<title>Volunteer Forum - {PAGE_TITLE}</title>
So all pages become: Volunteer Forum - "And the title here"
But when i add a titel at a website i created, there still is no
title as it should be.
Any idé why ?
Maybe fix this to the next version ?
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" dir="{S_CONTENT_DIRECTION}">
<head>
<meta http-equiv="Content-Type" content="text/html; charset={S_CONTENT_ENCODING}" />
<meta http-equiv="Content-Style-Type" content="text/css" />
<meta name="description" content="Volunteer Forum, Volontär Forum, Talk Discuss or Debate Volunteer 'ing" />
<meta name="keywords" content="Volunteer forum, Volontär forum, Community, Organisations, Portal, Website, Photo, Volunteer" />
<meta name="Author" content="http://www.phpbbstyles.com, Volunteer Forum" />
{META}
{NAV_LINKS}
<link rel="stylesheet" href="{T_TEMPLATE_PATH}/style_{TPL_COLOR}.css" type="text/css" />
<style type="text/css">
@import url("{T_TEMPLATE_PATH}/formIE.css");
</style>
<script language="javascript" type="text/javascript">
var PreloadFlag = false;
var expDays = 90;
var exp = new Date();
var tmp = '';
var tmp_counter = 0;
var tmp_open = 0;
exp.setTime(exp.getTime() + (expDays*24*60*60*1000));
function SetCookie(name, value)
var argv = SetCookie.arguments;
var argc = SetCookie.arguments.length;
var expires = (argc > 2) ? argv[2] : null;
var path = (argc > 3) ? argv[3] : null;
var domain = (argc > 4) ? argv[4] : null;
var secure = (argc > 5) ? argv[5] : false;
document.cookie = name + "=" + escape(value) +
((expires == null) ? "" : ("; expires=" + expires.toGMTString())) +
((path == null) ? "" : ("; path=" + path)) +
((domain == null) ? "" : ("; domain=" + domain)) +
((secure == true) ? "; secure" : "");
function getCookieVal(offset)
var endstr = document.cookie.indexOf(";",offset);
if (endstr == -1)
endstr = document.cookie.length;
return unescape(document.cookie.substring(offset, endstr));
function GetCookie(name)
var arg = name + "=";
var alen = arg.length;
var clen = document.cookie.length;
var i = 0;
while (i < clen)
var j = i + alen;
if (document.cookie.substring(i, j) == arg)
return getCookieVal(j);
i = document.cookie.indexOf(" ", i) + 1;
if (i == 0)
break;
return null;
function ShowHide(id1, id2, id3)
var res = expMenu(id1);
if (id2 != '') expMenu(id2);
if (id3 != '') SetCookie(id3, res, exp);
function expMenu(id)
var itm = null;
if (document.getElementById)
itm = document.getElementById(id);
else if (document.all)
itm = document.all[id];
else if (document.layers)
itm = document.layers[id];
if (!itm)
// do nothing
else if (itm.style)
if (itm.style.display == "none")
itm.style.display = "";
return 1;
else
itm.style.display = "none";
return 2;
else
itm.visibility = "show";
return 1;
</script>
</head>
<body bgcolor="#FFFFFF" text="#000000" link="#3B88C5" vlink="#3279B2" alink="#FF9C00">
<a name="top"></a>
<table border="0" cellspacing="0" cellpadding="0" width="100%" height="100%">
<tr>
<td width="10" class="border_left"><img src="{T_TEMPLATE_PATH}/images/spacer.gif" width="10" height="1" alt="" /></td>
<td width="100%" height="100%" class="content" align="center" valign="top">
<div id="header-box">
<div id="header-left"><a href="{U_INDEX}"><img src="{T_TEMPLATE_PATH}/images/{TPL_COLOR}/logo_left.gif" width="125" height="69" alt="{L_INDEX}" /></a></div>
<div id="header-right"><img src="{T_TEMPLATE_PATH}/images/{TPL_COLOR}/logo_right.gif" width="125" height="69" alt="" /></div>
<div id="header-center">
<b>{SITENAME}</b><br />
{SITE_DESCRIPTION}
