hello everyone:-)
I have been hosting in Winmx lately, no problems except when I am hosting, I can never bring my room up on the list. Which is'nt really a problem when I am using winmx to host. But the cohost wants me to start using ouka chat server now, would love to, but seems I still can't bring the room up in my list when I use it, and therefore I can't get in it, and that's not good.
Any ideas why I can't bring the room up?? and what I can do about it?
Thanks for any input on this
Hosting in Winmx
- A Forum Addict
Are you behind a router? When hosting on my network others on my network can't see my channel on the list but can still join thru the LAN IP. If not did you make sure to go to Channel --> Connect WPN?
If you don't the channel won't list because it's not connected to the WPN.
yes, I'm behind a router, but I portforward, have no problem everyone else seeing the room, I just can't see it, not with ouka or winmx , when I am the one hosting. it just won't load for me
Do you have Frog Legs?
- p2p-sharing-rules
- Moderator
Lavagale I came across this tutorial @ WinMXworld
Problems entering your own chat room that might help you.
I hope it helps you.
I didn't even know you had a room or co-hosted a room on MX .
what's the name of it?
- p2p-sharing-rules
- Moderator
Your welcome hope it helps you sort out the problems you're having hosting a room.
Thanks for the room name too.
I'll have to check out the room one of these day since your a CMX member.
