating countdown clock.
Banning people from quizzes doesn't work!
http://forums.cricketmx.com/viewtopic.php?p=81426#81426
Follow the code instructions in this post and the problem should be solved.
Deleting statistics for certain users
http://forums.cricketmx.com/viewtopic.p ... 035#p89035
Running the script and following the instructions listed in the post will allow you to delete all quiz statistics for a certain user.
Quiz moderators
http://forums.cricketmx.com/viewtopic.php?t=4183
Always ensure that when you enter quiz moderators, you enter their user id number, and not their username. To find a user id number, view a post of the users, and hover over their Image button. In the browser, you will see the link such as profile.php?mode=viewprofile&u=1528 - whatever the number is, in this case it is 1528, is the user id number for that user. This is what you enter into the ACP, separating each one with a comma (,).
Updating to v1.3.x from v1.0.6
http://www.cmxmods.net/quiz.php?mode=updating
Information on how to upgrade from old UQM versions (1.0.6 and earlier, circa 2004) to the latest and greatest 1.3.x series.
last updated Nov 8, 2008
