Have tried using the BBcode [img]image[/img] but this displays as the following in the actual quiz :
IMM
After reading the question, type the answer into the field beside!
[img]phpBB/images/Antonov%20An-70.jpg[/img]
[img]phpBB/images/Backfire.jpg[/img]
[img]phpBB/images/Black%20Hawk.jpg[/img]
[img]phpBB/images/Draken.jpg[/img]
[img]phpBB/images/Flanker.jpg[/img]
[img]phpBB/images/Flogger.jpg[/img]
[img]phpBB/images/Fulcrum.jpg[/img]
[img]phpBB/images/Harrier.jpg[/img]
[img]phpBB/images/Hornet.jpg[/img]
[img]phpBB/images/Jaguar.jpg[/img]
[img]phpBB/images/Merlin.jpg[/img]
[img]phpBB/images/Nimrod.jpg[/img]
[img]phpBB/images/Osprey.jpg[/img]
[img]phpBB/images/Tornado.jpg[/img]
[img]phpBB/images/Transall.jpg[/img]
Can somebody please explain how we get the actual images to display in the quiz...the path for the images on my server is phpBB/images
Adding images to Quiz
webmaster609
Use http://www.yoursitename.com/phpBB/images/image.gif
Using phpBB/images/image.gif by itself is not sufficient
webmaster609
Have tried using full address.....this is what is being displayed in the quiz.... still not displaying images.Identify the AIRCRAFT
Any ideas what I can be doing wrong, as the quiz itself works fine, just not displaying an image.....do you think I need an image size MOD to set the image size in the quiz?
Don't put a space between the [img] tag and the link.
Also, with images like Antonov An-70.jpg, replace that with Antonov%20An-70.jpg
webmaster609
Done all that...still no luck....removed reference to Antonov as file was corruptIdentify the AIRCRAFT
Any other suggestions....this is giving me grey hairs this side
You are putting these in the question field right?
From memory, I don't think you can put them in the answer field.
BTW, don't forget to say 'hi' in our Introductory Forum, we're only 12 posts from 1000
webmaster609
Yes ....placing the [img]images.jpg[/img] in the question field.... the answer field is showing blank on the quiz, but on setup I have entered the correct answers in the answer boxes....it is totally baffling me as to why the images will not display
Will definately go sign in at the Introductory Forum
Could you please set up a test account so I can try adding a quiz myself?
And thanks for the post in Introductory
webmaster609
Battye,
Test Account details:
User Name: webmasterTEST
Psw : test123
Hope you have luck
Psw : test123
Hope you have luck
Works perfectly for me
http://609wrsquadron.co.uk/phpBB/quiz.php?mode=play&q=3
I'm having a look at your test quiz right now
See: http://609wrsquadron.co.uk/phpBB/quiz.php?mode=play&q=4
So you can use http://www.609wrsquadron.co.uk/phpBB/images/Flanker.jpg or http://609wrsquadron.co.uk/phpBB/images/Flanker.jpg but NOT http://www.609wrsquadron.co.uk/phpBB/images/Flanker.jpg
So basically, all you need to do is include an http://
webmaster609
thats great...works for me now
.....Many thanks for all your assistance....much appreciated
No problem
Hope you continue to drop by here
webmaster609
Most definately will...as I said previously these forums are a godsend to us newbies ..we pick up loads of tips and advice as well as obtain first class assistance.....Keep up the good work, a job well done to you and your fellow moderators
