I have a Lexmark X73 and it seems to install ok, I just can't use it
Every time I attempt to print something, it tells me I need to install a printer, which I have already done.
Any ideas?
My printer won't work!
Haven't tried any new drivers. I forgot to add, I installed it two days ago and it printing fine. I open it today and try to print and nothing happens
So I reinstall, and it seems to have installed, and then I get the errors above
XP
Connected though USB 2
It is a cool printer
Would be even cooler if it worked
It can read that the Printer/Scanner is online. When I turn it on, the cross in the system tray disappears
I think it has to be a software related thing
Registry? *gulp*
Don't access that through regedit in Run?
Yes. then click run the find. Type in Lexmark and hit enter. If you are unsure don't do it. Just delete any keys referring to lexmark. I do this and have only screwed up once. This ensures that it is gone completely from your system. Then you push F3 to find next.
Huh?
I've never edited my registry before and I'm totally unsure what to do!
Is there a way to back it up beforehand? And then is there a way to restore it?
Well, I'm not game enough to do it now.. I'll do it when I'm awake
Thanks for the help
Thanks for the help
If you are still having problems and don't want to mess with the registry, you can do a restore point back to a time when it did work. You will just have to reinstall any apps that you have installed since the restore point. It might fix it and if it doesn't you can go back to the future to the current restore point.