</div>
</div>
<div id="navigation">
<!-- BEGIN switch_user_logged_out -->
<a href="{U_REGISTER}">{L_REGISTER}</a> |
<!-- END switch_user_logged_out -->
<a href="{U_INDEX}">Forum</a> |
<a href="{U_PORTAL}">Portal</a> |
<a href="websiteindex.php">Website</a> |
<a href="{U_ALBUM}">{L_ALBUM}</a> |
<a href="links.php">Links</a> |
<a href="{U_FAQ}">{L_FAQ}</a> |
<a href="{U_SEARCH}">{L_SEARCH}</a> |
<a href="{U_MEMBERLIST}">{L_MEMBERLIST}</a> |
<a href="{U_GROUP_CP}">{L_USERGROUPS}</a> |
<!-- BEGIN switch_user_logged_in -->
<a href="{U_PROFILE}">{L_PROFILE}</a> |
<a href="{U_PRIVATEMSGS}">{L_PRIVATEMSGS}{C_PM}</a> |
<!-- END switch_user_logged_in -->
<a href="{U_LOGIN_LOGOUT}">{CA_L_LOGIN_LOGOUT}</a>
</div>
<div id="content">
<!-- BEGIN switch_xs_enabled -->
<?php if($this->vars['CA_NEW_MSGS'] && $this->vars['PRIVATE_MESSAGE_INFO'] !== $this->vars['CA_L_NO_MSG'] && !defined('CA_POPUP_SHOWED')) { ?>
<div id="newmsgs"><a href="{U_PRIVATEMSGS}" class="newmsgs">{PRIVATE_MESSAGE_INFO}</a></div>
<?php define('CA_POPUP_SHOWED', true); } ?>
<!-- END switch_xs_enabled -->
<!-- BEGIN ca_new_privmsgs -->
{CA_XS_COMMENT_START}<div id="newmsgs"><a href="{U_PRIVATEMSGS}" class="newmsgs">{ca_new_privmsgs.TEXT}</a></div>{CA_XS_COMMENT_END}
<!-- END ca_new_privmsgs -->
'W_TITLE' => $title_website,Code: Select all
'W_TITLE' => 'Website - ' . $title_website,Code: Select all
* website.php
* begin : Thursday, Jun 09, 2005
* copyright : (C) 2005 Battye @ CricketMX.com
* email : cricketmx@hotmail.com
* $Id: website.php, v1.000.0.00 2005/09/06 21:18:36 battye Exp $
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
$phpbb_root_path = './';
include($phpbb_root_path . 'config.'.$phpEx);
include($phpbb_root_path . '/includes/constants.'.$phpEx);
include($phpbb_root_path . '/includes/functions_website.'.$phpEx);
include($phpbb_root_path . 'includes/bbcode.'.$phpEx);
// Start session management
$userdata = session_pagestart($user_ip, PAGE_INDEX);
init_userprefs($userdata);
// End session management
/* // For testing purposes
$lang['No_website'] = 'No website has been configured at this address!';
$lang['No_website_chosen'] = 'No website has been entered';
$lang['MOD_provided_website'] = 'User Website MOD © <a href=http://www.cricketmx.com>battye</a> 2005';
$lang['Admin_website'] = 'Administer Website';
$lang['Admin_sitename'] = 'Select an appropriate name for your website:';
$lang['Admin_sitetext'] = 'Enter the HTML for your site here:<br /><span class="genmed">Or use site %stemplates%s!';
$lang['Admin_website_updated'] = 'Website updated successfully!<br />Click %shere%s to view your site!';
$lang['Admin_website_colour'] = 'Choose a background colour for your site:';
$lang['Admin_website_nav'] = 'Administer Website';
$lang['Admin_website_back'] = 'Click <a href="javascript: history.go(-1)">here</a> to go back and make changes, or Submit!';
$lang['Admin_website_view_template'] = 'View Templates';
$lang['Admin_wesbite_theme_name'] = 'Template Name';
$lang['Admin_wesbite_theme_desc'] = 'Template Description';
$lang['Admin_wesbite_theme_auth'] = 'Template Author';
$lang['Admin_wesbite_use_temp'] = 'Use Template';
$lang['Admin_wesbite_preview_theme'] = 'Preview Template';
$lang['Admin_css'] = 'Enter the CSS for your site here:';
$lang['Admin_user_banned'] = 'You have been banned from creating a website!<br />Please contact an administrator for further details!';
$lang['Admin_group_banned'] = 'This usergroup has been banned from creating a website!<br />Please contact an administrator for further details!';
