Debug Mode
mummiesonline
Hi,
I installed the quiz mod this morning and are having no problems apart from this error that comes up when I submit any changes via the acp.
Query 17 did not execute correctly
DEBUG MODE
SQL Error : 1054 Unknown column 'user_points' in 'field list'
UPDATE phpbb_config SET config_value = user_points WHERE config_name = 'Quiz_Cash_Currency'
Line : 84
File : admin_quiz.php
I have no idea on what to do, I have re uploaded the admin_quiz file but it won't help.
Kirsty
mummiesonline
Hi,
I have now noticed that when someone tries to play it comes up with a Hacking Attempt error.
This is very frustrating....
Kirsty
RMcGirr83
mummiesonline wrote:Hi,
DEBUG MODE
Line : 84
Kirsty
Did you name your cash mod user_points db column something else. If so that's the problem. Generally these cash mod add-ons require the user field to be set at user_points.
mummiesonline
Mine is at user_points, I checked that.
Hi :)
This is fixed in v1.3.1, but to fix it for 1.2.0, see the following link :)
http://www.phpbb.com/phpBB/viewtopic.ph ... 46#2006146
