You can download the English or the French version at this link.BideBotMX is a bot written in delphi language ( pascal ). It is inspired from a bot written for IRC. It has dll's as
plugins. these plugins are written in a standard form to interface bidebotMX with other language dll. DScript.dll
is a plugin that allow BideBotMX to run scripts written in a special language that looks like Delphi Pascal
language. In the hope to write scripts, you need to have some Pascal/Delphi knowlege:
Writing loops, event handlers... Otherwise you can see the existing scripts.
how does it work :
The program BideBotMX send some room events to the plugins.
for example when a text is written into the room, the event OnText is sent to the plugins.
In the script files (with the plugin dscript) you must written some code to say what you do when an event is received.
I'm using BidebotMX in my WinMX chat room now.
It sends a welcome message whenever someone enters your room , includes Hangman , trivia , Mastermind and you can display pictures in your room with it. It has a bad word list too that triggers the bot to displays a message in the room whenever someone says a word that's in the bad word list. Mine says , "<user name> you are banned :-Þ".
Thanks to the programmers Bide&Musique for the bot.
