Warning: main(): Failed opening~~~~
Leon
Well i dont think that what i did made this problem.
I changed so i got a new header on the portal,
it worked just fine, then 5 mins later this comes up:
Warning: main(http://www.volunteerforum.se/overallheader/RandomBanner/rotate_nr/9.php): failed to open stream: HTTP request failed! HTTP/1.1 404 OK in /home/volunteerforum/www/overallheader/RandomBanner/rotate_nr/banners.php on line 6
Warning: main(): Failed opening 'http://www.volunteerforum.se/overallheader/RandomBanner/rotate_nr/9.php' for inclusion (include_path='.:/usr/share/php:/usr/share/pear') in /home/volunteerforum/www/overallheader/RandomBanner/rotate_nr/banners.php on line 6
So ofcourse i changed the portals header back to standard.
But this problem is still there..
Its the random banner script we talked about before.
And as i can see it, i cant even open the file that creates it =/
http://www.volunteerforum.se/overallhea ... anners.php
This code has always worked so =/
srand ((double) microtime( )*1000000);
$numbanners = 14;
$number = rand(0,$numbanners);
echo "<table align=center width=468 height=60><tr><td>";
include ("http://www.volunteerforum.se/overallheader/RandomBanner/rotate_nr/$number.php");
echo "</td></tr></table>";
This file has worked all the time, and i dont think it had anything
to do whit me changing the header on the portal :?
So i temporarily removed this script from the header.
Talk, discuss or debate everything about Volunteer 'ing at this forum!
Volunteer Forum Community
I still don't think that include is correct, in my experiences you should never have an http link in the include.
I would go with file_get_contents() :wink:
Leon
But it has worked all the time like this :?
But i do use it on the:
include/page_header.php
$template->assign_vars(array("ROTATEBANNER" => file_get_contents('http://www.volunteerforum.se/overallhea ... anners.php')));
It should work for this particular function as well.. but if not, we will need to look for an alternative :)
Leon
I tried your way in the banners.php
$numbanners = 14;
file_get_contents('http://www.volunteerforum.se/overallheader/RandomBanner/rotate_nr/$number.php');
Then i got this instead
Warning: file_get_contents(http://www.volunteerforum.se/overallhea ... number.php): failed to open stream: HTTP request failed! HTTP/1.1 404 OK in /home/volunteerforum/www/overallheader/RandomBanner/rotate_nr/banners.php on line 6
file_get_contents('http://www.volunteerforum.se/overallhea ... rotate_nr/' . $number . '.php');
You needed the ' . . ' around the variable $number
Leon
Ok, fixed:
Warning: file_get_contents(http://www.volunteerforum.se/overallheader/RandomBanner/rotate_nr/4.php): failed to open stream: HTTP request failed! HTTP/1.1 404 OK in /home/volunteerforum/www/overallheader/RandomBanner/rotate_nr/banners.php on line 6
$numbanners = 14;
file_get_contents('http://www.volunteerforum.se/overallheader/RandomBanner/rotate_nr/' . $number . '.php');
Can it be the server that makes this problem ?
Leon
Ok i made a test and included:
http://www.volunteerforum.se/overallhea ... e_nr/1.php
Test.php
include("http://www.volunteerforum.se/overallheader/RandomBanner/rotate_nr/1.php");
http://www.volunteerforum.se/overallhea ... r/test.php
Warning: main(http://www.volunteerforum.se/overallheader/RandomBanner/rotate_nr/1.php): failed to open stream: HTTP request failed! HTTP/1.1 404 OK in /home/volunteerforum/www/overallheader/RandomBanner/rotate_nr/test.php on line 3
Warning: main(): Failed opening 'http://www.volunteerforum.se/overallheader/RandomBanner/rotate_nr/1.php' for inclusion (include_path='.:/usr/share/php:/usr/share/pear') in /home/volunteerforum/www/overallheader/RandomBanner/rotate_nr/test.php on line 3
Leon
This works:
test.php
include("1.php");
This:
or:
Does not work
Leon
Now the file works agian:
$numbanners = 14;
include ("$number.php");
Changed:
include ("http://www.volunteerforum.se/overallhea ... number.php");
To:
But why ?
I haden't changed a thing, but now it works ? :?
Why did i need to make this change when it has been working before ?
Leon
I added AdSence on the normal header.
And continued to work on the testpage
http://www.volunteerforum.se/testpage.php
I did get the banners.php file to work, but i cant include
it whitout problem (yet)
BTW battye, look at this nicly done site i saw today:
http://www.mountainfund.org
Really lowely site. perfect done.. :P
Best volunteer site i have seen so far
(Except mine ofcourse) :wink:
Leon
I simplified this test:
This should work:
test.php
include ("http://www.volunteerforum.se/overallheader/RandomBanner/Tanzaniaprojektet.jpg");
But it dosen't
Warning: main(http://www.volunteerforum.se/overallheader/RandomBanner/Tanzaniaprojektet.jpg): failed to open stream: HTTP request failed! HTTP/1.1 404 Not Found in /home/volunteerforum/www/overallheader/RandomBanner/rotate_nr/test.php on line 3
Warning: main(): Failed opening 'http://www.volunteerforum.se/overallheader/RandomBanner/Tanzaniaprojektet.jpg' for inclusion (include_path='.:/usr/share/php:/usr/share/pear') in /home/volunteerforum/www/overallheader/RandomBanner/rotate_nr/test.php on line 3
Seems like there is something else then just a faulty code
But when i include something from the same folder it works.
Like: include ("1.php");
Can't it be the server in some way ?
With your first example, you can't include an image. You output an image with echo '<img src="linktoimage.jpg" />'; :)
Leon
Ok, that worked. But how do i include another php file then ?
(Whit a long url)
How do i include/echo this file in another php file in a proper way:
If i need i can have this in the root file too:
$template->assign_vars(array("***" => file_get_contents('*FOLDER*FILE*')));
Because it dosen't work for me anymore...
What is the path (http://...) to the file you wish to put the code into?
