Beyond Rootkits: World's First Standalone Kernel Mode Bot?
p2p-sharing-rules
Posted on 04/06/2006 @ 15:49:00 in Viruses.
A European student has just developed a Proof of Concept for what the developer believes is the world's first kernel mode IRCbot.
The creator, Tibbar ("Rabbit" spelled backwards), says the difference between this innovation and standard Windows rootkits lies in its crossover ability. Most Windows-based rootkits hide in device drivers, then depend on outside, usermode applications to get anything done.
This creates several challenges for rootkitters:
The abilities of requested apps are limited to the security rights granted to the User.
The apps needed by the rootkit may not be present or accessible on the victim's system.
Usermode operations are easier than kernelmode to detect.
That's why Tibbar thinks IRCbot is a huge leap forward. It carries its IRC app onboard, inside the kernel driver. So it doesn't need any outside help to get the job done.
This means that future generations of rootkits... if that's what we'll call these... will be even stealthier than the current crop. Oh joy.
To pull this off, Tibbar drew from a Kernel mode sockets library by Valerino, who described his effort at rootkit.com as:
A fully functional TDI sockets library. You can connect, send, receive, all from your supa-dupa-l333t kernelmode rootkit. Yes, you can bypass lame TDI firewalls with this. No, you can't bypass NDIS firewalls.
(read : you can bypass norton's firewall).
While the IRCbot does no damage by itself, Tibbar helpfully set the project up in Visual Studio 2003, so it can be easily extended. In addition, bot builders can compile the beast as either a kernelmode driver or usermode executable.
In case you were wondering, Tibbar says it's easier to build and debug your usermode IRCbot, before creating the device driver.
Source:emailbattles.com
Related news story about The creator Tibbar.
How The Anti-Virus Industry Is Turning A White Hat Black, or (at least) Gray
On the 28th day of December 2005, Tibbar encrypted the public version of Hacker Defender, the world-famous Windows rootkit. At the same time, the anonymous author unleashed codeCrypter on the web.
Then Tibbar waited.
On the first of March 2006, Tibbar ("Rabbit" spelled backwards) submitted the codeCrypter'd Hacker Defender to VirusTotal, an online virus testing service used by white and black hats alike.
The results were dispiriting. Despite two months' warning, just four of 24 anti-virus engines recognized Tibbar's creation: BitDefender, Ikarus, NOD32 and VBA32. Three a/v engines, CAT-QuickHeal, Fortinet and Panda, spotted something they considered suspicious... [..]
:shock: That's scary that AV companies were slow to respond to this rootkit threat.