$lang['Admin_user_low_post'] = 'You need to have at least %s posts to create a website!<br />Please contact an administrator for further details!';
$lang['Admin_mod_off'] = 'This feature has been disabled by an administrator.';
$lang['Admin_user_not_enabled'] = 'Users are not allowed to have websites!';
$lang['Admin_group_not_enabled'] = 'Usergroups are not allowed to have websites!'; */
// $lang['Admin_website_hits'] = 'This page has had %d hits!';
// Gotta remember to put this in constants.php
/* // User Website MOD
define('WEB_YES', '1');
define('WEB_NO', '0');
$uwm_lang = array();
$uwm_lang['TABLE_HEADING'] = 'Table Heading';
$uwm_lang['SITE_DESCRIPTION'] = 'Enter a description of your site here';
$uwm_lang['LINK_DESCRIPTION'] = 'Enter a description of your link here';
$uwm_lang['CONTENT'] = 'Enter content here';
$uwm_lang['FONT_FACE'] = 'Verdana';
$uwm_lang['FONT_SIZE'] = '2'; */
// Ok let's begin outputting the site.. not just yet though.. haha tricked you :-)
if(isset($HTTP_GET_VARS['id']) || intval($HTTP_GET_VARS['group_id']) && $HTTP_GET_VARS['mode'] != "owner")
uwm_enabled();
user_or_group_enabled($HTTP_GET_VARS['group_id']);
if(intval($HTTP_GET_VARS['id']) || intval($HTTP_GET_VARS['group_id']))
$id = (intval($HTTP_GET_VARS['id'])) ? $HTTP_GET_VARS['id'] : $HTTP_GET_VARS['group_id'];
if(intval($HTTP_GET_VARS['id']))
$hits = "UPDATE " . USERS_TABLE . " SET user_website_hits = user_website_hits + 1 WHERE user_id = " . $HTTP_GET_VARS['id'];
if(!$db->sql_query($hits))
message_die(GENERAL_ERROR, 'Could not update hit counter');
$sql = "SELECT * FROM " . USERS_TABLE . " WHERE user_id = '" . $id . "'";
if(intval($HTTP_GET_VARS['group_id']))
// Are they a member?
if(user_group_member($userdata['user_id'], $HTTP_GET_VARS['group_id']) == 2)
message_die(CRITICAL_ERROR, $lang['Admin_only_group_can_make_edit']);
$hits = "UPDATE " . GROUPS_TABLE . " SET user_website_hits = user_website_hits + 1 WHERE group_id = " . $HTTP_GET_VARS['group_id'];
$sql = "SELECT * FROM " . GROUPS_TABLE . " WHERE group_id = '" . $id . "'";
message_die(GENERAL_ERROR, 'Could not grab information');
while($user_website = $db->sql_fetchrow($result))
if (!$user_website['user_website_html'])
message_die(GENERAL_ERROR, $lang['No_website']);
$user_website['user_website_title'] = str_replace($chars, $tags, $user_website['user_website_title']);
$user_css = (isset($user_website['user_website_css'])) ? "<style type=\"text/css\"><br /><!--<br />" . $user_website['user_website_css'] . "<br />--><br /></style>" : ""; // Originally by Excursus
$bad = array("<script", "<form", "<iframe", "<?php", "?>", "<html>", "<body>", "</html>", "</body>");
$good = array("<script", "<form", "<iframe", "<?php", "?>", "<html>", "<body>", "</html>", "</body");
// Changed to htmlspecialchars() and back again, damn error, how was *I* to know it wanted parameter 1 to be a string :rolls eyes:
$title_website = (str_replace("''", "'", $user_website['user_website_title'])) ? str_replace("''", "'", $user_website['user_website_title']) : "";
$user_html = str_replace("''", "'", str_replace($bad, $good, $user_website['user_website_html']));
$user_html = bbencode_second_pass($user_html, '');
$colour = $user_website['user_website_colour'];
if($board_config['website_hits'] == WEB_YES)
$hits_out = sprintf($lang['Admin_website_hits'], $user_website['user_website_hits']);
$db->sql_close();
include($phpbb_root_path . "includes/page_header.$phpEx");
// Ok, do it...
