Hi,
I have just installed your Shoutbox mod and it works great.
BUT, there is always a but, I am using the Black & White theme which uses white text on a black background. The colour of the text box within the shoutbox is so light that you cant see the text when typing I need the text box to be darker.
I can install the boards and mods but thats about as far as my knowledge goes, so your help would be greatly appreciated. Is it in a css file somewhere or is it somewhere else???
I don't want to take the shoutbox off when there may be an easy solution.
Please help
Many thanks
Daggers
Shoutbox mod... Please Help
Hi, can I see your forum so I know what I am dealing with? Cheers
Thanks for the quick response.
http://cenobitewarriors.co.uk/forum/index.php
The forum can be found at the above address.
Cheers
Daggers
Cheers
Daggers
No problem, I registered, but you still need to activate me
By the way, don't forget to say hello in out Introductory Forum: http://forums.cricketmx.com/viewforum.php?f=25
Ok, I see the problem.. well, rather.. I don't see the problem
If you can wait a few minutes or so, I'll give you a few things to try which should fix it
NiceI will visit your introduction forum too
Ok, open your index_body.tpl file, and find:
Now replace that little section with the following:
Let me know how it goes
<input type="text" name="shout" length="50" maxlength="255" /> <input type="submit" value="{L_SUBMIT}" />Code: Select all
<input type="text" name="shout" style="width:450px" tabindex="2" class="post" length="50" maxlength="255" /> <input type="submit" tabindex="5" class="mainoption" value="{L_SUBMIT}" />CricketMX.com in 2022: Still the home of bat's, rat's and other farmyard animals!
Glad you like it, and glad it's working for you
