Shoutbox Mod problem, changed server
Heeter
Hi Guys,
I moved my forums onto a new tower. I copied and pasted the forum and the sql folders over. The forums (phpBB2.0.19) are pretty much up and running okay, as is the database (Mysql5.0). The problem is with the shoutbox.
It was working fine in previous setup, but I cannot get it to work properly here. There is no previous entries listed, and when I put in a new shoutbox entry the screen goes white.
I tried running shoutbox_install.php and this the errors that I am getting.
Anyone can tell me what I need to do to fix?
Thanks in advance,
Heeter
Heeter
Here is the error when logging onto site.
Thanks again,
Heeter
Heeter
Hi all,
I just tried upgrading to 0.1.3 and I am still gettings the same errors.
Thanks,
Heeter
Did you apply the changes to constants.php? Looks like you didn't:)
Heeter
Hi Battye,
Yes I did mod the constants.php file.
// Shoutbox MOD
define('SHOUTBOX_TABLE', $table_prefix.'shoutbox');
Same error.
Thanks,
Heeter
Could you please paste the contents of shoutbox_install.php here?
Don't forget to use the
 tag.
Heeter
http://hcctech.ca/forums/index.php
Now I have two shoutboxes, one on top and one on the bottom. Must be from the 013 mod.
Here is the sboutbox_install.php
 *                               shoutbox_install.php
 *   begin                : Sat, Oct 26, 2005
 *   copyright          : (C) 2005 Battye @ CricketMX.com
 *   email                : cricketmx@hotmail.com
 *   $Id: shoutbox.php, v1 (October 2005) battye Exp $
 *   This program is free software; you can redistribute it and/or modify
 *   it under the terms of the GNU General Public License as published by
 *   the Free Software Foundation; either version 2 of the License, or
 *   (at your option) any later version.
$phpbb_root_path = './';
//include($phpbb_root_path . 'config.'.$phpEx);
$userdata = session_pagestart($user_ip, PAGE_INDEX);
init_userprefs($userdata);
$sql = array();
$sql[] = "CREATE TABLE `" . SHOUTBOX_TABLE . "` (
  `shoutbox_id` int(5) NOT NULL default '0',
  `shoutbox_datetime` VARCHAR( 255 ) NOT NULL default '',
  `shoutbox_text` varchar(255) NOT NULL default '',
  `shoutbox_author` int(5) NOT NULL default '0'
$sql[] = "INSERT INTO " . CONFIG_TABLE . " (config_name, config_value) VALUES ('guest_shoutbox', '0')";
$sql[] = "INSERT INTO " . CONFIG_TABLE . " (config_name, config_value) VALUES ('rows_shoutbox', '5')";
	for ($i = 0; $i < count($sql); $i++)
		if( !$db->sql_query($sql[$i]) )
		echo $i . ': The shoutbox table / rows could not be created (' . $sql[$i] . ')( ' . $db->sql_error() . ' )<br />';
message_die(GENERAL_MESSAGE, $lang['Shoutbox_table_made']);
Thanks for your help, Battye.
Heeter
Try changing:
$sql = array();
To
$sql = array();
$sql[] = "CREATE TABLE " . SHOUTBOX_TABLE . " (
If that doesn't work, try:
$sql = array();
$sql[] = "CREATE TABLE phpbb_shoutbox (
Heeter
Hi battye,
Sorry, bud, no help, same errors.
Heeter
Heeter
If I was to do a fresh install of 2.0.19, then did a restore backup through the admin panel, then fresh installed 0.1.3 Shoutbox, would it work, or work the restore backup put shoutbox 0.1.2 back in? cause it was in the restore backup that this started happening.
Hope you understand what I am asking. LOLOL
Heeter
Heeter wrote:If I was to do a fresh install of 2.0.19, then did a restore backup through the admin panel, then fresh installed 0.1.3 Shoutbox, would it work, or work the restore backup put shoutbox 0.1.2 back in? cause it was in the restore backup that this started happening.
Heeter
I was referring to the first error regarding shoutbox_install.php.. are you sure that when you try the code changes above you get the same error?
In particular I'm referring to the very first error where it says CREATE TABLE `SHOUTBOX_TABLE` ....
Heeter
Heeter
Heeter
Even though it says "Shoutbox table created successfully" I still get debug errors upon login.
Thanks,
Heeter
On index.php you should find a few instances of:
Replace them with
phpbb_shoutbox
Heeter
I did replace..(2instances)...... and the same error as posted above.
Thanks for your Help, Battye
Heeter
