port scans
p2p-sharing-rules
My Sygate firewall says I'm keep getting UDP port scans from the same IP, I traced the IP to Chinese ISP added a advanced rule to block their IP but I'm still getting port scans from them , the same with other IPs I get port scans & set a advanced rule to block them but I still get port scans from the same IP.
Why is it happening even If I set up a advanced rule to block them it still says their port scanning me?My firewall says it's blocking them . Should I report them to their ISP & what exactly is port scanning?I'm guessing their scanning to see if I have any open ports for them to connect to me to do who knows what.
When it comes to firewalls, I'm out of my comfort zone, however, have you tried blocking an entire IP range?
You should be able to set wildcards somewhere such as xxx.xxx.xxx.* with the asterix as the wildcard.
p2p-sharing-rules
Thanks Battye I haven't put a IP address range just the IP they were using when they UDP port scanned me.
tunebud
Sounds like a bug to me. The reason reports keeps coming back to you is the fact your PC is is the culprit sending the info. to the intruder.
Start doing some virus scans I bet you will find it hidden inside.
It seems that China has a lot of machines involved in this kind of activity. I get a lot of phishing reports at work, and many of the originating ip addresses are in China.
Myth!
hello people from the past :-)
There are 10 kinds of people...those who understand binary and those who don't.
Layzie Bone
Mr. Computergeek Salad Guy
interesting. When i was at college the University would do port scans, I think by the time the semester was over I had about 80 computers blocked. I couldn't do a IP range because i would make it to where I couldn't get on the university's website and the internet in general. I had about %1 of the network blocked, out of 65,535 computers....
I would run some adware/spyware scanner because along with phishing, keloggers are a possibility. Keloggers are used to watch your every move, every key you press and every click of the mouse is logged, therefore they can get your credit card info.
Port scans are used to find out which ports are open to communication. However, with a software firewall all ports, except ones in use, are stealthed. That means, the person scanning your ports can't find out whether they're open or closed, as if your computer is invisible.
