Link Referer Mod
Is there a mod out there where you can put in a link
in the Admin panel to lets say:
http://www.test.com - And the page create - referer?f=1
http://www.testing.com - And the page create - referer?f=2
http://www.blabla.com - And the page create - referer?f=3
The referer script creates a url like:
http://www.volunteerforum.se/referer?f=1
http://www.volunteerforum.se/referer?f=2
http://www.volunteerforum.se/referer?f=3
http://www.volunteerforum.se/referer?f=xx
http://www.volunteerforum.se/referer?f=100
And so on..
So when i add the url lets say:
Anywhere on the net and my page it goes to:
(As usual i have no idé if "?f=2" is the right or wrong "end")
I know i talked about it before, but nothing happened whit it then
Link Referer Mod
Talk, discuss or debate everything about Volunteer 'ing at this forum!
Volunteer Forum Community
You mean a bit like this?
http://forums.cricketmx.com/home.php?mo ... te=general
Something like that, but it should not be public to see it.
Only in the Admin Panel.
(Its only for my own use)
Also so i can see whats happening on the linkpage. who gets click etc there.
And the link is tooooooo long:
http://forums.cricketmx.com/home.php?mo ... ocks_music
Think how nice it would be if that link was like this instead:
http://forums.cricketmx.com/referrer?f=11
Alot nicer =P
Alot nicer =P
Then you could use it like this also:
<A HREF="http://forums.cricketmx.com/referrer?f=11" TARGET="_blank">Hockeyjocks Music</A>
[url=http://forums.cricketmx.com/referrer?f=11]Hockeyjocks Music[/url]
Okay, there are several ways you can do this.
The easiest is simply through a PHP file (and it is quite easy). The other is like you said, through the admin panel and then in to the database. That is quite complicated to write though. Not difficult, but it will take considerably longer than the first method because it involves the database.
What are you leaning towards?
Yee but is there a mod out there that does this ?
It sounds so common.
Its like "it must exist already" I think =P
To much in that mod then i need.
But the concept is right
Like:
links.php?mode=show&id=89
Like:
