Shoutbox Mod problem, changed server
That's impossible.. did you also change the one on line 290 as mentioned in the error?
Hi Battye,
I searched through that area on the index.php. I did not locate that text.
I cleaned all my forums files out and did a fresh install with 2.0.19. then I imported my backup config.php and my backups and started from fresh. Will do a Shoutbox Mod from fresh as well.
The site is up again, and I didn't lose any posts/threads.
Thanks Battye, for sticking with me. Looking forward to installing 0.1.3 as I have been using 0.1.2 up until now.
What is the difference?
Thanks,
Heeter
Thanks,
Heeter
Hi, there is someone who made 0.1.4 (at phpBB.com) so you may want to consider that instead
Hope to continue to see you around the forums here
If you get a chance, don't forget to drop by OT Forum
Sure I am sticking around, The yellow paint in here is pretty cool, LOLOL
Is there a way do remove/clean out the shoutbox entries in mysql (4.1.2 version).
I am still getting sql errors same as posted above when I run shoutbox_install.
Will go check for updated version of Shoutbox. Excited already. I never really modded my site, really not into it, but the Shoutbox mod is the only one that everyone sees/uses, can't wait to get it going.
Thanks Battye.
Heeter
Thanks Battye.
Heeter
