anyone ever have this happen?
LavaGale
ok, can't get the ouka chat room to load in the winmx channel list for myself, everyone else can find the room, but not me, atleast not with winmx. So I figure I'll try putting it on my very old Pentium 2 pc cause a friend of mine says that's what she did and it does fine. I get it on but can't get it started cause I get this........"The Server .exe is linked to missing export SHELL.DLL:StrStrlA. " then another one pops up behind it sayin..."A device attached tothe system is not functioning"
Anyone know what this means?
Also, does anyone know ouka's minimum requirements?
Do you have Frog Legs?
Searcher
Are you running the server on an XP/win2k machine Lavagale.
Like many of the MxControl programs it will not work with 98/Me systems, maybe thats the problem ?
Also what port are you using to host the server on (6698 is the usual one ), as if its already in use it may give a strange message also. :?
tunebud
I cannot give you any answer but it sure is nice seeing you around Gale :) . You should do it more often..
tunebud wrote:I cannot give you any answer but it sure is nice seeing you around Gale :) . You should do it more often..
I agree with Tune :)
Hi Lavagale :)
LavaGale
Aww, thanks guys :D
the one I got it running on but could not load it in list to enter the room was on a 2000pro. could not get it on at all on my old p2 which rusn 98se. guess I know why now, lol
think I'm gonna try WCS , it loads great on the old p2, but no one, not even myself can get inside the room, will have to look little more at my router and try that backlooping thing I think :?
