Renaming Program - Bulk Rename Utility
[quote]Bulk Rename Utility is a utility which allows you to easily rename files and directories, based upon extemely flexible criteria. Add date-stamps, replace numbers, insert strings, convert case, add auto-numbers, process folders and subfolders....plus loads more!
Bulk Rename Utility is easy to use and has a small memory “footprintâ€
