Being as this is the Metis discussion group, it seems the obvious place to post this!
Ok, my Metis bot is called 'Bot' and I use it to respond to users requests and display the response 'privately'. Here is what I have:
<command type="script" flood="1">
<in>help!</in>
<out type="normal" delay="200">#private %RAWNAME% #message The following help is available:</out>
<out type="normal" delay="200">#private %RAWNAME% #message join! - Details of how to join</out>
<out type="normal" delay="200">#private %RAWNAME% #message how to share files - needs updating</out>
<out type="normal" delay="200">#private %RAWNAME% #message how to unshare files - needs updating</out>
<out type="normal" delay="200">#private %RAWNAME% #message how to search</out>
<out type="normal" delay="200">#private %RAWNAME% #message how to browse</out>
<out type="normal" delay="200">#private %RAWNAME% #message what is remotely queued</out>
<out type="normal" delay="200">#private %RAWNAME% #message what is busy in queue</out>
<out type="normal" delay="200">#private %RAWNAME% #message how to change your name</out>
<out type="normal" delay="200">#private %RAWNAME% #message how to download</out>
</command>
Which produces this 'privately' when someone types help!:
Bot700_00000 [Private] The following help is available:
Bot700_00000 [Private] join! - Details of how to join
Bot700_00000 [Private] how to share files - needs updating
Bot700_00000 [Private] how to unshare files - needs updating
Bot700_00000 [Private] how to search
Bot700_00000 [Private] how to browse
Bot700_00000 [Private] what is remotely queued
Bot700_00000 [Private] what is busy in queue
Bot700_00000 [Private] how to change your name
Bot700_00000 [Private] how to download
However, this is what I would like to appear 'privately':
OR even better
how to search
how to browse
how to download
I would REALLY appreciate some guidance on this. Many thanks
