Version 2.8 is an update of ver. 1.8
It now has a channel list which is downloaded from Nushi's web chat channel list via the ListClient plugin.
Okay so it's not spectacular. But I've been using Nushi Chat 1.8 for ages. It's simple, functional, and expandable with plugins. Now that it's been given the interface that the List Client plugin uses you can now get a channel list.
Like all versions prior to 2.0 it does not connect to the WPN, which means no browsing, PMs, or WhoIs.
I havn't translated it because, Nushi Chat has always had the same layout so it should be familiar to anyone using it. For those that aren't familiar it's simle enough you wouldn't need to be able to read it anyways. If I get bored tonight I'll translate it to give me something to do.