echo '<html>';
echo $user_css; // Originally by Excursus
echo "<title>$title_website</title><table bgcolor=\"$colour\" width=\"100%\"><tr><td>";
echo $user_html;
echo '</body></html>';
echo '<br />';
echo '<font face="Arial">';
echo '<div align="center">User Website MOD © <a href=http://www.online-scrabble.com>battye</a> 2005<br />
Powered by <a href="http://www.phpbb.com/" target="_phpbb" class="copyright">phpBB</a> © 2001, 2005 phpBB Group';
echo '<br /><br />';
echo $board_config['website_footer'];
echo '<br />';
echo $hits_out;
echo '</div></td></tr></table></font>';
else
message_die(GENERAL_ERROR, $lang['No_website_chosen']);
if($HTTP_GET_VARS['mode'] == "owner" && $userdata['session_logged_in'])
uwm_enabled();
$sql = "SELECT * FROM " . GROUPS_TABLE . " WHERE group_id = " . intval($HTTP_GET_VARS['group_id']);
else
$sql = "SELECT * FROM " . USERS_TABLE . " WHERE user_id = " . $userdata['user_id'];
$gu_data = $db->sql_fetchrow($result);
if($HTTP_GET_VARS['view'] == "templates")
// From php.net: readdir
if(!(isset($HTTP_GET_VARS['filename'])))
if ($handle = opendir('./html_templates'))
$page_title = $lang['Admin_website_view_template'];
$template->set_filenames(array("admin_t" => "admin_view_site_template_body.tpl"));
/* This is the correct way to loop over the directory. */
while (false !== ($file = readdir($handle)))
if(get_site_template_html("description", $file) != '')
$file_link = "<a href='./website.$phpEx?mode=owner&view=templates&filename=$file'>$file</a>"; // Filename
$template->assign_block_vars('temp', array(
"U_LINK" => $file_link,
"U_DESC" => str_replace("Description: ", "", get_site_template_html("description", $file)),
"U_AUTHOR" => str_replace("Author: ", "", get_site_template_html("author", $file))));
$template->assign_vars(array(
"L_LINK_NAME" => $lang['Admin_wesbite_theme_name'],
"L_DESCRIPTION" => $lang['Admin_wesbite_theme_desc'],
"L_AUTHOR_NAME" => $lang['Admin_wesbite_theme_auth']));
$template->pparse("admin_t");
include($phpbb_root_path . "includes/page_tail.$phpEx");
if(isset($HTTP_GET_VARS['filename']))
$template->set_filenames(array("admin_vt" => "admin_consider_template_body.tpl"));
"U_NAME" => $HTTP_GET_VARS['filename'],
"U_FULL_DESC" => str_replace("Description: ", "", get_site_template_html("description", $HTTP_GET_VARS['filename'])),
"U_AUTH_NAME" => str_replace("Author: ", "", get_site_template_html("author", $HTTP_GET_VARS['filename'])),
"U_CSS" => nl2br(htmlspecialchars("<style type=\"text/css\">" . get_site_template_html('css', $HTTP_GET_VARS['filename']) . "\n</style>")),
"U_HTML" => nl2br(htmlspecialchars(get_site_template_html("html", $HTTP_GET_VARS['filename']))),
"U_FORM" => append_sid("website.$phpEx?mode=owner"),
"U_FORM_P" => append_sid("website.$phpEx?mode=preview"),
"U_HIDDEN" => str_replace("<", "<", get_site_template_html("html", $HTTP_GET_VARS['filename'])),
"L_PRE_TEMP" => $lang['Admin_wesbite_preview_theme'],
"L_DESC" => $lang['Admin_wesbite_theme_desc'],
"L_USE_TEMP" => $lang['Admin_wesbite_use_temp'],
"L_AUTHOR" => $lang['Admin_wesbite_theme_auth']));
$template->pparse("admin_vt");
else
if(isset($HTTP_POST_VARS['pre_temp']))
echo "<style type=\"text/css\"><br /><!--<br />" . get_site_template_html("css", $HTTP_POST_VARS['html']) . "<br />--><br /></style>";
echo get_site_template_html("html", $HTTP_POST_VARS['html']);
die();
if(isset($HTTP_POST_VARS['use_temp']))
$userdata_revised_text = get_site_template_html("html", $HTTP_POST_VARS['html']);
$userdata_revised_css = get_site_template_html("css", $HTTP_POST_VARS['html']);
else
$userdata_revised_text = stripslashes(str_replace("''", "'", $gu_data['user_website_html']));
$userdata_revised_css = stripslashes(str_replace("''", "'", $gu_data['user_website_css']));
