latest version and
Gephri
I've updated to 1.3.3 but continue to get the "hacking attempt" error whenever quiz answers are submitted. Traced the alert to the following code - but not sure what is triggering it:
	// Merge all into one extremely huge array; unset
	// this later
	$input = array_merge($HTTP_GET_VARS, $HTTP_POST_VARS, $HTTP_COOKIE_VARS, $HTTP_SERVER_VARS, $HTTP_SESSION_VARS, $HTTP_ENV_VARS, $HTTP_POST_FILES);
	unset($input['input']);
	unset($input['not_unset']);
	while (list($var,) = @each($input))
		if (in_array($var, $not_unset))
			die('Hacking attempt detected !');
//		unset($$var); 						// MOD Backslashes Added
	unset($input);
Also, could you update your text file so we see the latest version available - the text file currently shows 1.2:
http://www.cmxmods.net/quiz_latest.txt
Toy
1.3.3 is a Beta.
Gephri wrote:I've updated to 1.3.3 but continue to get the "hacking attempt" error whenever quiz answers are submitted. Traced the alert to the following code - but not sure what is triggering it:
	// this later
	unset($input);
Have you made all the required changes? This was fixed in 1.3.1 :)
And regarding the version, see Toy's post :wink:
Gephri
yea - did all the updates.
Can you tell me what was "fixed" for this error - I'll try and work backwards from there.
Regarding version - got it,
It was to do with the radio boxes, and their name attribute being set to a number. From memory, to solve this, uqm_ was added in front of the variable. It was done in quiz.php IIRC :)
Gephri
got it - went back and reinstalled from scratch
thanks
