Resurrecting WinMX
September 23, 2005
Thomas Mennecke
WinMX fans awoke Wednesday to disturbing news. However before realizing this news, the WinMX population was faced with the inability to connect to this community. Finally news reports began circulating that individuals were not alone and indeed the entire community had collapsed including the WinMX.com website.
Although the demise of FrontCode Technologies along with its WinMX.com homepage would not have been the end of the world, WinMX.com provided the all-important host cache server. This server provided the IP addresses to WinMX supernodes, thereby allowing clients entry to the network. With the WinMX.com domain eliminated, the network collapsed. That is unless of course someone establishes a new method of connecting to WinMX hosts.
P2Pzone.net, a popular Italian P2P news site has a collaborative effort resurrected the WinMX network. The method is quite simple. P2Pzone.net has indexed over 200 functioning WinMX hosts readily available to incoming WinMX connections. It requires the user to download a new host list provided from P2PZone.net, which redirects the WinMX client to the functioning hosts. From P2Pzone.net:
This is the procedure to configure your pc to connect with WinMx:
1) Download a new host file from this URL:
http://205.238.40.1/hosts/hosts
2) After downloading the "hosts" file (is a windows file included in the system) we can proceed.
3) Now paste the new file "hosts" in the Windows directory respective to its version:
For Windows 95/98/Me the directory is c:\windows\hosts
For Windows NT/2000/XP Pro the directory is c:\winnt\system32\drivers\etc\hosts
For Windows XP Home the directory is c:\windows\system32\drivers\etc\hosts
Now we can replace the "hosts" file.
4) For Win2k & XP users, sometimes may be necessary use the command "ipconfig /flushdns" from the command prompt.
5) Now, open WinMx and try to connect with primary connection!
Luca, the administrator of P2Pzone.net, tells Slyck.com this is a temporary fix and the developers are working on a more permanent solution. From public reaction so far and from our own testing, this method works exceedingly well. WinMX fans will certainly have a place to call home once again.
slycks
WinMX Back Online Thanks to Mr Drac
http://www.winmxworld.com/forum/viewtopic.php?t=410
UPDATE! Connect to WinMX using custom cache (Secondary Only)
http://www.vladd44.com/phpbb2/viewtopic ... 6494#26494
UPDATE! New fix for Primary and Secondary Connections
http://www.vladd44.com/phpbb2/viewtopic ... 6688#26688
Thanks to Mr Drac , KM & all the tech WinMX community users for creating this patch.