check_web_ban("user", "");
if(isset($HTTP_GET_VARS['group_id']))
check_web_ban("group", $HTTP_GET_VARS['group_id']);
$page_title = $lang['Admin_website'];
$template->set_filenames(array("admin" => "admin_website_body.tpl"));
"L_ADMIN_WEBSITE" => $lang['Admin_website_nav'],
"L_SITENAME" => $lang['Admin_sitename'],
"L_SITETEXT" => sprintf($lang['Admin_sitetext'], "<a href='./website.$phpEx?mode=owner&view=templates'>", "</a>"),
"L_SITECOLOUR" => $lang['Admin_website_colour'],
"L_CSS" => $lang['Admin_css'],
"L_SUBMIT" => $lang['Submit'],
"L_PREVIEW" => $lang['Preview'],
"U_SITECOLOUR" => $gu_data['user_website_colour'],
"U_CSS" => $userdata_revised_css,
"U_SITENAME" => $gu_data['user_website_title'],
"U_SITETEXT" => $userdata_revised_text,
"GROUP" => (intval($HTTP_GET_VARS['group_id'])) ? $HTTP_GET_VARS['group_id'] : '',
"FORM" => append_sid("website.$phpEx?mode=sql")));
$template->pparse("admin");
if($HTTP_GET_VARS['mode'] == "sql" && $userdata['session_logged_in'])
uwm_enabled();
user_or_group_enabled($HTTP_POST_VARS['group']);
if(!$HTTP_POST_VARS)
message_die(CRITICAL_ERROR, 'No $HTTP_POST_VARS found!');
if(isset($HTTP_POST_VARS['preview']))
$site_text = bbencode_first_pass(str_replace("\'", "''", $HTTP_POST_VARS['Sitetext']), '');
$site_text = str_replace($chars, $tags, $site_text);
$site_title = str_replace("\'", "''", $HTTP_POST_VARS['Sitename']);
$user_css = (isset($HTTP_POST_VARS['Sitecss'])) ? "<style type=\"text/css\"><br /><!--<br />" . $HTTP_POST_VARS['Sitecss'] . "<br />--><br /></style>" : ""; // Originally by Excursus
$title_website = (str_replace("''", "'", $site_title)) ? str_replace("''", "'", $site_title) : "";
$user_html = stripslashes(str_replace("''", "'", str_replace($bad, $good, $site_text)));
$colour = str_replace("'", "''", $HTTP_POST_VARS['Sitecolour']);
$db->sql_close();
echo '<html><body bgcolor="' . $colour . '">';
echo $user_css;
echo "<title>$title_website</title>";
echo $user_html;
echo '<br />';
echo '<font face="Arial"><table width="100%"><tr><td align="center">';
echo $lang['Admin_website_back'];
echo '</td></tr></table></font>';
if(isset($HTTP_POST_VARS['submit']))
$site_css = str_replace("\'", "''", $HTTP_POST_VARS['Sitecss']);
if(intval($HTTP_POST_VARS['group']))
$sql = "UPDATE " . GROUPS_TABLE . " SET user_website_title = '$site_title', user_website_colour = '" . str_replace("'", "''", $HTTP_POST_VARS['Sitecolour']) . "', user_website_css = '$site_css', user_website_html = '$site_text' WHERE group_id = " . $HTTP_POST_VARS['group'];
else
$sql = "UPDATE " . USERS_TABLE . " SET user_website_title = '$site_title', user_website_colour = '" . str_replace("'", "''", $HTTP_POST_VARS['Sitecolour']) . "', user_website_css = '$site_css', user_website_html = '$site_text' WHERE user_id = " . $userdata['user_id'];
if(!$db->sql_query($sql))
message_die(GENERAL_ERROR, 'Could not update user website information');
else
message_die(GENERAL_MESSAGE, sprintf($lang['Admin_website_updated'], "<a href='./website.$phpEx?group_id=" . intval($HTTP_POST_VARS['group']) . "'>", "</a>"));
else
message_die(GENERAL_MESSAGE, sprintf($lang['Admin_website_updated'], "<a href='./website.$phpEx?id=" . $userdata['user_id'] . "'>", "</a>"));
echo "<title>$title_website</title><table bgcolor=\"$colour\" width=\"100%\"><tr><td>"; Code: Select all
echo "<title>Website - $title_website</title><table bgcolor=\"$colour\" width=\"100%\"><tr><td>"; Does using that work?Leon wrote:Does not seems to work.
http://www.volunteerforum.se/website.php?id=3
Btw, should i maybe write something else then
<titel>blabla</titel>
in the:
website.php?mode=owner
page for it to work ?
Or use site templates!
Btw not even the page:
has an own titel
