eMule Plus is a new generation eMule compatible client created to improve the original GUI and to bring you the best experience ever. Give it a try and feel the boogie
02.03.2006 NEW! eMule Plus 1.2 released!
FEATURE: republish a file on file rating change to update server statistics [Aw3]
FEATURE: show file rating received from the server in the search list [Aw3]
FEATURE: detect Ogg Vorbis in AVI info {Fuxie - DK} [Aw3]
FEATURE: increased the file reask time for LowID clients up to 32 min in order to give them a chance to connect first & save a traffic on callback request [Eklmn]
FEATURE: WebServer: added support for receiving the HTTP header "If-Modified-Since" [morphis]
FEATURE: WebServer: compare "If-Modified-Since" and "Last-Modified" if they are the same, send the HTTP message 304 Not Modified, reducing file reloading [morphis]
FEATURE: WebServer: added support for "Accept-Encoding", Gzip is now automatic [morphis]
FEATURE: WebServer: added detection of caps lock while logging in [DonGato]
CHANGE: faster switching between the Known and Shared Files lists in the shared files view [Aw3]
CHANGE: avoided rare double publishing of a just completed file {muleteer} [Aw3]
CHANGE: applied a couple of optimizations for proxy support (from original) [Aw3]
CHANGE: more space for data in the search lists (reduced column margins) [Aw3]
CHANGE: updated Georgian flag {wonder_al} [Aw3]
CHANGE: faster message preprocessing in the transfer window [Aw3]
CHANGE: avoid creating a link with sources for unshared files {Vladimir (SV)} [Aw3]
CHANGE: MobileMule: protocol update (from original) [Aw3]
CHANGE: file sharing mode to allow read-only access to a preview file [Aw3]
CHANGE: improve timeout processing for open chat sessions {muleteer/Fuxie - DK} [Aw3]
CHANGE: significantly improved downloading from MLdonkey clients [Aw3]
CHANGE: more compatibility with VC2005 [brengarne]
CHANGE: revised and updated Lithuanian [vwpassatgt]
CHANGE: WebServer: new HTML4.01 strict login pages carrying Gzip compression indicator [morphis]
CHANGE: WebServer: reduced the file sizes of a lot of the images [morphis]
CHANGE: WebServer: updated/corrected ed2k link generation in transfer/shared files lists [Aw3]
CHANGE: WebServer: reduced file I/O while loading templates [Aw3]
CHANGE: WebServer: optimized preparation of the tranfer page [Aw3]
CHANGE: WebServer: added forced word wrap to logs [DonGato]
CHANGE: WebServer: optimized processing of the requests for auxiliary files [Aw3]
CHANGE: WebServer: permanent javascripts were moved to .js files to reduce traffic [morphis]
BUGFIX: startup (mostly Win98) when some windows were not available {semental/morrismatto} [Aw3]
BUGFIX: date display for maximum connections reached statistics {Fuxie - DK} [DonGato]
BUGFIX: copying of completing file instead of moving for case sensitive paths {glaskrug} [Aw3]
BUGFIX: proxy SOCKS 5 authentication (from original) [Aw3]
BUGFIX: URL for the Internet version check was outdated [KuSh]
BUGFIX: some IP ranges couldn't be loaded from PeerGuardian database [Aw3]
BUGFIX: the whole shared files list resort when chunk hidden status was changed by double-click [Aw3]
BUGFIX: rating icon update when edit shortcut was pressed on selected chunk [Aw3]
BUGFIX: saving of some list data after failed start {semental/morrismatto} [Aw3]
BUGFIX: completed file deletion on Show File Details when temp and incoming folders're the same {quadesh} [Aw3]
BUGFIX: processing of the connected sources if file was stopped [Eklmn]
BUGFIX: file reask by LowID client was skipped if a client is on the same server [Eklmn]
BUGFIX: a warning about too many shared files when no server information available {Vladimir (SV)} [Aw3]
BUGFIX: clipped string in category edit dialog {Vladimir (SV)} [Aw3]
BUGFIX: WebServer: added appropriate response if a requested file is not found [Aw3]
BUGFIX: WebServer: the HTTP header "Last-Modified" is now the requested file's modification date and not the date of when the template was loaded [morphis]
BUGFIX: WebServer: corrected page refresh feature {Rick164} [DonGato]
BUGFIX: WebServer: corrected tooltips code in XP template and a minor HTML error {Fuxie - DK} [DonGato]
Operating System: All 32-bit MS Windows (95/98/NT/2000/XP)
License: GNU General Public License (GPL)
Sourceforge eMule Plus-1.2.Installer download page.
eMule Plus FAQ
