Sony MP3 Flash Walkman
Image Image Image
Three minutes and you’re ready to go
If this wasn’t enough, it only takes a mere three minutes to charge in order to enjoy up to three hours of playback. So plug it in, make a cup of tea and your new E Series is ready to entertain you for the next three hours. For a full charge, the E Series only needs two hours.
You also get a set of headphones, the essential SonicStage3.4 CD-ROM and a quick start guide whether you choose the 512 MB, 1 GB version or the 2 GB one. So once you’ve made your purchase, you’re ready to go. Other accessories available are an attractive armband, a silicon protective case, an acrylic splash-proof case and a clip with 3 caps making this one of the most stylish music players on the market.
If this wasn’t enough to make you rush out and buy your E Series WALKMAN, it’s also worth noting that it comes fully equipped with stop watch and a clock and calendar function too. And if you are a radio fan the 512 MB and 1 GB versions have the option of an *FM tuner.
*FM tuner versions not available from all retailers.
Any which way you like it
The E Series offers unbelievable sound quality, especially when using Sony ATRAC compression technology. Furthermore it’s also compatible with the most commonly used compression formats such as MP3 and WMA*.
* WMA files with DRM protection are not supported
http://tinyurl.com/fedgv
http://www.sony.co.uk
